Question about Roper RAX4233PQ Top Load Washer
My washer leaks when it rinses and spins - Roper RAX4233PQ Top Load Washer
  • Roper Master
  • 8,220 Answers
my washer leaks when it rinses and spins - 27d7fd4.jpg 78d0my washer leaks when it rinses and spins - b182db7.jpgass=b182db7.jpg9da99f8.jpg
Remove the case and defeat the lid switch for testing. Do a load and see if you can tell where the leak is. Most times the pump is the leaker. A very easy fix.
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 29, 2010
vest6
  • 196 Answers
SOURCE: roper ras8445KQO washer
arlenekc : The water pump needs replaced.
malibu66,: Replacing the pump is not difficult at all.
In the above cases, Tilt the machine back so you have access to the bottom. (It there is a soft bottom plate you will have to remove it.) The pump it located on the bottom of the motor and is held on by two clips. Remove the hoses ant then the clips. The pump should slide off the motor shaft. If the pump does not come off then you will have to break it off. DO NOT pry on the motor or shaft. Once the pump is off check the motor shaft for any rust or build-up. This will have to be removed before a new pump is installed.
Line the pump up to the motor shaft to get it in place and put the unit back together then check the operation.
LITTLEGIRL4 Open the lid and find the water flume where the water comes in. This flume gets out of position sometimes. Start filling the machine and watch the flume. If there is water dripping or running down the sides toward the rear then the flume is not in position or has been damaged.
Posted on Jan 12, 2008
vest6
  • 196 Answers
SOURCE: Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
docjohn174
  • 943 Answers
SOURCE: washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Posted on Sep 27, 2008
SOURCE: Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Posted on Aug 18, 2009
SOURCE: maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Posted on Apr 05, 2011
My washer is leaking bad and does not spin all the water out
there may be a blockage in the waste water pump had a similar problem with a beko there was a rubber band wraped around the outlet fan
Jan 23, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
WASHER LEAKING
DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
Jun 23, 2008 | GE WBSR3140DW Top Load Washer
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
WD640 Aquarious supersilent washer/dryer leaking from powder draw
during the rinse the machine uses a higher level of water, therefore check the door seal for holes,if the water is leaking from the soap drawer in the spin then this suggests that you may have a blockage in the outlet hose or in the sump filter, to check the filter remove the sump hose, the filter is hidden in the hose. Regards Engineer
Jul 29, 2007 | Hotpoint Aquarius WD63 Front Load...
Roper RAX4233PQ Top Load Washer Logo
67 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
