Question about Cobra 29 LTD CB Radio
Hooking up power and antenna the radio does not squelch and does not pick up signals. Have changed radios and antennas same problem. Appears to transmit, i did calibrate channels, and the switch is in the cb selection.......
    Genius:
  • Cobra Master
  • 1,795 Answers
Recheck all your adjustments
Posted on Feb 15, 2015
Shuttle83
  • 1139 Answers
SOURCE: CB transmission
Hello 64driver,
Make sure the radio is grounded properly and that the SWR is around 1.2:1, 1.3:1 is good but try to get it to 1.2:1. Also take a power output reading while keying the mic. To do this with your power meter put it in-line with the CB and your antenna and key the mic you should get about 4 to 5 watts PEP. If this is the case your unit is putting out the proper power level, if not have the power amplifier checked by a qualified repair shop.
I hope this helps
Shuttle83
Posted on May 14, 2008
informatica
  • 1114 Answers
SOURCE: Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 31, 2008
  • 14 Answers
SOURCE: no antenna lite when transmitting
Antenna light should be a warning indicator for high VSWR..... simple rule of thumb for CB antenna.... the lower the frequency "channel" the longer the antenna length, higher the frequency "channel" the shorter the antenna length. Your vehicle is a ground plane, where you mount the antenna will also affect its operation and tuning. A properly tuned antenna will have lower reflection on the midband channels and gradually rise as you near the upper and lower end of the band. Some base loaded antennas will be noticably narrow in bandwidth, if you have that problem then tune it for the channel you use most!
K40 has always been good for easy tuning and band coverage, center it on the vehicle top for good omni coverage!
PS... always make sure your connectors are secure, a loose shield will ruin your day when adjusting SWR!
Posted on Dec 22, 2008
  • 39 Answers
SOURCE: I installed a browning br-51 cb antenna on my cb radio.
You need to shorten the antenna,adjust the whip all the way down and see what you have and then cut off 1/4" at a time remember this low on 1 high on 40 it needs to be lengthened high on 1 low on 40 it needs to be shortened . I hope this helps and good luck.
Posted on Apr 12, 2009
  • 773 Answers
SOURCE: antenna light comes on when trying to transmit
Its the antenna. it is not tuned correctly for the radio. First, stop transmitting. You can burn out the final transistor. If the antenna light is coming on, that means your SWR is too high,
first. Check to make sure that the antenna coax is securely attached and fastened tightly to both the radio and antenna.
Next inspect the coax. Make sure there is no damage to it. If there is a slice in it, it is kinked really bad, that could be the problem.
Now, if the coax looks good and is connected tightly, now its on to tuning the antenna. Your antenna is either too long or too short. Antenna's usually have a way to adjust this. Most common is where a metal whip sits in a collar. You loosen the collar, and you can move the whip up and down in it. That is how you adjust the length of your antenna. Fiberglas whips usually have an adjustment at the tip that you can adjust usually by screwing it in or out.
Now here is how to check your SWR.
Make sure you are in an open area like a parking lot as structures such as buildings and trees can cause reflection and give you a false reading. Always take an SWR reading with your doors and windows shut as not doing so can also cause a false reading.
Now that you are in an open area, turn on the radio and turn to channel 20. flip the switch located all the way to the left by the signal meter to CAL. Now turn the knob all the way to the right just before the channel selector marked SWR CAL all the way down to the left before you start. Now key the mic without talking into it and turn the SWR CAL knob up until the needle on the meter is all the way to the right to the mark for CAL. its a little upside down triangle with the letters CAL next to it. You want the needle to be on that triangle. Now while still holding the key in, flip the switch all the way to the left next to the signal meter up once to SWR.
The needle should swing back giving you your SWR reading. Ideally you want this reading to be as low as possible, but 1.5 and under is acceptable. If it is higher then 3 and in the RED stop transmitting. Try to do the steps quickly so you can un key as soon as possible to avoid damage to the final resistor if the SWR is higher then 3.
If the reading is 1.5 or under and the ant light is going on, it could be something else. I will go more into this at the end.
Now we have to figure out if the antenna is too long or too short. Here is how to do this.
Turn to channel 1 and repeat the steps to take an SWR reading. Make note of the reading.
Turn to channel 40 and repeat the steps again to take an SWR reading. Not that number.
If the SWR is higher on channel 40 then channel 1, then your antenna is too long and you need to adjust your antenna so it is lower.
If the SWR is higher on channel 1 then on channel 40, then the antenna is too short, and you need to adjust the antenna higher.
If the signal is over 3 on both channels, then there is something wrong with either your coax, antenna or both, and you should replace the coax, and if its still high, the antenna.
