Question about Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
How to change light bulb in refrigerator - Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
    President:
  • 1,099 Answers
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Posted on Jul 29, 2010
LG REFRIGERATOR-FREEZER MODEL GR-B207WLQ HOW TO CHANGE LIGHT BULB IN REFRIGERATOR
Just remove the panel of the light bulb present in the
REFRIGERATOR and simply remove the bulb.
May 06, 2017 | LG Refrigerators
The light does not funtion though the bulb is new
Before you change the switch, check the bulb connection, but first unplug it.
Mar 24, 2013 | Daewoo FR-064R Refrigerator With Ice Box
How to change bulb in fridge
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Jul 04, 2011 | Whirlpool Refrigerators
HOW TO CHANGE THE LIGHT BULB IN THE REFRIGERTOR
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 01, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
HOW DO I TAKE OFF LIGHT BULB IN REGRIGERATOR SO I CAN CHANGE IT IT'S NOT UNSCREWING
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
Sep 30, 2010 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Chasnge light for water dispenser
Dispenser
Unplug the refrigerator.
The bulb is located on the dispenser
under the control panel.
Remove the light bulb by turning
it counterclockwise.
Replace the bulb with a bulb of the
same size and wattage.
Plug the refrigerator back in and you are ready to go!
Thanks, Sea Breeze
Apr 25, 2010 | GE Profile Arctica Stainless Steel Top...
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
How to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Jan 01, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
2,720 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
