Have a xerox document center 440dc, error code is scanner fault, replaced scanner, scanner powers up for about 30 seconds and then shuts down. Scanner fault error comes back up.
  • 7 more comments
  • microsolutio Jul 29, 2010
    Any other suggestions would be appreciated.
    Would appreciate any other suggestions
    Any other suggestions please
    Other suggestions appreciated
    Should the scanner be shutting down after about 30 seconds
    When went to fault history, getting U8-3 error
    Following the U8-3 error is ITT AGC failure. Still need to know if the scanner should shut down after 30 seconds
  • microsolutio Jul 30, 2010
    Still need to know if the scanner is supposed to shut down 30 seconds into the machine initializing.
  • naipal singh Jun 15, 2013
    hi i have problam in xerox 440 st problam is scanner foult &foult code is u8-3 -iit-aoc failure &u8-3 alsocoming i riplec lamp &csannir pcp mother bord also what problam is same pis ask the solv may problam thans .naipal singh .mobil no .9810996496 india delhi
  • 360 Answers
Hi, the scanner is meant to shut down 30 seconds into the machine initializing.
Take care
Posted on Jul 30, 2010
  • 503 Answers
You can try a reset on the printer using the # and the number 6,holding them down while plugging in the power cord at the back of the printer.if it still does not work then you can try the same with the # and the number 9.If it still does not work,get your printer serviced.
Please post the feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jul 29, 2010
  • 6,826 Answers
Http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=315,E=0000000002217888391,K=9193,Sxi=1,Case=obj(40527)
The above has to do with finding the fault code with CWIS (CentreWare Internet Services).
I think that the printer is a windows 2000 machine.
    President:
  • 567 Answers
Hi the scanner has a problem, try uninstall and reinstall the drivers for the Xerox and see what happens.
  • 9 more comments
    This machine is being used as a stand alone.
  • Hilton Bristol Jul 29, 2010
    is it only the scanner shutting down? or is it the whole system?
    Only the scanner
    Did you see any error code when the scanner shut down?
    scanner fault error
  • First, if the copier is still under warranty, do not attempt to trouble shoot it or they may not cover it under the warranty if you work on it without their technician doing it for you.
  • Step 2Second, do not laugh because if you do, you may one day feel VERY foolish. Turn the copier off, then re-start it. Too many times this is an automatic reset that people fail to try. It seems too easy and it is, so try it before you call a technician who will charge you just to come by your office to turn the copier on and then off.
  • Read the directions that accompanied the copier. Too many times we start using office supplies before we read the directions - if ever. Go to the index and look up the specific problem you are experiencing and try it. Look specifically for paper jams and a reset button inside the copier.
  • Step 4If all else fails, call the company's technician and watch what they do. you may have to perform the same task for the same problem again in the future and it will save you some time and money.
  • i will send another solution for you.
    When tech just went to fault history, getting U8-3 error
    The power connection to your scanner has a problem so the scanner is not getting enough power thats why its tripping.
    Your Xerox copy machine has a variety of internal components used to print documents and any of them may cause serious problems if they stop working correctly or become dirty. Most common problems are a simple matter of replacing the dead part or cleaning off the dusty component that has stopped functioning correctly. Repairing your Xerox copier isn't much of a challenge for the average office worker and only takes a few minutes.
    Cleaning The Paper Release Blade
  • Step 1Power off the Xerox copier and lift open the top control panel. Pull out any paper currently in the paper feed tray.
  • Step 2Lift open the plastic exit cover door underneath the paper feed tray. Tilt the green plastic paper guide unit toward you so the paper release blade is visible.
  • Step 3Dampen a soft cloth with isopropyl alcohol. Wipe down both sides of the paper release blade from left to right. Set the plastic paper guide unit back into place.
  • Close the exit cover piece and push down the top control panel.
  • Replacing Imaging Unit
  • Step 1Turn off the Xerox copier. Pull down either the plastic door at the front or left side of the Xerox copier, depending on where the toner and imaging unit are located on your specific model.
  • Step 2Lift up the plastic latch holding the guide bar in place and push the guide bar down. Grip the edge of the cylindrical, plastic imaging unit and slide it out of the Xerox copier. Discard the old imaging unit.
  • Step 3Pull off the strip on the top edge of the new imaging unit. Slide the imaging unit into the Xerox copier and lift up the guide bar. Push down the plastic locking latch.
    mptying The Waste Tray
  • Step 1Shut down the Xerox copier. Pull down the small plastic waste tray door located on the right side of the copy machine.
  • Step 2Grip the edges of the green plastic waste tray and slide it toward you. Discard the excess ink inside the waste tray and wipe out the inside of the tray with a soft cloth.
  • Step 3Slide the tray back into the Xerox copier and push down until it clicks into place. Close the plastic door and turn on the copier.
  • Those are other information you can look at,
      Master:
    • 497 Answers
    Try going to this link and read and follow the troubleshooting directions carefully. The link is taking you to the Official Xerox Model Support Page:
    http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE
      President:
    • 3,278 Answers
    Hello.
    From FixYa Support:
    Make sure that the cable from the scanner to the machine is not bent/loose.
