Question about Aloha Housewares (93645) Ceiling Fan
I have an Aloha Industries ceiling fan and one of the blades broke on it! How can I get just one blade?
Unfortunately you can't buy one blade. Blades are made in sets and have to be balanced within a few grams of each other. If you can find the supplier for this brand there is a small chance you may be able to buy a new set of blades but you will need to know the model as well. Blades aren't interchangeable between brands or models.
Most likely you will need to buy a whole new fan.
Posted on Jul 30, 2010
Aloha breeze ceilinf fan model number 970003 does anyone know to to call 800 295 4448 number does not work
Why don't you get a better fan. You need to look for blade pitch in the fan. The higher the blade pitch,the better the air flow. This fan is worthless if you're looking for airflow.
Aug 01, 2013 | Aloha Housewares (93645) Ceiling Fan
How to assemble a42inch aloha breeze fan with light kit
This fan is a complete waste of money. You need to look for blade pitch( 13degree or higher) To get air flow or you're otherwise you're throwing your money away. YOU GET WHAT YOU PAY FOR!
Apr 05, 2013 | Aloha Housewares (93645) Ceiling Fan
Missing fan blade
Call the factory at 1-800-295-4448, and tell them what happened. They will send you out a new set of blades, and brackets out to you. When they do come, use only the new blades. the reason why is because they are balanced at a tolerance of only a few fractions of a gram. this will keep it from wobbeling.
Jul 11, 2010 | Aloha Housewares (93645) Ceiling Fan
Distance between blades and ceiling?
I'd be more concerned on how much clearance you have between the blades and the floor since you mention a "low" ceiling. The efficiency drops
rapidly as you get too close to the ceiling. You also have to worry about the wobbling of the unit. I wouldn't go less that 8"
May 15, 2010 | Aloha Housewares (93645) Ceiling Fan
My ceiling fan wobbles and I can only use it on the lowest speed.
This problem is most probably due to some irregularity or loss of alignment of the blades. Check the blades to sort out this issue.
Jun 27, 2009 | Encon Industries (78018) Ceiling Fan
The fan will not make a breeze at any speed
There is a switch to make it turn the opposite direction. you will need to flip the switch. Otherwise the fan blades are on upside down.
May 04, 2009 | Aloha Housewares (93645) Ceiling Fan
Ceiling fan chain broke
Motor: XTR-200
Blade Span:
60"
Blade Pitch:
Downrod:
3.5"
Blades: Choice of
Traditional Wicker Black, Tropical Wicker Weather Bronze or Adirondack Reclaimed Antique Blades
Light kit: Optional
Control: Included
W-81 Wet-Rated Wall Control
Aug 16, 2008 | Dryers
Aloha breeze 52 white ceiling fan
Is there something specific you need to know?
Kill power at the breaker for saftey. Mount the bracket to the ceiling first. there should be a small hook on the ceiling bracket that you can hang the fan motor from while you do the wiring.
The blue wire and black wire on the fan should both be connected to the black wire in your house wiring. Attach the fan blades to the motor once it is in place.
Aug 02, 2008 | Aloha Housewares (93645) Ceiling Fan
Broken fan blade
you can goto a habitat for humanity store they would have full or seperate blades or heck even a junker fan here with your blades for cheap or a thrift store but if your looking for correct size blades the most reliable place ive been able to order from is true value store
Jun 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Aloha Housewares (93645) Ceiling Fan Logo
Top Aloha Housewares Dryers Experts
Steve
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
