Question about Peg Perego John Deere Gator HPX Ride on Toy
I know that the battery is good, it is new. I
I know that the battery is good, it is new. I unplugged the battery over the weekend and it wouldn't work after replugging. I had the battery and charger checked by someone in maintanence where I work and both are fine. What could the problem be?
    Problem Solver:
  • 13 Answers
From what you are saying, If you unplugged the battery for the weekend (I assume it ran fine before you unplugged it) and after plugging it back in then it did not run, that is most likely a problem with the connector or even battery. The connectors on these vehicles are always in question. But, I must advise that checking the battery and charger is a problem also. You need to check the battery under a load, a load needs to be put on the battery, you can't reliably check that unless you have a load tester. The charger, well, that is another animal. The best way to easily check the system is to hook up a standard 6 amp 12 volt charger to the battery or terminals of the battery while it is all hooked up to the vehicle and see if it runs then? That will tell you alot of things. If it runs then there is a bad connection, either the battery is dead or the connector is dead. If it does not run then you’re looking at a switch that turns it on or possibly a board, but I don't recommend looking into the board until you eliminate the battery and connection.
The good news is that if you hook up a battery charger to the battery while it is in the vehicle that you will know that it is not the battery. If you jiggle the connector and it runs then you will know it is the connector. If all fails then a connector or board is the problem, but I must tell you that the board is probably not a problem, it is in the battery, connector or both.
Go to www.cammshm.com and find out about this kind of stuff. To my amazement these companies will sell you products that have problems and never recall them. As far as Prego, I don't know but as far as Kid Tax or Safeyt1st or Pacific Cycle Inc. products, they keep selling bad batteries and have been recalled thousands of time of the connector or battery. I have not heard allot of bad things with Prego.
Posted on Jul 29, 2010
I can't get the clock to switch from am to pm
2003 FORD TOURS -SES /OHV -MY WIFE TOOK BATTERY OUT AND LET HER FRIEND BARROW 1T FOR THE WEEKEND THAT I WAS DEER HUNTING ON TUESDAY SHE TELLS ME ALL ABOUT IT AND HOW WHEN SHE WAS PUTTING IT IN SHE DONE BACKWARDS HOW SHE DID THIS I DON'T KNOW NOW BATTERY WILL NOT CHARGE OK GET NEW ALT CHARGE BATTERY SAME THING THIS TIME I GO GET A NEW REBUILD $235.00 SAME-THING NOW I GET A NEW BATTERY $150.00 CHECK FUSSES ALL GOOD YA DONE WRONG OK CAR YOU WIN. ! WEEKEND DEER HUNT HOOD IS UP AND IN A MOCK KILLING OF CAR I LOOK THROUGH SCOPE I SEE A FUSE BOX UNDER THE FUSE BOX . !!! DRUM PLEASE ANSWER IS MAGA FUSE
Dec 10, 2012 | Watches
Car wouldn't crank tried to jump it off wouldn't
First make sure your battery connections are good and clean. If you have a volt meter make sure your battery is at least 11.5 volts. If all other electrical systems seem to work then it probably is the starter. Before you buy a new one take it to Auto Zone and they will test it for free.
Feb 16, 2012 | 1994 Cadillac DeVille
When I try to start my 04 fatboy it clicks but wouldn't start.
This could be your battery, even if it is charged to 12 volts sometimes they go bad and don't have the cranking AMPS needed to fully engage the starter drive. Try another battery you know is good or if you know how to jump it from another battery try that, if the syarter works you know it is the battery
Oct 09, 2011 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
My 2004 yfz 450 wont start i changed my plug changed my stator put fresh gas in it was riding over the weekend then stopped for a break and went to start up wouldn't start
When you have difficulties starting do you get fuel to the cylinder and sparks on the plugs when you pull out the hi tension wire from the engine?
Sep 30, 2011 | 2004 Yamaha YZ 450 F
We have a 2003 dodge caravan and have been having problems with keeping a charge. the alternator has been replaced, so has the battery. several weeks ago I had driven up to 7-11 came out and it would not...
Testing the electrical circuits an componets is the way to find the problem , not guessing . Testing power an grounds . Voltage Drop Testing the Charging System Plus this charging system is computer controlled .Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model , engine size . Under system click on engine , subsystem click charging system .
Mar 30, 2017 | 2003 Dodge Caravan
Water pump and ignitor do not work
took coleman away for weekend wouldn't work. Very dissapointed, was cold would have loved a hot shower. Had charged battery, when I went to start it. It wouldn't go, light come up as battery low tried it on car charger still no luck. Got home and looked up this site told me to try taking filter off pump and putting a long nail inside to turn pump to make sure it wasn't seized. And guess what every thing works well thank god, water temp was dodgy as well but now all good. Thanks to people that do reply to these sites, it has saved me a lot of money and frustration.
May 23, 2011 | Coleman Hot Water On Demand
Im fixing a 2001 pt crusier ive changed altanater the belt surpintine belt and the computer and its still not charging the battery ive had the altanater tested its good its just not getting charge so i...
check the battery. it may not be holding a charge!! at battery with car off it should read at least 13 volts, with it running at battery it should read 14 or a bit higher. have a good day!! check the engine and battery grounds also.
Oct 29, 2010 | 2001 Chrysler PT Cruiser
Peg Perego John Deere Gator HPX Ride on Toy Logo
207 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
