Question about Epson 4880 Stylus Pro InkJet Printer
4880 epson nozzles still clogged - Epson 4880 Stylus Pro InkJet Printer
  • 27 Answers
SOURCE: Epson Nozzle check
hi sandysun,
try to deep cleaning at you nozzle from printer software at printer properties..it should help..
if still the same problem...u printhead got problem...try to take out you print head..put in the hot water..becarefull dont wet the chip near the print head
Posted on Jan 08, 2009
efs_perpends
  • 1996 Answers
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
desertrat144
  • 22 Answers
SOURCE: Epson 4800 clogged
I've had similar fun(?) with my Epson. The best solution that I've found is getting by a drafting (or crafts) supply store and getting a jar of Rapiograph, Koohinor, or drafting pen cleaner. With any kind of luck all you'll need to do is 'flood' the print head a bit (let the solution pool around the cartridge intakes), and set a few minutes, then do the Nozzle check.
The next step if that doesn't get it, is to get an old 'empty' cartridge, add a teaspoon or so to the cartridge, then insert as usual- be quick, as the ink inside has been greatly diluted!
Cycle the printer off & on several times allowing 3-5 minutes between the first & second cycles. What happens during cycling is the printer 'charges' then 'empties' the internal ink tubes; the solution is drawn back and forth, washing out the tubes and jets.
Make sure that your cartridges are 20+% full when using them to print. Epson was one of the bad guys that showed empty ink supplies when they were still full.
Hope this helps.
Posted on Sep 13, 2009
aicaxz
  • 511 Answers
SOURCE: clean clogged nozzles epson rx680
Turn on printer, unplug power chord while carriage moving. Unplug usb. Move carriage by hand freely.
Posted on Feb 02, 2010
SOURCE: I have an Epson 4000 which has a clogged nozzle
I've cleaned the capping station as recommended by R A smart my supplier of sawgrass ArTainium inks but the nozzles are still clogged, this started a few days ago when the yellow started showing showing magenta in it's print out.
I'm at a loss as to what to do next as the print outs are now looking worse.
Posted on Mar 17, 2011
What does "service req. - 00010005" on epson 4880 printer mean?
http://largeformatrepairs.co.uk/errors/epson/sp4880/00010005/
Quoting from the link above:
Service Call Error 00010005 CR Motor Out Of Step During CR Motor operation, there may be a case where the encoder pulse signal within the specified range is not input within a specified period of time or the pulse width is extremely long or short. In such a case, the CR Motor is judged to be out-of-step, so that this message is displayed and the printer stops operating.
This error occurs on the Epson Stylus Pro 4880 large format printer and is not a routine maintenance request.
May 02, 2018 | Epson Office Equipment & Supplies
Maintenance request error code 4000 for Epson stylist pro 4900
HI,
MAINTENANCE REQ - 4000 - It detects twice in a row that all the nozzles are clogging.
Check the video to know how to clean the nozzle to get ride of error 4000
How to clear nozzle clog on your Epson wide format printer from PRO...
www.electro-medical.blogspot.com
Mar 04, 2013 | Epson Office Equipment & Supplies
MNT TK NEAR FULL what should I do replace mnt tk or cleaning the tank?
maintenance tank problem Epson 4880
I have my Epson pro 4880 down for four weeks. The Maintenance tank is rejected by printer. I bought brand new waste tank sensor and chips still says: "NO MNT TNK" it also would let do media setting through Epson LFP remote panel at all. I need help of what may be wrong. please???
Nov 16, 2012 | Epson 4880 Stylus Pro InkJet Printer
Epson 4880 stylus pro service req. 10037
Hello Frank,
i have the same 10037 error code in my machine. On internet is says it is 00010037 Print Head thermistor error. I can not understand the problem and service employee could not solve.
I would really appreciate if you can tell me what was the reason of the problem in your machine how the problem is solved on your side?
Best Regards
Cagr
May 23, 2012 | Office Equipment & Supplies
Epson D88: yellow does not print. Tried head cleaning, nozzle check, & put new cartridge in but no change.
its possible that the yellow nozzles are totally clogged. Its possible that you would need a new printer. See your epson service center, maybe they can replace the nozzles
Jul 23, 2010 | Epson Stylus D88 InkJet Photo Printer
My epson 1400 printer doesn't print
try printing a nozzle check to see if the nozzles are clogged by dried inks that why nothings printing. turn off the printer than press and hold power and paper button together for 3 sec. then release, it will print, if blank, all nozzles are clogged. do a head cleaning. hold the ink button for 3 seconds. wait until the power light stops flashing then print nozzle check again until all lines are complete,
Feb 10, 2010 | Epson Stylus 1400 InkJet Photo Printer
I'm using an iMac G5 with an Epson an Epson RX595 printer. Everything worked well for a long time. Now ... the printer just shoots paper through constantly without printing. I've re-installed the newest...
hi,,
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
click this link to see how to print a nozzle check and run a head cleaning, click the search box and type nozzle check, select "check the print head nozzles"
type head and select "clean the print head nozzles"
http://files.support.epson.com/htmldocs/rx595_/rx595_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Dec 03, 2009 | Epson RX595 Photo All-In-One Printer
Epson 4880 Stylus Pro InkJet Printer Logo
836 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
