Question about Garden
I have a push mower with a Briggs and Stratton 3.5 Classic engine. If I prime the engine, it will start and run until the gasoline with which the engine was primed has burned, then the engine stalls. I have cleaned and gapped the spark plug, replaced the air filter, emptied and refilled the gasoline tank with fresh, unleaded regular gasoline (no ethanol), made sure the carburetor is clean both inside and out, all to no avail. Can you help with this problem, please?
    Brigadier General:
  • 4,088 Answers
Check the plastic screen on the bottom of the fuel pick-up tube for plugging. Check the diaphragm/gasket that joins the carburetor body to the fuel tank--it should be defect free and soft. Make sure the carburetor mounting face is not damaged or warped causing an air leak. Check the impulse line that connects from the valve cover to the carburetor (this is what pumps fresh fuel into the carburetor). Hope this helps!
Posted on Jul 29, 2010
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
I have just purchase a Sears 22 Lawm mower, with a Briggs and Stratton 158cc engine. I prime the motor it act like it wants to start but then dies. I pull it and try to strat it several more times and it...
The procedure for starting an engine is as follows:
  • Check that you have the throttle in the start position and/or on high revs with choke on
  • Prime the engine by pushing the button about 5 times
  • Pull out the cord until you meet resistance. Then let the cord go fully back into the engine and then pull the cord out sharply. Repeat this until the engine starts but not more than a few times.
  • If the engine doesn't start, try pressing the primer button another few times then try to pull start the engine
  • If the engine doesn't start after a few pulls it may have flooded so leave it for a few minutes before pulling the starter rope
Apr 30, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Gas Push Mower - Briggs & Stratton, will start but run for
The jet in the bottom of the carburetor is clogged up. The engine will prime but after that fuel is burned off, the engine stops. The jet is not allowing fuel to be sucked into the engine.
Sep 29, 2009 | Garden
Mower shuts off 3 seconds after priming
Briggs made primers with and without holes in them. In my shop it is common to see them transposed on engines.
Take down the MODEL TYPE CODE numbers and check here to see if yours should have the primer with or without the hole in it.
Click the Parts Lookup box in the center of that page.
Next, drop down the menu on the left to Briggs & Stratton. Set the tab at the top to MODEL.
Next, type in the model number and click search.
From the results page, select your exact type number. Your individual parts views will then be listed on the right side of the page. You'll get the idea!
Hope this helps.
Sep 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
My Yard Machine W/a 6hp B&Sengine will crank & run on starting fl
Most likely you still have a jet inside carburetor that is clogged how did you clean it soak it in carburetor cleaner? Did you take out jets to make sure they are clean
May 05, 2009 | Briggs & Stratton 66set Panzer Tractor...
Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Mar 19, 2009 | Garden
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
