Question about Dell Latitude D600 Notebook
Hard Drive swap
Is it feasible to physically remove the hard drives from two separate Dell laptops (same model) and each function normally?
I'm having problems with the older of the two laptops and wish to obtain data off of the older hard drive. Thanks.
    Scholar:
  • 61 Answers
You could purchase a 2.5" hard drive enclosure. These are usually powered purely by the USB cable. This will allow you to recover any data from the old hard drive.
Posted on Apr 24, 2008
Have black screen. Error PXE E53 help
Check the physical connection for your hard drive. Sometimes they get loose. With the computer off and the battery removed, remove he hard drive and then replace it. Try to boot again.
If this fails to help, you may have a hard drive failure and need to replace it.
Feb 17, 2015 | Dell Computers & Internet
My computer says no bootable device
No Boot Device Available - What Does This Mean?Simply put: "No Bootable Device Available" means your computer can't find your hard drive. Aka: Hard Disk or HDD. The hard drive is where data is stored on your computer (files, programs, photos, everything), this includes Windows or whatever operating system you have installed.
Since your computer "can't find" your hard drive (HDD)... it can not boot (start) Windows or other OS...and you are stuck.
Troubleshooting Steps:First, let's see if your computer has any link left to the hard drive. You've already tried pushing F1 (if you are on a Dell), and recieved an "Internal HDD Error".
So, step 1: Press F2 (or whatever the computer suggests) to enter BIOS setup. If F2 doesn't work try the "del", or F10 key. The "esc" key works on some brands, too.
BIOS has different versions, but there should be something labled "Primary Hard Drive" - if it says "none" ... then your computer doesn't even recognize that a Hard Drive is connected. Let's hope my solution works for you.
If under "Primary Hard Drive" it lists any info (name, size, etc)...then skip down to this section for your next step (actually, even if the HDD is showing up in BIOS, you could try my easy fix below...but it is less likely to work.
If under "Primary Hard Drive" it says "none", it could just be a loose connection keep reading:
How I fixed my No Bootable Devices Error on my Dell Laptop:I removed the Hard Drive, then pushed it back in...nice and tight. And TA DA!
All Fixed. Crazy, eh?
If your computer can't find the HDD at all, the problem came without warning, and you are on a Laptop (Dell and HP are known for this)... this would be my first suggestion to try fixing your error.
Opening a computer can void your warranty, but if you are like me: my computers always break after the warranty has expired anyway -- it doesn't matter :P
You must: Unplug the power cable, and remove the battery first before removing the Hard Drive. Remove any thing else plugged into the computer: mouse, USB drives, etc.
Also, you'll want to ground yourself by touching a un-painted metal object (I use a wrench) to ground myself before touching the insides of a computer.
After removing the battery, you should see if you computer model has a way to ground the MotherBoard. On my Dell 610 -- you simply hold the power button down for a 5 seconds after disconnecting the battery to ground the MotherBoard. All Dell laptops work this way, I think.
This guide has photos and steps to disassemble a Dell 610 Laptop (thanks to the author for helping me fix my computer!) -- but my guess is that any Dell Laptop would have similar instructions.
If you have a different computer brand or model simply do a Google search for "disassemble brand /model" -- replacing "brand / model" with your own computers name. For instance if you have a HP Pavillion G6, your search term would be "disassemble HP Pavillion G6". Go through the results and try to find a nice step-by-step guide with photos. Check out my resources below for quick links to common Laptop Disassembly guides.
Remember: you don't have to take apart your whole computer. Just find out how to remove the battery and the hard drive. Be sure to read warnings and suggestions if the guide mentions any.
I don't know if this would work on Desktop computers -- but it may be worth a try.
Why Does Removing and Putting-Back a Hard Drive Fix this Error?Sometimes, the connection to the HDD gets loose -- removing it and putting it back in (push it into the slot firmly to make sure) can fix this issue instantly. Dell laptops seem to be especially associated with this issue.
I also think perhaps removing and re-installing (physically, not software-wise) the hard drive resets things back to normal. Kind of like how if your computer is acting weird, the first step is generally to turn it off and on again.
GeeksToGo.com might be able to guide you through further troubleshooting in BIOS.
Sep 14, 2013 | Acer Aspire 5250-BZ455 -25793
Slow start up with pxe over ipv6 sign
It lost communications with the hard drive. Try physically reconnecting / re-seating the hard drive. Then verify that it is seen in BIOS.
Feb 22, 2013 | Dell Inspiron Computers & Internet
Laptop SATA drive not working
You cannot take a hard drive out of your faulty HP laptop and insert it into any laptop and expect it to run/boot up. When Windows is installed on a laptop, it is configured with device drivers for that particular laptop and it wont work in another laptop with different devices.
Replace the Dell's hard drive back into its laptop and the Dell should function normally.
To recover data off the SATA Hitachi hard drive, connect this hard drive into an USB hard drive adapter and then plug this adapter with the Hitachi hard drive into the USB port of your Dell. The Dell will detect the Hitachi as an external Mass storage device. You can then open the various folders and files to back up your data onto the Dell laptop or USB memory stick.
If you want to, you can use the Hitachi hard disk as an USB external hard drive by installing it into an USB SATA hard drive enclosure.
Jun 04, 2012 | Dell Precision M90 Notebook
How to reconnect harddrive
To reseat the hard drive on a Dell and it depends upon the model.
Most Dell hard drives are in a slot located behind a panel on the side of the laptop near the audio connectors. The hard drive panel/hard drive tray may be held in place with one or two screws. Remove the screw/s then open the laptop lid and pull/slide out the hard drive panel out. The hard drive panel has the drive tray and hard drive is attached to this panel.
Reverse this order to insert/reseat the hard drive back into your laptop.
May 14, 2012 | Dell Computers & Internet
How to find hdd for toshiba satellite laptop 1715xcds
The physical hard drive is normally located on the bottom of the laptop. Normally when your turn the laptop over and let it sit on the lcd screen you will see an icon that has 3 circular discs that house the hard drive. Normally there are only 2 screws on the bottom case to remove the cover. Then you might have no screws or 2 - 4 screws that hold the hard drive in place. Remove them and just lift the hard drive out. Some drive will lift up, others you will have to slide backwards then lift up. There will be a piece of plastic on the drive for you to grab to lift it. If the drive is not on the bottom, then it will be located on the inside under the keyboard which means you will have to remove the keyboard to get to it.
Mar 10, 2012 | Toshiba Satellite 1715XCDS Notebook
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Swap a hard drives on two exactly same laptops?
Yes, swapping the drives would not result in any data loss.
Please proceed with swapping of hard drives.
Jun 03, 2010 | Computers & Internet
1 Solution for "dell inspiron 8600 laptop how
The hard drive is behind the cover where the mic and earphone are located. Turn the laptop over and there is a single screw that secures this cover. Remove the screw then slide the cover and hard drive out. The cover and cradle are attached to the hard drive.
May 08, 2009 | Dell Computers & Internet
Error at start up
Blues, The first thing I would try is to remove and reseat the hard drive. With the laptop oriented with the cover latch towards you the hard drive is on the left of the laptop towards the front end. -Flip the laptop over and locate the hard drive carrier door. -There is one screw holding the drive in place, remove it. - Lift the hard drive door up until you hear a click. -Slide the hard drive out of the computer. -Reinsert the drive and push the hard drive until it is fully seated in the hard drive bay. -Reinstall the retention screw. If that doesn?t work then you either have software corruption problems or hardware failure or both. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 25, 2007 | Dell Latitude C640 Notebook
Dell Latitude D600 Notebook Logo
46 people viewed this question
Alun Cox
