Question about Zebex ZB 2200AM
I own a Curves and we use the Zebex ZB 2200AM Scanner. We have recently had to buy a new computer and gone from Vista to Windows 7. Everything else was able to be set up through drivers. I do not want to have to buy another scanner when I already have one that is perfectly fine. Is there any way to get a driver?
3 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: I want Zebex ZB-2200AM to
To enable your device to be able to scan both 10 digit and 13 digit ISBNs you have to re adjust the settings. The link below will direct you to where you can download a manual which will help you change the settings.
http://www.barkodokuyucu.com/download/Zebex/eltipi_kitapcik_en.pdf
Hope the solution has been helpful?
Posted on Sep 26, 2010
micromatikal
  • 2777 Answers
Hmmm, I am not certain if this model can handle 13 digit ISBN's, but as long as they are less than 80 mm long I suppose it should. If the barcodes are definitely less than 80 mm's long you will need to fully reprogram the scanner to recognize the 13 digit ISBN's. Do you know who programmed it originally? If you are unfamiliar with how to do this please contact Zebex at (908) 359-2070
I have a primefilm 2700 scanner and I'm looking for drivers for this scanner for windows 7, can you help out?
Scanners are often not supported when a new operating system comes along.
The simplest solution would be to run an old computer with the correct drivers for the scanner, I'm afraid. You can probably get an old computer for around £30.00, which is far cheaper than buying a new film scanner.
Jan 20, 2015 | Office Equipment & Supplies
Recently upgraded from Windows Vista to Windows 7. Where can I get correct drivers to run with my Nikon Super Coolscan slide scanner LS-4000 ED model. I have Nikon Scan 3.0 twain software. Stu Milligan
Hello there.
This will help you if you have 64-bit Windows 7, because officially, there is not windows 7 64 bit driver.
Just read and do everything.
http://www.earthboundlight.com/phototips/coolscan-vista-64.html
Otherwise, if you have windows 7 32bit click here:
link
To check bits, go right click on My Computer, Properties, and you will see it.
Sincerely,
Steve TM
May 28, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
Hi, I have a Canoscan 9900F. I have a problem when installing it on a new Windows 7. Do you have any new driver for my scanner? My name is Joga, I live in Indonesia Thanks
i have the same problem with this scanner
but you cannot do any thing Joga
problem is windows 7
i have both of Windows 7 (64bit) and Visa (32bit)
and use Vista when i want to use scanner
you can buy a new scanner to solve this problem with windows 7!
Drivers only available for Windows XP (32bit) and Vista (32bit):
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_9900f#DriversAndSoftware
Oct 24, 2010 | Canon CanoScan 9900F
My HP Scanjet 6300c Flatbed Scanner does not work
It is not likely that there will be driver support for Windows 7.
That scanner is not even on Microsoft's compatibility list for Windows 7 and is listed as unknown on the compatibility list for Windows Vista
There was no driver support for Windows Vista listed on HP support page as well so it is unlikely HP will develop and Windows 7 driver.
Robert from Blitware
Jun 18, 2010 | HP Scanjet 6300c Flatbed Scanner
Installing the Zebex z-3010
Normally, these scanners need no software, as they simply send a series of digits to the active text box. Try opening notepad or word and scanning any barcode. It should type the number itself.
Apr 14, 2010 | Zebex Z-3080 Handheld
UMAX ASTRA 4100/4600 DRIVER FOR VISTA / WINDOWS 7
I don't know about Windows 7, but I'm using my Astra 4600 on Windows Vista.
Umax said on its website that the Astra series of scanners are not supported for Windows Vista/7. I suppose this is to get us to buy new scanners...
I searched all around the internet for my driver, but couldn't get one. Finally I tried one more time using the CD that came with my scanner. Of course it doesn't work if you run Setup.exe from the CD --- it will just tell you that the OS is not supported. So I went to Device Manager and deleted the scanner under the "unknown USB device" section, and unplugged the scanner.
When I replugged the scanner, I let Vista install the driver automatically. Of course it couldn't, as Microsoft doesn't support it either. Then the install wizard asked me to put in the CD that came with the scanner. And that did the job! Vista was able to ignore the fact that the driver wasn't written specifically for Vista, and the scanner is working!
I hope you have the same luck with yours.
Happy new year.
Feb 04, 2010 | Office Equipment & Supplies
Alpha 70 Series is not working after disconnecting PC and recnctg
Hello Suzanne. The problem you are going to find here is that Zebex doesn't make this model anymore and haven't for some time. If the unit has power and emits a beam, I have the Zebex generic Programming Card and Programming Guide available on my company's website. Have a look at the sections that include the "reset default" barcodes. Print out that page and try scanning them with your scanner. Resetting the scanner to it's default programming may get everything ironed out. If the scanner doesn't have power or emit a beam, then unfortunately you will be looking at getting a replacement scanner. I can recommend several different scanners what would work fantastically and be quite cheap. If you still need help, please feel free send a message or email me. I hope this helps. Good luck!
Dec 28, 2009 | Zebex ZB 2200AM
I've changed computers & need to install to new computer
If you have the install disk for the device just pop it in that computer and run it and it should work.
Dec 10, 2009 | Zebex ZB 2200AM
My scanner scans different numbers to what is on
Firstly, You must be reset scanner.
for reset,
to find programing manual.
if you don't have it.I can send to you.
1. scan start of configuration barcode
2. scan reset barcode
3. scan end of configuration barcode
best regards
Ufuk
Mar 07, 2009 | Zebex ZB 2200AM
Stopped scanning
I seldom do this ...but I will comment on the Zebex scanner. This is ...errr ... not the best choice for future scanner needs. I will never forget commercial Zebex experience. They should have stuck to anti freeze (just kidding).
However if it did work and now doesn't there is one problem that is so obvious no one thinks of it ... check the clear plastic protector on teh front and see if it need cleaned. Greasy environments usually fog it over time.
I have the Zebex default codes somewhere in the shop ... but you can replace that scanner with a nice PSC, Mot, or Intermec for about 120.00 why not do that?
Jan 07, 2008 | Zebex Alpha-70 Handheld
Zebex ZB 2200AM Logo
118 people viewed this question
Top Zebex Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
