Question about Averatec 3200 Notebook
I have bought two batteries for this lap top. Both have went dead on me, I properly charge them. But still it goes dead, and I can't use my lap top unless it is plugged into a/c power? Why is this continuing to happen, and what can I do about it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
Your may need to change the AC adaptor you use with this product as the battery does not appear to be the problem.
Posted on Jul 30, 2010
How do I stop my tuch pad om my lap top jumping went powerd by inverter
Power is too noisy. Use the battery and switch the laptop off to charge the battery.
Oct 03, 2014 | HP Pavilion Computers & Internet
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
I left my lap top in my cupboard while I was away for a month. The battery and the computer wer intact and the battery was very much o.k. After coming back and swicthing on my laptop the it was o.k. but...
kindly remove the battery when the laptop is off also remove the power chord ,then remove the battery an clean it with a brush properly ,then re fix the battery again then keep it for charging for three hours then see weather it work if not then its dead ,if u r replacing the battery the please buy the original batter so u will not be in risk in spoiling the laptop always use the original never go for the refurbished one glad to help you fixya team.
Dec 21, 2010 | Acer Computers & Internet
Car won't start. But i know battery is good
you have a red top thats the problem
read the lit on the battery they are not designed for your uses
if you want a battery that can take abuse put in a deep cycle or a reg led acid but the sealed gell cells are not designed for under hood use in the long term look at the charging cycle required on the owners manule it it self is a pain in the ***
Mar 23, 2010 | 2004 Scion xB
Laptop will not turn on without being plugged in.
hi, the problem you are having is going to be either the battery is totally dead you should have got some warning about this on your lap top as the battery's have only a certain life span before they need replacing so this is the most likely cause of your problem.
If its not the battery then you need to start thinking about the wires going to the battery may have come loose this is less likely as the lap top wouldnt come on at all even with power lead as the power goes through the battery.
Get the battery looked at and changed this will then solve your problem.
Let me know how you get on or if you need further assistance ok.
Many thanks for using fixya.com
Please pass this website onto any friends and family members and the experts here would be more than glad to offer any assistance with any tech problems
Nov 18, 2009 | Cell Phones
Battery goes dead
You need to Check out the Alternator.
Jan 17, 2009 | 1995 Ford Thunderbird
Lap top battery dead?
Probably the extreme heat and dryness out there drained it out, and or not being able to recharge it to full capacity. Did you charge it the recommended hours to charge when first used as stated in the manual the battery?. If you have access to a freezer put the battery in a ziploc bag seal and leave in the freezer overnight then take out and charge your battery overnight it might come back to life and hold it's charge once again.
May 04, 2008 | HP Pavilion dv6000z Notebook
Phone dead
I am guessing heat can only come from discharging the battery in a non-intentional way. Short circuit or something internal.
Did you plug it into something besides the connector it came with?
An FM transmitter for the iPod killed mine.
Hard reset, wall charging, USB charge, iTunes restore, replaced the battery ... still dead.
Considering how hot it gets, (could be a fire hazard?) surprised Apple doesn't issue a notice or warning.
Caveat emptor, going back to Motorola.
Mar 13, 2008 | Apple iPhone Smartphone
Charging Problem
Hi, Does the unit run off of the battery? Also, try running the unit without the battery. This tells us several things. Nice unit; I'm working on a similar one now. good luck Harvester3
Aug 18, 2007 | HP nx9110 Notebook
Averatec 3200 Notebook Logo
78 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
