Question about Toshiba 2060 Copier
Got the dreaded "Call Service" symbol
Hi There... I got the "call service" symbol on my Toshiba 2060 copier. The manual suggests that this is a problem with the heater. Is there anything I can do to diagnose the root cause of the problem myself... prior to calling in the experts? Thanks for your help.
  • DefaultITGrl Apr 25, 2008
    I'm out of the office today... but the code I got was for the Thirmister. Not sure what that is........ and if it is a costly fix? Any advice???
  • Toshiba Expert
  • 1,326 Answers
First of all what Error code is being displayed????? Need a place to start from...... It could be one or two or all threethings----- Fixxing thermal fuse, Thirmister, fuser heating lamp...
Posted on Apr 25, 2008
I would like to do a cleaning and preventive maintenance check on my toshiba 2060 copier
call service engineer this is the best way to clean your machine
Aug 21, 2010 | Toshiba 2060 Copier
Toshiba 2060 problem with casette
If the cassette makes a popping noise when first inserted (as it tries to lift paper to feed rollers) then the lift motor drive case is cracked / damaged....one of the gears may be also damaged.
Sep 09, 2009 | Toshiba 2060 Copier
Toshiba 2060 wrench call for service error code
thats a problem with the feeder, when you guys moved the copier you may have knocked it slightly out of place, hence the error code to prevent the machine from a miss-feed and jam.
Jul 07, 2009 | Toshiba 2060 Copier
Toshiba 2060 copier - warmup
No the machine has to warm up to make a copy. It may be in energy saver causing it to have to wake up and come alive . There are ways of changing the energy level settings. By entering the service mode but the toshibas are all number driven menus making it hard to navigate. good luck
Apr 28, 2009 | Toshiba 2060 Copier
The machine shows spanners
If you press the ' clear ' and ' 8 ' button, at a time both has to be pressed continuously then after two to three seconds you can see some code like "c44", "c43", c26, "c01".
the spanner means it is call for service. you have to call a service engineer if the symbol is blinking even though you may clear some of these with the codes.
These spanner blinks then it is saying that some part has gone bad and it need the replacement , service, reset of the code. any one of the three.
Nov 18, 2008 | Toshiba 2060 Copier
Toshiba 2060 Copier access code
The machine is not a printer as well. I don't know how the account was enabled but we don't know what to do. Thanks for your help!
Oct 27, 2008 | Toshiba 2060 Copier
How to change developer on Toshiba 2060 copier?
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on copytechnet.com.  There are Toshiba service technicians on that can help you with that.
Sep 13, 2008 | Toshiba 2060 Copier
Wrench symbol on Toshiba 2060
That means you have a Error code or a problem with the copier. What dose the display show as a code???
Aug 25, 2008 | Toshiba 2060 Copier
Change developer on a toshiba 2060
For that pls contact a trained service engg
You may contact to HCL infosystems Ltd
Address
HCl Infosystems Ltd
261, Okhla Ph-3
New Delhi-20
Ph : 011-26328528-31
Fax : 011-26328532
Jul 09, 2008 | Toshiba 2060 Copier
Toshiba 2060 Paper Jam at the fuser
I would have to say that you are missing the fuser drive. I would remove the fusing unit and look to see if you are missing any gears or any missing teeth from a gear or just missing a gear...
Jun 18, 2008 | Toshiba 2060 Copier
136 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
