Question about HP Officejet 5610 All-In-One InkJet Printer
I have a problem with the black ink cartuccia. The printer will not use the present black ink even though it worked for a long time and is still full of ink. It is a refilled original black ink. What do I do?
    Problem Solver:
  • 5 Answers
Your printer most likely doesnt take refilled cartuccies
Posted on Aug 02, 2010
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
Is it possible to convert this printer so it only uses black ink and it operates without the color cartridges?
The Photosmart printers work in Thermal Inkjet printing technology. This require all cartridges to be present with ink for printer to work.
You may disable the color printing feature using the printer properties, even though the color cartridge will still be in use.
Only Laser jet printers can work with Black cartridge alone.
Regards
Riztech
If this solution is helpful,kindly vote 'thumbs up' and testimonial.
Dec 31, 2010 | HP Photosmart C7180 All-In-One InkJet...
The black does not print any darker than pale gray even with a brand new dell black ink. What could it be?
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 17, 2010 | Dell 1320c Laser Printer
Color Ink prints fine but Black ink will not print. Have replaced both black in cartridges and Cleaned several times. Have turned off printer and computer after cleaning. Nothing working.
Nov 22, 2010 | Canon Pixma MP500 All-In-One InkJet...
My printer won't complete the cartridge alignment function. It only prints the first two bars and then stops. When printing the black cartridge looks faded and half printed lines across even though it is a...
My printer does the same thing. I changed the blank ink yesterday (the printer shows the black ink was low) however after trying and trying and not being able to complete the alignment I decided to change the color ink as well.
It worked. Printer works fine now. Sometimes the ink dries up and you have to change it even though you know it should last longer.
Give it a try and let me know.
laura@theprincessandthepup.com
Sep 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark E120 black cartridge
In their determination to keep you purchasing their ink whether you like it or not, Lexmark has circuitry built into their ink cartridges that based on measured use tell the printer when the cartridge theoretically should be empty, whether it is or not.
In the case of the black cartridge they are somewhat more lenient than in the case of the color cartridge. Eventually, when the circuitry tells the printer that the black cartridge should be empty it will continue to be refillable, and work, but will present the owner with annoying messages ranging from "you're using an unauthentic cartridge" to other things. The best thing to do in this case is to check the box that pops up telling it not to continue giving you the annoying messages. This works, but eventually may start again, after which you again check the box telling it to stop. It's quite livable though.
In the case of the color cartridge the built in circuitry will eventually tell the printer that the cartridge is empty, even if it's not because you have properly refilled it, and it simply will not function any longer. You've just wasted your ink. Natually they don't want to see you destroy your printer, which costs less than purchasing only two of their 2400% profit ink cartridges. Good luck.
Jun 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a HP 6656A Printer Cartridge that sometimes works good and other times will fail the power on check. Error message varies between Ink Cartridge not compatabile, Check Color Cartridge (even though...
I got hold of another set of 56 and 57 Ink cartridges. By swapping the four of them in and out of two printers, I determined that one of the Black 57 cartridges was bad and caused a missleading error message to pop up saying to check the Color 57 cartridge. I don't know why I was getting different messages at first, but after several swaps in and out of two printers, the error message finally became consistant and I learned that the one Black 56 cartridge was the faulty guy. One Color 57 cartridge printed good but the other (newer one) left streaks on the Cyan and Magenta colors even after soaking the head surface for a few minutes and cleaning it with inkjet cleaner fluid.
The end result is that I have one good Color 57 cartridge and one good Black 56 cartridge which work good in two different printers.
By the way, can you email a labled pinout reference drawing of the hp56, 57 & 58 Ink Cartridges???
Reggie Bostwick
Jul 07, 2008 | HP Office Equipment & Supplies
My HP Photosmart C6180 All in One printer is not printing ing black even though I have replaced the black ink. It will print the colour sections but comes out blank for black. Any suggestions as to what...
Remove the black cartridge from the all-in-one and clean the copper contacts of the cartridge with a soft cotton cloth and then try to align the cartridges once and then try to print the self-test page. Also check the ink level and expiry date present on the cartridge.
May 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Not print and not scann without colour cartridge
most printer require all cartridge to be present and recognised before they will operate- even though you only wish to print -say- text in black. When printing in most machines all colours print even if it is only text you want. Except some machine can have a black only mode This will be found in the properties menu, if your machine has the facility
Jun 06, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
