Question about Garmin nuvi 255W GPS Receiver
Can not get past I agree, no response when touching screen.
  • 268 Answers
Did u try reseting the unit?
if yes but still same then pls try to calibarate ur screen.
turn off ur device,
while off, hold the upper-left corner of the screen while turning the power on
leave the power button when its on but continue holding(30 secs) the upper-left corner of the screen untill "Press dot" appears.
thanks
Posted on Jul 30, 2010
  • 6 more comments
  • champdog99 Sep 01, 2010
    once "press dot" appears, then what? As soon as you let go it disappears and reloads but nothing changed. Is there something else I should be doing?
    Okay, I called the company and this does work. Note though, if you have connected it to a power cord from say a camera (because it doesn't come with one other than a car charger) it doesn't provide enough power to the battery and the dot won't stay on long enough to calibrate the screen. You need to plug it into the car. When the dot appears, it actually moves around the screen each time you press it until the screen is calibrated, then it will tell you the calibration is complete and you are then good to go.
    Okay, I called the company and this does work. Note though, if you have connected it to a power cord from say a camera (because it doesn't come with one other than a car charger) it doesn't provide enough power to the battery and the dot won't stay on long enough to calibrate the screen. You need to plug it into the car. When the dot appears, it actually moves around the screen each time you press it until the screen is calibrated, then it will tell you the calibration is complete and you are then good to go. Hope this info is helpful.
    I called the co and this works. Note, if you have connected it to a power cord from say a camera (because it doesn't come with one other than a car charger) it doesn't provide enough power to the battery and the dot won't stay on long enough to calibrate the screen. You need to plug it into the car.
    I called the co and this works. Note, if you have connected it to a power cord from say a camera ( it only comes w/a car charger) it doesn't provide enough power to the battery and the dot won't stay on long enough to calibrate the screen. You need to plug it into the car.
    Sorry, it kept telling me to try again. :)
    Guru:
  • 630 Answers
If this were mine I would be on the horn with the company and demanding a new unit for free.... squeaky wheel gets the grease... its defective!!!
Posted on Aug 16, 2010
I have Nuvi 255W;battery shows full;satellite signal full strength;When I on it no problems; when I touch select'Map' no problem; but when I select any other button the screen goes black; I hope for help;TQ
Posted on Aug 09, 2010
Touch screen is not responsive on LG Spectrum VS920. I performed a a hard factory reset but can't answer the menu questions b/c touch screen won't let me! How can I get through the I am not able to...
Even if you were able to get past the setup, you would still not be able to use the phone. Since you have already performed a factory reset, I would suspect the actual hardware to be faulty. Get it serviced at an authorised service centre
Apr 03, 2014 | LG Vu CU920 Cellular Phone
Go 720 unresponsive when at legal notice screen and when asked if wanting to connect to computer. having screen response problem since last update 2 days ago. does not seem to be a unresponsive screen...
I may not be giving you any regarding knowledge about it but its very true that people are liable to know about the elated aspect of the above query. I surely recommend you to concern any professional regarding your query as I think it will help a lot.
https://www.structuredsettlement-quotes.com/
Nov 18, 2013 | Tomtom GO 720 GPS Receiver
720 screen does not allow " i agree" to be pushed. screen was un responsive after l;ast update. Did complete reset . reloaded new applications. after the screen does respond to menu where you choose...
A lot of people are having the same issue after the update. Since you cant connect it to computer, my best advice is to get it replaced unfortunately.
I get no response when i push i agree on first screen
Then you have to calibrate the screen since it is not responding to touch. To calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen for about 30 seconds until the calibration screen comes appears (white screen with touch dot),
  4. Follow the on screen instructions.
It is an easy fix. The solution above will help you out on that. Another solution is for you to remove the battery and fix it in back. That should also help.
Jan 02, 2011 | Garmin nuvi 255W GPS Receiver
Can not get past the I agree screen...What is the problem nuvi 255W
Can not get past the I agree screen - Agree touch area doesnt seem to be working
Jul 28, 2010 | Garmin nuvi 255W GPS Receiver
Touch screen does not work
1) Ensure that a cartridge is not inserted
2) Hold down the Hint button while turning the unit on
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Mar 22, 2009 | Leapster Learning System
Align screen
ur Touch panel or in other word Digitizer is faulty try getting it replaced it is around 60 or 70 $ , if u dont want to spend money right now and just want to get rid of this screen alignment process just google 'bypass screen alignment ' there is a utility for that just connect ur pda using usb cable and bypass this process but u will not gett correct response when u touch the screen u will get mis aligned response if u want to get rid of this u have to spent money on hardware replacement
Feb 21, 2009 | HTC PPC-6800 Smartphone
Garmin nuvi 255W GPS Receiver Logo
672 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
