Question about GE Refrigerators
GE GSH25JFTA refrigerator has stopped dispensing water. Ice is OK
GE GSH25JFTA refrigerator has stopped dispensing water. Filter has been replaced, but no luck. I'm wondering if the line is frozen as described by ''dleham'' on 12/13/08. In which case -- HOW DO I THAW OUT THE LINE?
    President:
  • 1,891 Answers
Change the tempt of freezer if too cold it will freeze line . try seting it for 5 to 20 deg some run below 0 and will freeze the water .. mm
Posted on Jul 29, 2010
  • dennis dodge Jul 30, 2010
    filter usualy does not stop the water flow but slows it . / mm
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
GE GSH25JFTA BB water dispenser not working but ice cube maker working fine
Ice maker is working. Water dispenser is not working. I did the initial diagnosis and the water line is not frozen. How do I replace the water valve or is that the right next step?
Jan 05, 2012 | GE GSH25JSTSS Stainless Steel Side by Side...
GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Mar 02, 2010 | GE GSH25JFT
Not getting any water out of my dispenser. The light indicator is on but when I push in the dispenser lever no water comes out??? My ice despensor is working fine, Indicator lights are working fine. I...
I have the same problem with the same refrigerator, call up GE Customer Service and tell them that you want part number WR49X10173, a water dispenser heater kit. They should sell it to you for a "discounted" price of $25. Good Luck, and don't ever by GE anything ever again.
Jan 15, 2010 | GE GSH25JFT
Only will dispense crushed ice, no cubes.
Sounds like the piece which lifts up the crush/cube actuator behind the ice bucket . Will have to be replaced with 1 piece (plunger AND actuator ) .
Jul 18, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
670 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
