Question about Acer X193W LCD Monitor
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the top and bottom do not touch the edge of the monitor's screen - please help.
  • 6,826 Answers
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Posted on Jul 29, 2010
VGA CABLES 15PIN
Use a VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
,connect it to the VGA port on the laptop,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
(Color does NOT matter )
A) Laptop OFF, monitor OFF, connect the CRT monitor to the laptop.
B) Turn the CRT monitor on, allow it to warm up.
C) Turn the laptop on. By factory default the display should now show on the external VGA (CRT) monitor.
IF not, there are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor AND external VGA (CRT ) monitor
3) External VGA (CRT) monitor ONLY
Press the Fn key down, and hold it down. At the same time tap once on the Display Toggle-Over key.
IF this is in reference to a Samsung NC10-14ROBL Notebook PC,
the Display Toggle-Over key is the F4 key.
[ http://www.samsung.com/uk/support/model/NP-NC10-KA02UK-downloads?isManualDownload=true ]
For additional questions please post in a Comment.
Regards,
joecoolvette
( Need a VGA connector pinout?
1) http://pinouts.ru/Video/VGA15_pinout.shtml
2) http://images.search.yahoo.com/images/view?back=http%3A%2F%2Fsearch.yahoo.com%2Fsearch%3Fei%3DUTF-8%26p%3DVGA%2Bpinout&w=160&h=160&imgurl=www.bing.com%2Fimages%2Fsearch%3Fq%3DVGA%2Bpinout%23focal%3Dc39c325e6d7bbd7d1b43dbc37441f812%26furl%3Dhttp%253a%252f%252fteletechsvc.net%252fpinouts%252fimg%252fvga_pinout.jpg&size=&name=search&rcurl=http%3A%2F%2Fwww.bing.com%2Fimages%2Fsearch%3Fq%3DVGA%2Bpinout%23focal%3Dc39c325e6d7bbd7d1b43dbc37441f812%26furl%3Dhttp%253a%252f%252fteletechsvc.net%252fpinouts%252fimg%252fvga_pinout.jpg&rurl=http%3A%2F%2Fwww.bing.com%2Fimages%2Fsearch%3Fq%3DVGA%2Bpinout%23focal%3Dc39c325e6d7bbd7d1b43dbc37441f812%26furl%3Dhttp%253a%252f%252fteletechsvc.net%252fpinouts%252fimg%252fvga_pinout.jpg&p=VGA+pinout&type=&no=1&tt=114&oid=http%3A%2F%2Fts1.mm.bing.net%2Fimages%2Fthumbnail.aspx%3Fq%3D4892612529160620%26id%3D948dd2942c3315d2dd2252cd4b849a08&***=vga_pinout&sigr=14ooshh1n&sigi=14huk2q99&sigb=11kfglo0l&fr=moz35
Apr 25, 2012 | Samsung NC10-14ROBL Notebook
Hi, I have an Acer X193W monitor that recently got an update that I guess was from 2008. When I restarted the computer suddenly everything was brighter colorwise. As in Red looked like pink and everything...
you should be able to uses "system restore" to remove the update or to take the computer back to the time before the update. here is a link for a article that will explain it all. if that doesnt work then you can search acers web site for drivers that are compatible with vista. i think you just have a driver issue. in fact, search for the drivers first then use restore if you have to. here is the article.
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
i just did a quick Google on Acer x193w vista drivers, and found several spots for drivers, here is 1.
Acer-X193W.html">http://www.bravofiles.com/driver-Acer-X193W.html
Apr 23, 2011 | Computers & Internet
How do you change the contrasting on the acer monitor x193W
Check for hidden buttons around the ridge and on the back if none are found you will need the software from acer to manage the display settings
Jul 21, 2010 | Acer X193W LCD Monitor
Low volume in acer x193w
install the audio drives again then it will worl fine
Jun 25, 2009 | Acer Aspire 5100 Notebook
"No signal" msg on new Acer X193W LCD Monitor with Vista 64-bit
this should be easy...go to your desktop...right click on it and choose "personalize" it will open up a window. on the bottom it will say display settings...click on it...at the top right it should say "identify monitors" click on that...if that dosent work.click on the monitor that has a 2 on it and it will ask you if you want to add a monitor...it should work
if not, post a comment and i will check back with you
Jun 21, 2009 | Acer X193W LCD Monitor
Just bought an Acer AL2216WBD flat panel monitor. Have an old Dell computer; "Jewel Quest" game loaded. When I plugged in the new monitor, tried to play the game. Good sound but no picture. Only "input...
the resolution is incorrect for that new monitor , it does not support it, attach the old monitor reduce the display resolution and then hook in the new monitor, up the resolution until it fails again and do nothing it will reset to the last good display resolution and you can leave it there.
hope this helps
Mar 06, 2009 | Acer X193W LCD Monitor
Home page does not fill the screen
use the monitor hardware controls on the actual monitor, and if that doesnt work, you have to change the display settings. which you would get to by right clicking your desktop interface, going to properties and display.
Jan 16, 2009 | Acer X193W LCD Monitor
Acer x193w on win xp woulnt go above 800x600 resolution
The resolution issue you are describing sounds like a video card driver issue. You must determine what video card or chipset you have and apply the appropriate driver. The Acer x193w monitor is plug and play, it will display whatever the OS sends to it provided it is within it display range and 1440x900 is definitely within that range.
Dec 16, 2008 | Acer X193W LCD Monitor
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Acer X193W LCD Monitor Logo
166 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