If your antenna is too long or too short, make adjustments to correct. Raise or lower the antenna a 1/4 inch at a time. each time taking a measurement to see if it is still to long or too short. You want to try to get the SWR the same on 1 as on 40. And channel 20 will have the lowest reading.
If your SWR reads low, under 1.5, or even a 2, the light should not come on. If you have had the radio worked on at a radio shop, or purchased it from some where that modifies the radio to put out more power before they sell it, then that can cause that light to go on falsely. Purchase an external SWR meter. You can get one off ebay, or from radioshack. Check the SWR with the meter, and if the SWR is still good, then you can do 1 of the following.
1. ignore the light because it is not right.
2. go in the radio and try to adjust VR6 so that the light doesn't go on. Not recommended if you don't know what you are doing.
3. take it to a cb shop and have them adjust VR6 for you.
I would leave it alone.
Most likely your antenna is not tuned properly.
Posted on Apr 29, 2009
Why won't my Realistic Pro 2020 stop scanning
You might have the squelch turned up too high so the broadcast cannot break the squelch open. Here's an instruction manual (with how-to) for your scanner. Seems easy. Also make sure you have a good antenna so you can pick up signals.
http://pdf.textfiles.com/manuals/SCANNERS-F-R/Radio%20Shack_PRO-2020%20VHF-UHF%20Scanner-Reciever_Short%20Manual.pdf
Sep 08, 2015 | Radio Communications
The scanner is a model PRO-2050. It will only do squelching sound on all the channels and will not bring in any messages. I completely emptied the scanner. Then I put channel..1-8 in. yStill hear...
Once you hear the sqelching, than you want to turn it back just till it stops. Make sure you have your scanner antenna all the way up and adjust it, slowly down, till you scanner starts to pick up. Believe it or not, the antenna has alot to do with picking up signals. Plus, you need to have it by a window, to help pick up stronger signals.
Radio shack can make you a copy of all the codes for this scanner. I would contact them, about your problems.
Kind regards!
Sep 13, 2011 | Radio Shack Pro-2052 Scanner
Cb is fine when vehicle is off , but when vehicle is running it feeds motor noise back threw my cb?
There are several things you can do to help limit motor noise interference but first you have to figure out if the noise is coming from the power wire, or the antenna system. Here is how to do that.
  1. Start the car, and turn on the radio.
  2. Trun the squelch off so that you can hear the interference.
  3. Unscrew the antenna coax from the back of the radio.(make sure that you do not key the radio at this point. It is bad to key a radio without an antenna hooked up.)
If the noise goes away when you unplug the coax, the noise is getting in from the antenna system. It's either getting in from bad coax, poorly grounded antenna, or position of antenna. For instance, if its mounted on the back of the truck some times it picks up the fuel pump noise.
If the noise is still there then it is coming in via the power cable. If this is the case then there are a few things you can do.
First. Make sure the radio has a good ground. Next, run the power wire right to the battery. This eliminates most noise. Twisting the power cord helps cancel out some noise. And a knot right at the plug end of the cord also helps. Lastly, if the noise is still bad you can get a power wire ground loop noise canceling unit. This stops most noise.
Sep 08, 2010 | Midland 1001Z 40-Channels Base CB Radio
Excessive static equally on all chanels on cb
You should always connect the CB directly to the battery as the accessory socket is full of noise. You also should choose a better antenna as these small glass mounts cannot hear signals well and magnify local noise. AM (CBs) radios naturally pick up noise as it is the nature of AM signals. Use your squelch to lesson this but too much can knock out you reception.
Feb 14, 2010 | Cobra Radio Communications
Is it my CB antenna or something else
First off, Midland makes a fine radio. Make sure your squelch is turned all the way down to receive distant signals (down meaning counter clockwise). The through the glass antennas are not the best thing in the world. I personally use a 102" whip and a 6" spring on a modified mirror mount. It is installed on the tailgate side of the tool box. The TX and RX is amazing. Wilson and K40 make great antennas also.
Jul 07, 2009 | Midland 1001Z 40-Channels Base CB Radio
Uhf radio cb tranciever
Hello Are You using the correct antenna?,when you turn the squelch down do you hear static sound?, are you using squelch codes? if it is just a CB radio that works on Citizen Band (11 Mts) this radios does not have squelch codes.
Let me know the brand, model of the radio.
Dec 18, 2007 | Radio Communications
Cannot Get Antenna To Pick-Up Signal
If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
Aug 25, 2006 | Delphi Roady XT XM Radio Receiver
Cobra 29 LTD CB Radio Logo
129 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
