Question about Mtd 22" Yard Machine Push Mower
Idles fast all the time once you start it up...........just started doing this and is only one year old.......
  • 420 Answers
Other than the throttle sticking there may be a couple things:
The idle screw is mal-adjusted.
There is an air leak where the carburetor meets the block.
The governor spring has bound or streched (depending on type) affecting the RPM.
Posted on Jul 29, 2010
  • thenag Sep 26, 2010
    where is the idel screw i cannot for the life of me find it.
Lawnmower is hard to start
could it be that it too is old and needs retired
Dec 13, 2015 | Garden
1988 Suburban with 5.7 TBI runs fine until warms up. Goes to fast idle and when it comes off fast idles won't start back until cools down.
Lets start at the beginning. Is the check engine light on ?
You have an idle air control valve which could be sticking open or shorted to ground. You should be able to unplug it to test. There also could be a gasket or hose that is opening up and causing a huge vac leak.
Aug 06, 2014 | 1988 Chevrolet K1500
Fuel air lock
Could be some internal carb problems. Especially if the carb is original, or if it is a rebuilt off the shelf. The internal parts can get old and stop working, such as the accelerator pump.
Mar 04, 2014 | GMC Sierra Cars & Trucks
Idling problem
stalls.
you stated the bad , but what is the good.
can it be driven? with full power.
your car has no year? and if working engine,? what engine? option
ever get a 60,000 mile tune up this decade? (just old spark plugs do this)
you start the cold engine/
can you keep it running, with a fast right foot action?
starts after 5min, then runs perfect all day???????
my guess, is one more missed tune up.
Feb 23, 2014 | Toyota Quantum Cars & Trucks
My 1994 samurai idles really high when I first crank it, but later slow down. is there anyting I can do to ?
From a cold start my sami idles really fast, but as I drive it and the engine warms up it will idle correctly. Is there a way to make it idle slower from a cold start?
what engine ? 1.3 L
carb or EFI? (94 was first year of efi, and many have been converted this old)
but the answer is the same , that is normal.
on car its a fast ilde cam on the carb.
in EFI its on the software and in the IAC thermal valve.
Mar 29, 2013 | 1994 Suzuki Samurai
My husqvarna 128ld starts and idles fast but only with the choke half on. Give it gas or take the choke off and it dies.
Possibly a fuel starvation issue, incorrect fuel air mix or an air leak within the fuel system
Nov 25, 2011 | Husqvarna Garden
IDLES FAST WHEN STARTED, FOR 5 MINUTES THEN DROPS
It's the choke doing tis job. It reduces the amount of air to the engine to help it start/warm up. As the engine reaches a good operating temp it will drop the RPM's. Some times they do get stuck, so some cleaner wouldn't hurt. Spray it into the throttle body while the engine is running. Also the O2 sensor could be bad.
Apr 12, 2010 | 2001 Suzuki Xl 7
1979 cj replased carb idles tohigh
Even with a rebuilt carb you have to make the adjustments. Check the choke adjustment and set the fast idle. If choke is to tight it will be hard to start and take a long time to idle down. The fast idle sounds like it is high also.
Oct 01, 2009 | 1983 Jeep CJ7
Husqvarna chain saw works great until its shut off then it wont start again
A couple of suggestions:
How old is the gas in the tank? If it has sat for a year in the tank or the can, the gas won't burn as easily because of octane breakdown. Mix in newly bought gas (with oil of course).
Pull the spark plug(s) and check the spark gap referring to your manual. If the gap is too wide, you'll have a hard time starting it.
It's also a good idea to check how dirty your spark plugs are, and clean if necessary.
Depending on the age of the saw, if it's 35 years old or more, you may have to put less 2-cycle oil into your mix. The ratio has changed for all 2 cycle engines if they're approximately 35 years or older. Instead of 30 to 1 it's now 50 to 1.
Sep 21, 2009 | Garden
1999 Ford Escort idle problems
PVC valve is not metering air correctly, it will appear ok shaking it but looses it ability to maintain proper position causing a medium to gross vacuum leak.
Sep 12, 2008 | 1998 Ford Escort
Mtd 22" Yard Machine Push Mower Logo
321 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
