Question about Audiovox Televison & Video
I have a magnavox flat screen lcd tv. It says the model number is 26mf23id/37. A few weeks ago the switch that controls the outlet the TV was hooked up to was turned off while the TV was on, and since then it won't stay on or show a picture. The Power light comes on, you'll see the screen flash for a moment and then it will start the process over again. I have the back taken apart, the power board looks fine, nothing popped or burnt. Same with the mainboard. Now on the power board there is a yellow "brick" that has a cylinder shape in the middle of it. I assume it's some sort of coil, but it clicks when the power cord is plugged in. There is no real rythem to it. Also there is a smaller board that leads to the power board via ~16 wires, it has a red light on it that flashes periodically, and immediately if I press the power button.
  • Audiovox Master
  • 8,457 Answers
Now,hook ur tv Air broscasting incommig tv signal.Give it power.Now,tv turn on have picture flashes few sec. than dies just have only sound left?Yes,than the long LCD inverter board is dead.The long LCD inverter board,help the LCD screen to get a baklight to get a picture.Tries websites like shopjimmy.com,Ebay,com to buy a refurbish LCD inverter board for the replacement.
Posted on Jul 29, 2010
TV JUST SHUT OFF
Check power outlet and ensure there is power. If necessary, try the TV on some other power outlet. If it does not switch on, it is better to call in a qualified service technician, as back cover has to be opened.
Aug 16, 2012 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Horizontal lines at the top of the t.v. screen.
you will have to find fault in vertical deflection try condencer replacement in that stage
Jul 11, 2009 | Philips 27PT6441 27" TV
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself sometimes screen goes blank tv unresponsive to remote
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Jul 08, 2009 | SNK Magnavox 42MF438B/27 42 in. LCD TV
High pitched squeal
Hello, This sounds as if it could be a switching power supply problem or a ballast problem. Both will effect your power supply and cause malfunction in various subsystems (audio, screen control, control systems, and the like). I would suggest having a qualified TV repair technician look at the set. This is because there are no user servicable parts associated with this type of problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Philips Magnavox 37" LCD Flat Screen 37MF331D Have replaced power board,main board,hit power a faint light on whole screen for about 2 seconds the nothing.
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Feb 19, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Magnavox 81 cm LCD TV Model No. MLCD32
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Jun 04, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Magnavox 37" LCD HD TV 3 years old
You may need to replace the Small Signal Board of your tv.
Nov 25, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Magnavox 37" widescreen LCD HDTV
If the set has no led light on the front the proble is the power supply. If it has a blinking led please let me know how many times it blink and give me the model number thanks...
Mar 01, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
321 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
