Question about Sony VPL-CX86 Multimedia Projector
Need to reset lamp. replaced lamp and installed new lamp.
Need to reset lamp Installed new lamp and need to reset lamp
  • 10,594 Answers
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Posted on Jul 29, 2010
  • robbk10
    robbk10 Jun 26, 2012
    what do you do if you dont have remote?
  • Kira Weaver
    Kira Weaver Feb 26, 2015
    u die
    President:
  • 261 Answers
Hi
go to the menu (remote control- key -menu)
you can find it
    New Friend:
Toshiba TDP T350 Lamp hour reset
How to Reset a Toshiba Projector Lamp Timer
The lamps used in projectors have a limited lifespan and need replacement after approximately 2000 hours of use. Toshiba projectors have a lamp timer to keep you informed of how many hours your lamp has been used. When the total hours used approaches 2000, the projector displays a warning. Even if you replace the lamp, the warning will appear on the screen until you reset the lamp timer.
Other People Are Reading
Instructions
    • 1 Unplug the power cord from the electrical outlet.
    • 2 Turn the main power switch to the "On" position.
      • Lcd Projector Lamps All Make, Model With 3 Month Warranty India image copier services chennai 09842427600
      Press and hold the "On/Standby," "Menu" and "Input" buttons at the same time. The buttons are on the projector. Though the same buttons are found on the remote control, the reset only works with the buttons on the projector.
    • 4 Plug the power cord back into the outlet while holding the buttons in Step 3. The lamp timer will reset when the projector receives power.
pillurantree
Posted on Mar 19, 2013
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
But use Always some cloth, never touch the lamp with you're sticky fingers!
Posted on Dec 01, 2014
2 Suggested Answers
SOURCE: Installed new lamp but Replace the Lamp prompt still displays.
YOU CAN TRY TAKING THE LAMP OUT AND REINSTALLING IT IF THAT DOES NOT WORK WILL PROBALY NEDD TO GO IN FOR REPAIR
Posted on Oct 16, 2009
Intermittent vertical black lines samsung hlp5067w
even technicians who are familiar with those units, before installing new lamps, they use a 'calibration unit' for that or any particular model lamp and calibrate them right after installation. If you don't have the proper calibrator and adjust them right after you installed them, you will get that result. Even experience techs come across that problem if the calibration is not done properly. Also, each lamp for a different color value, has its own calibration/sync values.
Nov 18, 2013 | Televison & Video
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
I installed the projection lamp with new housing and it still says projection lamp is ending near of life.
you need to reset the lamp timer it is in the tv menu-
check under setup or clocks and timer--it will ask you did you replace the lamp--select yes--youll be all set
Jul 12, 2010 | Sony KDF-E55A20 55 in. LCD Television
Unit not powering up. New lamp installed but
a couple of things did you reset the lamp timer? Sometimes if the panel door lamp is open or not closed you will not be able to power up. Have you tried removing the lamp and reseating it? Perhaps the fuse is blown...you will need to remove the cover and look to see. fuse should be located in the area of where you plug the power cord again you will need to remove the power cord.
Jun 02, 2010 | Runco CL-510LT Multimedia Projector
Need instructions for lamp unit part number TY-LA2004
the projector will not know that u have replaced the lamp!u will have to tell it that a new lamp has been installed
to do this go to the menu & find reset lamp hours option & do a lampo reset.the lamp hours will reset to zero & then the replace lamp message will nt appear!
Jan 28, 2009 | Office Equipment & Supplies
New bulb installed and it takes 10 plus minutes to start
Exchange the lamp under warranty...
You've tried almost everything else.
It's not that uncommon to experience "infancy failure" with a brand new lamp.
If the problem persists with the replacements replacement then I would suspect the Lamp power supply (Ballast) is failing.
Dec 14, 2008 | InFocus ScreenPlay 4805 Multimedia...
Lg tv 52sz8r-tb new lamp installed, red lamp light still on
you need to reset your lamp hours timer. as far as i know this can only be done with the service remote
Dec 12, 2008 | Televison & Video
Sanyo plc se15 no light output
i all,hoping you can help with my problem.Ihave been given a sanyo plc se15 projectoe but with no lamp originally,the "lamp"indicator and "lamp replace indicator"were originally lit but when i have installed a new(23hrs use previously) lamp i have no light output and these 2 indicators are still lit! what voltage should i have on the lamp terminals(i a fully qualified electrician btw) is there some sort of reset procedure as i dont have any instructions etc
thanks in advance for any help
Mar 05, 2008 | Sanyo PLC-SW30 Multimedia Projector
Cannot reset projector after new lamp installed
hi
Have you reset the lamp timer after replacing the lamp, if not then do so and see the user manual for that.
Viren
Jan 24, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Sony VPL-CX86 Multimedia Projector Logo
18,331 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
