Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Where can i get a mojo 15 reconed
My son memphis mojo 15 has it's cone disolved we need it replaced
  • 58 Answers
You'll find out it will cost you way more to rebuild the woofer than to replace it.
Posted on Jul 30, 2010
How do i hook my 2 15" memphis mojo to 1ohm
  1. For that wiring all you have to do is wire all four positives together into one wire. And all four negatives together into another wire then back to the amp check with a meter to make sure you have the right impedance this will only work if your speakers are dual 4 ohm. Otherwise you end up with 2 ohms.
Nov 07, 2014 | Car Audio & Video
Car amplifier just shut off and goes on and off when it wants
Driving the amplifier too hard causes it to go into protect mode to prevent damage. The amp periodically recovers and operates normally until the next overdrive peak hits it.
Apr 21, 2014 | Clarion Car Audio & Video
Repair kit cone recone
Average recone ,dc,atomic,fi.. are around $150
Jan 23, 2014 | Soundstream Tarantula T2-15 Car Speaker
I have damaged the cone on my swa 1801z subwoofer can I get a replacement cone and where ?
  • Yes you can. It is not the easiest of tasks but far cheaper than replacing that 18. There are a few places you can get recone kits from so I will list a few of them and let you decide the quality of kit you wish to purchase.
http://www.speakerrepair.com/ocsrepairprice.html http://reconekits.com/ http://www.simplyspeakers.com/speaker-recone-kits.html
  • Here is a place that will recone all moving parts for you. Of course there is some shipping involved.
http://www.simplyspeakers.com/speaker-reconing.html
Regards, Tony
Apr 25, 2011 | Mackie SWA1801 Subwoofer
REPAIR CONE TEAR IN 18"
If the tear is large, or the speaker cone is brittle because of age, you might be best off having the speaker completely reconed. There are companies that offer the service, or you can buy replacement cones and do it yourself.
For small tears (an inch or so long), you can glue a patch in place. I have used a piece of a paper coffee filter as a patch, and plain white Elmer's glue slightly thinned with water. Put the patch over the tear and use a small brush to spread a thin layer of glue over it. Give it a day to thoroughly dry and you should be set.
I have found this repair to be more effective on smaller speakers than on large woofers, though. The woofer cones are more mechanically active. But I patched a couple of 15-inch cones that had been punctured for a friend, and they are still playing after a year. So it can't hurt to try.
Jan 30, 2011 | Audio Players & Recorders
I have a set of cerwin vega AT15's my dog decided to put his paw through the one surround and puntured the paper cone I need total 15" woofer replacements or repair. or I need replacements I can buy and...
Ebay sell Cerwin Vega Surround (rubber bit) replacements. If he has ripped the cone too, appart from replacing his back legs with wheels (joke!), contact Cerwin Vega directly and they will send you out a new "driver". These are easily fitted at home by any one with a screwdriver
Sep 02, 2010 | Audio Players & Recorders
Hercules XPS 210 sub problem. distorted sound
I think you've just answered your own question. It sounds as if you've coned the sub woofer. Meaning you've fractured the bond between the edge of the speaker body with the speaker cone. Or overheated the voice coil and it's distorted and not getting free movement. Excuse the Pun but it "sounds" like you need a new speaker as a replacement. If it's a particularly expensive speaker it can be reconed. A check of the Net for someone close to you will find a company who recones them. If it's a cheaper one then a replacement would be in order.
Apr 21, 2010 | Audio Players & Recorders
The 6.5 foam ring
This is a very common problem and I don't know why companies still use foam.
The ring is called the "surround" and the problem is known as "surround rot".
There are 3 fixes.
Replace the entire driver. (most expensive)
Recone the driver (tear out the old cone + surround + spider and glue in a new one using the old basket).
Refoam the surround. (replace just the foam surround).
I know of one location in my hometown (Ottawa Ontario, that does re-foaming and people that do this are few and far between).
If you can find someone to refoam it go that route, failing that do a recone. A recone will last just as long as a new driver.
Hope this helps!
Cheers,
Jan 24, 2010 | Audio Players & Recorders
I have a 15'' Yamaha MSR800W powered sub speaker with a torn cone. Can I replace this myself or should I send back to be repaired?
If you have a warranty on it send it back, if you don't you can do several things. It depends on how bad the tear is. If its a small less than 2 in or so tear, a beed of hot melt glue on both sides of the cone is a sturdy but not permanent fix. If its a large tear you'll need a new cone. I looked a bit online for recone kits for that model but i couldn't find anything. So my advice would be to find a speaker service in your area, or send it back to yamaha for repair. If you want you can do a more thourough search for a recone kit, you might find something... hope you get it workin.
Sep 15, 2009 | Yamaha Music
Technics speaker torn
most of the older Japanese speakers must be repaired ratther than replaced if the frame is squared or odd sized. many had a flange making a 15" speaker a 16" size or were square framed so that a round replacement will not work. if it is a standard size round frame speaker, then this is easily replaced. if the tear is only on the center dome or dustcap, then this can be easily replaced. if the actual cone is torn or there is other damage to the moving parts, then the speaker can be reconed. often modifications must be made due to the current availability of standard sized parts vs the original metric, etc, but in the end, the reconed speaker will perform as closely as possible to the original and sometimes better.
cathy@speakerex.com
Jun 25, 2009 | Audio Players & Recorders
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
181 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
