Question about Toshiba NB205-N210 Netbook
The NB205-NB210 will not power up. When I try to turn it on the power light turns on the fan spins up for about 2 seconds and then it shuts off.
    Problem Solver:
  • 10 Answers
It is a problem with hard ware. could be processor or mother board
Posted on Jul 29, 2010
  • fuckno May 14, 2011
    I too have learned the hard way. Don't waste your money on Toshiba. If they were the only computer manufacturer we'd all still be using paper and pencil.
HP Desktop 550-a114, will not turn on, though there is a green bright light on the motherboard
take a A+ cert course then tell this fib again.?
An LED can glow at 2vdc, tells you nothing!
only that some weak power is present, nothing more...!
learn that in electronics.
it can fail all theses ways.
good
bad.
weak
intermittent.
the PSU tests are covered here, take a volmeter
not some LED on a stick or parts glowing.
got 50 years of on the job doing this, from DC to daylight, from MIL to you name it.
http://pcdied.com/black-screen.html
Apr 15, 2017 | HP Computers & Internet
My netbook fan spin just for a second and then shuts down
Is the netbook functioning otherwise? Fans often spin on startup, then turn off until they are needed.
Feb 05, 2014 | Computers & Internet
I turn on my tower and the fans move and the disk try clicks like it wants to spin then i turn the monitor on and it turns green them orange right away and says entering power save mode waht do i do
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds.
(Count)
Let go of the Power On button.
Do this same procedure two more times. (Or until the Power On LED does not light up anymore)
3) Plug the computer into power. WAIT 1 minute, turn the computer on.
The fans should spin at high speed for a few seconds, then settle down.
Let's see if the computer boots.
Post back in a Comment, and we will go from there.
Regards,
joecoolvette
Feb 26, 2012 | Gateway 702GE PC Desktop
Push power button and the power light turns amber and lights up then shuts off. the light in back of the computer is light green and it starts to turn on then dies
The fact that ity is trying to start and shuts off after ..it seams that it is the CPU fan to blame ...If the fan fails to start the CPU will turn the computer down instantly due to the temperature limit ..(in 1 or 2 sec ) ..
so ...open it up ..and see if the fan is spinning ...on start ..and if it is not ...check the connection with the board or replace it ..
(by the way ..this may also be a CPU failure ..and need another one ) ..
Aug 31, 2011 | Dell Inspiron 518 Desktop Computer
Connect to external power, the indicator light is on. Power switch does not turn the system on. What is the most likely source of the problem? Motherboard?
Try... take the battery out, take the charger out.. hold down the power button for 10 seconds... plug in the battery and the charger, turn on... worth a try - fingers crossed
if not then yeah its possibly the Motherboard or PSU
Aug 24, 2011 | Toshiba NB205-N210 Netbook
I've had Toshiba Netbook NB-205 for a year, and the display won't show. The fan will come on for a like two seconds and then cut off. If I need to replace the fan, then I'm fine with that, but if there's...
Try removing the battery and starting it up with only AC power.
Sometimes it doesn't charge properly and will turn off after a second. Removing the battery will sometimes fix this.
Make sure you are getting charge lights as well. If the AC adapter isn't working anymore, it can cause exactly what you're experiencing.
Please leave feedback if you found this helpful. Thanks.
Mar 18, 2011 | Toshiba NB205-N210 Netbook
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
Lg ru52sz51d will not turn on intermittantly
Check fan if bad set will not turn on ,it will try to come on.Bad Fan.
Nov 12, 2008 | LG RU-52SZ51D 52" Rear Projection...
Toshiba NB205-N210 Netbook Logo
496 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
