Question about Whirlpool Washing Machines
Hi I have a Whirlpool Ultimate Care 11. 3954727 It started to play up a couple of months ago, we changed the fuse and all was well, we have put 3 new fuses in in the last few months and the last time the fuse hadn't blown, but the machine won't start, there is current to the plug and to the small fuse in the machine but we cannot get it to start. Any ideas.
gittos73
  • 244 Answers
SOURCE: No power to washing machine but fuse is ok...
could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
Posted on Aug 22, 2007
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
  • 1314 Answers
SOURCE: spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Posted on Dec 30, 2007
  • 84 Answers
SOURCE: washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Posted on Feb 18, 2008
aborcass
  • 2651 Answers
SOURCE: Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Posted on Mar 16, 2008
2004 Yukon XL 1500, with the car off the radio circuit draws alot of current and drains my new battery in 2-3 days. Also maybe seprate issue my oil presure gage does not reset to zero.
With the problem with the battery draining, Get the chargeing system check out, End tell them all so to check for a short, As for the problem with the oil gauge change the oil pressure sending unit,
Nov 26, 2012 | GMC Yukon Cars & Trucks
My whirlpool ultimate care II electric dryer won't
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 21, 2011 | Whirlpool Dryers
I have a Whirlpool Ultimate Care II washing machine, model number: LSQ9110PW3 that stopped working properly two days ago. At first it seemed to not be able to go into the spin cycle. However, I just...
You have one of the best washers ever made... It is called a "Direct Drive" by us technicians. You probably need this part, but NEVER get rid of this machine as NOTHING out there is this good- not for anyprice. https://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Motor-Coupling/285753A/1195967?modelNumber=LSQ9110PW3&ss=a11b5d654521&mr=1
Apr 07, 2017 | Whirlpool Washing Machines
Ultimate Care II washer will not agitate or spin
Your lid switch could be the problem. It has 3 wires: black red which are hot and green which is ground. Unplug that lid switch and check for continuity between black and red with the lid shut. This video shows where the lid switch is located
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 08, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II won't fill up with water
Please provide the exact Model number in your reply.
I realize you indicated you had checked the hoses, but check the filter screen at each end of the hoses, and inside the water inlets of the washing machine. If mineral buildup has broken loose inside the lines, it will plug those screens (My neighbor had a similar problem happen to him a couple of months ago, in a bathroom, where 2 sinks, a shower, and the tub, all clogged due to mineral buildup breaking loose inside the pipe system.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Same whirlpool ultimate care 2 gripe.
sounds like the run winding is out on the motor BTW the whole cabniet comes off the unit so you dont need to put it up on jack stands
May 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Addl Info: Our Whirlpool Ultimate Care II washing maching agitates fine, but will not spin.
The spin tub mounting block is probably stripped on the basket drive. Remove agitator. Now put machine into spin do you see shaft spinning but the tub isnt moving???
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
49 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
