Question about Yamaha DSP-A1 Receiver
Have Problem With Yamaha DSP A 1. power does not come on...after repeatedly pressing the on switch it comes on and then works fine ..most of the PSU cold solder prob solved...what could be the possible fault...Diagonostic also shows everything ok.
  • 11,896 Answers
Either the power switch is shorting out, or you could have a faulty or somewhat faulty resistor or capacitor on the power board. You can test them with an anlalog meter. Each component has an imprinted number on it to determine it voltage and ohm rating. That number should match the number on your tester.
Some units also have relays in them. The little square plastic boxes. You can test these with an ohmmeter but you would likely have to pull the circuit board to test the relay from the solder joints on the bottom.
Posted on Jul 29, 2010
Works fine but the fan runs constantly from power on its a yamaha z9
Some systems are just designed like that, especially chinese cheapies. I have an ESC I bought from china and the fan stays on the entire time its turned on, its just to say a few cents not installing a temp sensor and automatic switch.
May 01, 2016 | Audio Players & Recorders
It is getting no sound. What should I check first?
first check it is getting power. does it light up? is there power to the switched AC outlet in back?
May 23, 2014 | Yamaha DSP-A1000 5-Channel Amplifier
YAMAHA DSP A1 WONT SWITCH ON
Popped power supply hi sorry if you can't get it on trying to do a diagnostic won't matter if you can open the back check where the power is going into you will c a power supply board a cap has carrots on it check if any of them is popped up
May 20, 2012 | Yamaha DSP-A1 Receiver
Own a Yamaha DSP-A1000. Center channel "died" this week. Everything had been working for years. Suddenly, the center channel stopped working (very obvious in DSP fields for Home Theater). Any...
If you run through the setup and certify it knows about the center channel first, then test it with tiones, then maybe swap the center speaker with another one you might come to an answer.
May 13, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha Amp DSP A-3090 Power/function/Remote
These issues can only be fixed by an audio-tech.
Do a websearch around your area for a repair person
Sep 30, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
Yamaha DSP-A3090: All video settings trip unit and it turns off
Hi...
Is the first set "stereo" settings and the 2nd set "surround" settings?
If so that may mean that the surround speakers arent all connected right.
Jan 14, 2009 | Yamaha DSP-A3090 7-Channel Amplifier
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
No Sound
Called Onkyo and here is the solution they gave me.
1. Turn on unit.
2. Press and hold VIDEO 1 button.
3. While pressing VIDEO 1, press Speaker A button.
4. You should see "CLEAR" on the display for a second and it will go on stand-by mode.
5. Turn on the unit and check if sound is back.
Hope this helps
Mar 30, 2007 | Onkyo TX-DS575 Receiver
Yamaha DSP-A1 Receiver Logo
179 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