    If still a problem, select the Machine Status button (3rd on the left) and look for the Fault Clearance Instructions on the Xerox Document Center for assistance to clear the fault.
    Hope this helps.
    • 4 more comments
    • NinaE Jul 29, 2010
      Did you find the "Machine Status" button ???
      What have you tried so far ?
      Just as a point of information, each FixYa expert cannot see the other experts' comments, only your comments.
      Do you know if the scanner is supposed to shut down after 30 seconds. That is what is happening and then the error code comes back up?
      Can you get to the Machine Status button and follow the Fault Clearance Instructions in those 30 seconds ??
      Tech is getting ready to go back out to the job site on a ship. Do you have an answer as to whether or not the scanner should shut down after about 30 seconds?
      The 30 seconds we are talking about is when the machine is initializing. Has not that particular yet, but all the other buttons he has tried this morning said something like control panel not functioning, turn printer off and same thing happens.
    • 4,323 Answers
    Hi
    If you are doing a network scan then please check that there are not many systems accessing the machine simultaneously. Also, try reducing the resolution of the document to be scanned. If scanning from a remote system then try cleaning up the files off the remote server to free up more disk space. Also check the system settings and then scan sheet status, select the default setting from there.
    If this doesn't help then try & reset the power to the machine. Inspect if there are any broken parts around the scanner.
    Please post back for any further assistance. If you are satisfied please do accept the solution.
    Daniel
    Tip
    Disconnecting the Xerox c2424 Document Scanner
    The Xerox c2424 Document Scanner has a very high rate of failure. After very limited use it can generate an error code of 39,012.40 indicating that the document feeder is damaged. Xerox's answer to 99% of the document scanner issues is to replace the unit. But while restarting or cleaning can possibly resolve this issue, it is also possible to just disconnect the scanner and use it independently of the document feeder.
    Xerox documentation however, does not instruct the user how to do this and tech support won't walk you though it. (So, courtesy of Pastor Ray of Indiana) Listed here are the steps to operating the scanner without the document feeder:
    (1) Perform a standard shutdown on the printer.
    (2) Disconnect the Document Feeder from the printer IN THE REAR OF THE PRINTER. You still need the side connector hooked up, the one by the power-on switch, power plug, USB port and all the other goodies.
    (3) Power up the printer.
    (4) It should work. However...
    If for some reason the printer won't copy, then just do what I did in my experimentation:
    (2) Disconnect the Document Feeder from the printer in the rear of the printer.
    (3) Physically remove the Document Feeder, leaving the copy platen visible.
    (4) Power up the printer.
    At this point you should be able to copy stuff.
    (5) Physically reattach the Document Feeder, but DON'T reconnect it!
    You should still be able to copy, scan, etc.
    on Apr 16, 2010 | Xerox C2424 Copier
    What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
    Try this:
    The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
    If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
    Also:
    Based on the problem description provided, we have determined that your printer needs service.
    Please turn your printer off and use one of the methods below to make arrangements for service:
    If using the local service provider website, please perform the following steps:
    1. Enter your zip code in the space provided.
    2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
    3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
    Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
    I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
    When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
    002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
    003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
    003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
    003-754
    003-755 An error occurred in the document scanner. Reset the document, and scan again.
    003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
    003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
    003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
    003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
    003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
    smaller segments.
    003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
    003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
    005-210
    005-275
    005-280
    005-283
    005-284
    005-285
    005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
    Jan 16, 2011 | Xerox Office Equipment & Supplies
    Getting fault error 37,008.44:31508 How
    There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox website for 37,008:44 error code you should Verify the Printer's Power Source and Isolate the Printer.
    Oct 20, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
    Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
    this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
    Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
    Fault 37, 008.44:197329
    There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox support website for 37,008:44 error code you should Verify the Printer's power source and isolate the printer.
    Oct 26, 2009 | Xerox Phaser 8500N Printer
    System error 39,012.40:49875
    If after cycling the power to the machine and this problem still exists you may need to replace the ADF assembly. Here's a video that shows you how
    Jun 26, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
    Scan failure
    Anything with scanning problems on this machine, would require a service call.
    Turning off and wait for at least 30 seconds and powering on the machine "Might" get the machine back to a good "Ready" condition.
    The problem might be a bad scanner motor gear or even curciut board. There might even be some major binding that might knocked out some sensor, giving this condition.
    Most times, a service call needs to be placed with Xerox.
    Mar 13, 2009 | Xerox Document Centre 420 DC Laser Printer
    Errors
    If this is a Xerox 128, I have looked through all the documentation and those are non standard fault codes.
    I would first start by seeing if the scanner was comming on and moving correctly.
    The only other thing you can try is to remove all the covers and disconnect and reconnect plugs, and ribbon cables.
    There is nothing in the documentation or engineering notes to reference any of those error codes.
    Not even eliminating the P and just looking up the individual codes as just numerical codes.
    A non functioning scanner will produce many odd codes not listed in documentation, which is why I am having you start there. Reseating connectors will allow all modules to communicate, which can also produce odd codes.
    Feb 26, 2008 | Xerox WorkCentre PRO 128 Copier
    488 people viewed this question
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
