Question about Yard Machines 24a 452g729 5.5 Hp Chipper Shredder
Can't pull starter, the cord is stuck.
Had the machine running, and stopped for a break. Went to restart, and the pull cord only comes out about 4 inches.
I have the same problem. Did you get any help?
Posted on Aug 01, 2010
My B&S cord will not pull out. It is not stuck. Help
If the recoil starter was pulling free after you took it off, Are you sure the engine isn't seized?
May 11, 2017 | Garden
My Mcculoch TM251 petrol hedge trimmer won't start after I stop the engine.
I would check the oil/ fuel mix ratio as it may be too weak and the engine is starting to seize up
nothing over 50: 1 ratio and most will operate as low as 25:1 ratio
while it is running check to see if it is smoking at the exhaust
if not ,there is not enough oil in the fuel
Oct 22, 2015 | Garden
My blower stops running and cord got stuck
Does it seem to be the cord holding the unit? Try to turn the blower in reverse. Disconnect the spark plug and use a screw driver to reverse the blower., If the starter pawls engaged for some reason and jammed the engine, this should free them. If not, there could be problems inside the engine.
Mar 10, 2015 | Poulan Pro 25cc 2-Cycle Gas Blower...
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
Won't turn on stop running in the middle of room.
Mine did the same thing. The electrical cord is loose where it plugs into the machine. When you pull the vacuum into the room it puts just enough strain on the cord to break the electrical connection. Push the plug on the cord firmly into the vacuum.
Sep 08, 2013 | Eureka 3276AZ Pet Lover Bagless Upright...
My Makita circular power saw works then stops working, then starts again. Why is this happening?
Things to check: With the saw running, safely grab the cord by the boot and pull and twist it around. This is where a break frequently occurs inside the cord and when the saw is held in certain positions the break will either open or close. If the cord's OK, unplug the saw and remove the brush caps and check the brushes. If the brushes are less than 1/4" long or the springs are burnt or broke they won't make good contact with the armature. If the cord & brushes are OK your next recourse is to replace the switch (Makita PN 651172-0).
Jan 22, 2013 | Makita 7 1/4" Circular Saw 5007NB
Toro pull cord won't rewind
You have to open up the starter and reattach the spring that works with the pull cord. A royal PIA.
Sep 16, 2017 | Toro Personal Pace CARB Walk Power Mower
Miele Red Star model S314. Cord reel is stuck. About three feet of cord is out. The rest of cord is jammed inside machine? How do I get to where the cord reel is?
It is actually simple when I tell you, Here we go...
First, open the lid and take the bag, and hepa filter out of the machine.
With a slot screwdriver, pry the hinges of the bag door out a little and take the bag door off.
You should see one screw holding the black black panel, remove that. When that is out, you can pull the black panel off. It will give a little resistance to you, do not be afraid of breaking it, it will come off.
Next you will see 4 or 5 screws down the holes there, remove all of them and the final remaining red piece will come off. When you pull this off, it will have both the cord rewinder and the motor assembly attached to it. It will be heavy becasue of the motor. Before you pull out the cord rewinder, just have a look at it closely and you may be able to just fix it without removing anything else.
good luck with it.
Nov 05, 2010 | Miele Red Star Bagged Canister Vacuum
Yard Machines 24a 452g729 5.5 Hp Chipper Shredder Logo
464 people viewed this question
Top Yard Machines Heavy Machinery Experts
donald boissonneault
Phil Walker
Phil Walker
gerald martin
Level 1 Expert
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
