Question about THQ The Lawnmower Man
How to access the carburator in Craftsman 917.377271 rotary lawnmower. It is behind the airfilter panel. I want to clean the carburator.
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
My Craftsman Series 550 Lawnmower was working fine and I decided to check and clean the airfilter and carburetor. When I tried to restart the pull cord is stuck and won't allow me to pull it. I have...
i suggest you pull the housing off for the pull cord and see if it pulling fine if it does see if the brake is of on the motor i would bet the brake is not releasing
Jul 17, 2017 | Craftsman Garden
The lawnmower won t start after pulling the start up cord . changed the spark plug it still won t start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Jun 27, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 6.75hp mrs lawnmower dies out after a few seconds. I've changed the spark plug, added oil and gas, and cleaned the filter. Any other suggestions? I don't know much about lawnmowers or...
You will have check the carburettor. If you cleaned the air filter, the carb.is right under it. Or if you follow the fuel pipe from the fuel tank it will run straight to the carb. Remove the round bowl at the base, it is held on with a small screw at the bottom. Clean this out and blow out the carb. with air. You may have to remove the whole carb. to clean it right. Good luck, Stephen.
Sep 29, 2009 | Craftsman Garden
Why is my 4.0 crafrtsman lawnmower flooding gas into my airfilter
float is sticking in the carb. Pull carb clean holes with paper clip put back together.
Jul 19, 2009 | Craftsman Garden
Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Hi i'm having trouble with oil leaking from some where around the airfilter. I had changed the air filter and cleaned the sparkplug as had not been done in ages and was not running very well airfilter was...
Getting main blackcover off of Craftsman 48 volt electric mower model # 18A-188-799. Push flat head screwdriver thru one of four holes. press slightly down on black cover and pull slightly up. Continue one the other three. You are wanting to push the black part attached to the cover back and away from the white part holding the cover down. Picture shows black cover tab that you will push slightly back. in towards the mower. Also the other part of the plug attached to the lawnmower. Be careful not to stretch the meter wires when removing cover. They unplug from the meter.7d93cc1.jpg8bd0035.jpg
Apr 04, 2009 | Garden
THQ The Lawnmower Man Logo
177 people viewed this question
Top THQ Video Game Consoles & Games Experts
James Wishart
Edward Talavera
Edward Talavera
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
