The remote for my 65" cinema series toshiba tv sometimes works good and sometimes stops to work for a few days.When that happens programing the remote doesnt do anything.After few days of not working starts to work again.What could be the problem?
  • 6,993 Answers
the problem should be from the remote control. The remote control batteries are failing contact, that's why it works some times and other time stops responding.
Check the back of the remote, remove the battery and check the battery terminal, see if the spring/metal there are not rust. If you see any sign of rust there, use a fat screw driver to scratch the rust part off and also make sure your batteries are very okay.
If you are lucky to find someone that uses that same remote, you can use the person's remote to test your TV and likewise use your remote to test the person's TV.
If the case/problem is otherwise, please let me know.
Good luck.
Posted on Jul 29, 2010
  • mariusz1492 Jul 29, 2010
    The remote is from verizon Fios .It still continues to control the verizon fios box and only stops to control the tv.Than I try the oryginal tv remote to check and it also is not working.After few days it starts to control the tv again while never stops to control the verizon fios box.
  • Walesarumi
    Walesarumi Jul 29, 2010
    this means the problem is not from the remote control, but from the TV's infrared/sensor. Its either the infrared/sensor of the TV is loosing contact or its beginning to become defective. I don't if you can open up the TV and check the remote sensor if its well fixed to the TV board. If its not firm to its position you can solder it.
    Note that TV stores a lot of current, so you will have to wait for a while for it to cool if you want to open the TV.
    Take care.
MY TOSHIBA 65HX83 remote will not operate the TV
You may need to get a universal remote and the programming codes in order to operate everything you'd like to on your tv. I'm guessing the remote you have is newer than the TV?
"Toshiba 65HX81 65 in. Rear Projection Television...65HX83 remote "
Sep 24, 2012 | Toshiba 65HX81 65" Rear Projection...
Toshiba Rear projection 65" cinema series
You need to replace or have the convergennce IC's replaced. This is not a very hard job to do, but will take some soldering skills. Good Luck
Oct 21, 2007 | Toshiba 50A61 50" Rear Projection...
I have a 65 inch toshiba cinema series it's says
if a large rear projection set that just says HD, it likely is HD ready which means it needs a set top box connected to the Colorstream input marked 1080 on the rear of the set--It will only likely be 1080i and not p---owner manual would confirm this.
May 28, 2012 | Toshiba Televison & Video
I have a toshiba cinema series. Tried to put
rabbit ears wont work on any tv anymore,you need a converter box,its all digital now,call your local cable company,they did this a few months back(government).
Oct 25, 2009 | Televison & Video
Toshiba 65H81 Step By Step
Could I get a copy of that manual please? Sometimes my remote works / and sometimes it doesn't. I use other remotes which are programmed for the TV, but it's the receiver eye on the TV which is intermittent. Does anyone know of a fix??
Mar 25, 2008 | Toshiba 65H81 65" Rear Projection...
65 Toshiba picture sides are bowing in.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 21, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba Cinema Series
possible regulator ic. in the power supply.
Nov 20, 2007 | Toshiba 55H70 55" Rear Projection...
Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Oct 06, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
RE: Toshiba 27" Cinema Series
your problem is in the high voltage circuit.change your flyback it has a short.also check around for open diode in the same circuit.good luck
Aug 04, 2007 | Toshiba 27A34 27" TV
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
