Hello,there is problem: Kyocera KM-3035 error code C4200, replaced laser motor, same, how to fix it ? thanks
  • 4,323 Answers
Hi
Error code C4200 means BD steady state problem, laser motor problem or bad main board. There is a problem with the way the wire harness is wired to the laser, please inspect this wiring. Also, check the main charge assembly, door switch on left side of machine (behind finisher)will also cause this. The locating pin gets loose, so the door doesn't latch firmly.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Jul 29, 2010
Hello how do I fix A-4200 problem on my copier Kyocera KM-1620?
C4200 CODE IS FOR A LASER UNIT PROBLEM, IF IT WONT
RESET BY TURNING IT OFF AND ON THE LASER UNIT NEEDS
TO BE REPLACED. EXPENSIVE PART FOR A COPIER THAT OLD.
May 21, 2015 | Kyocera Mita KM-1620 Toner Black...
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
My Kyocera KM-5035 receive error code 4200 in PC printing and in photocopy
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
Dec 10, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
System error C4200 on kyocera 3530 printer
try doing a reset... with the copy screen on press 10871087 then when screen changes enter 906 then press enter then start then enter... if that fixes it run to the store and get you a nice expensive surge protector... if that does not fix it then your main board is fried...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Jun 05, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Copier giving error
Defective Optical Laser Unit or main board. Is it making noise?
If so, it is the laser unit.
And that is more likely than the main board.
Sep 06, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
90 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
