Question about Mitsubishi WD-57731 57" Projection HDTV
A message flashes at the bottom of the screen
Mitsubishi WD-57731. A message flashes at the bottom of the screen saying TV will power down check air flow. TV then goes off, lamp light flashes for a few seconds, i turn the TV back on and this repeats for 3 or 4 times and then it stays on for the rest of the evening. The yellow status light stays on. ???
  • 171 Answers
Tv is overheating.  possible that fan not working or temperature protection circuit faulty.  check fan for excessive dirt first.  could be as simple as cleaning the fan
Posted on Jul 30, 2010
Blinking yellow light on Mitsubishi wd 57731
Based on the service manual:
Blinking yellow= Lamp cover is open.
It could be something else!
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD-57731 57" Projection HDTV
Air flow vent is blocked, tv keeps shutting down, mitsubishi ws-55615, how to fix ?
Mitsubishi's product line includes a wide array of LCD, Flat Panel, and DLP televisions to suit your home entertainment needs. The electronics division has the distinction of inventing the first rear-projection television and selling the very first HDTV in America. Their 400,000 square foot manufacturing facility, located in Irvine, CA, boasts the ability to produce more than 1,000 projection TV's in one day. The company's oft-stated goal of unmatched excellence is driven by their mantra: "Technically, anything is possible." In June, 2008, Mitsubishi introduced a new premium flat panel TV with an integrated 16-speaker sound projector.
Warranty Information
There is in-home service on all big screen models, which have warranties of 30 days for screens and one year for parts and labor. The LCD televisions have a one year warranty on parts and one year on labor with carry-in service. For plasma sets, in-home service is available on all models. There is a one year warranty on parts and one year on labor. The faulty thermal sensor, mentioned in the commmon repairs section, is now covered by an extended 2 year warranty, as is the problem related to the optical engine.
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board.
Jul 26, 2012 | Mitsubishi Televison & Video
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
My mitsubishi wd-65c8 has a flashing green light.. I have replaced the capacitors on the DM board and the same is happening.. what else could be the...
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board. Make sure all bad caps are changed.
Jan 23, 2011 | Mitsubishi WD-65C8 65 in. LCD HDTV
Message that TV is powering down, check air flow for obstruction
Mitsubishi has had some problems with these sets with the lamp cartridge(google the model number and look for how to replace lamp instructions) On some of the lamp cartridges they covered several openings with a fine screen like material---one is narrow and completely blocks up with dust---this will trigger the air flow message--if you get the lamp out and this screen is blocked, carefully clean the dirt off with a brush---if you don't get it soon enough it will kill the lamp----the replacement lamps for these sets use a bigger mesh that does not block with dirt---it blocks because there is a fan the pulls air and dirt into the set to cool the lamp during operation.
NEVER TOUCH THE FRONT GLASS OF THE LAMP WITH YOUR HAND
I do this here for free so if this helps you give me a vote here.
Aug 24, 2009 | Mitsubishi WD-57731 57" Projection HDTV
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd 57731
Thats a lamp abnormality, sound like the two 3300uf caps on the PWB PCB need replacing
Jun 29, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Wd-65731
AIr flow is blocked?.....is this the message you get on screen mitubishi have a problem with what is called the thermal sensor.. the processor says its getting to hot... mitsubishi suggest service center replace this thermal sensor.
Jun 02, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi WD-62526
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-57731 57" Projection HDTV Logo
249 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
