Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
Mobile hung on align screen page despite aligning screen several times. mobile was working fine. suddenly system was hung. tried to hard format using call and end button on start up page. ever since the mobile is hung on that page. even though I have aligned the screen several times. the problem persists. i am given to understand that i need to flash my mobile. is it true. if it is so, how can my mobile be flashed. is there any software that i need to download
  • 944 Answers
Please try this with windows XP
Make sure you:
Turned off any Firewall you have on the PC.
Not running the update in Safe Mode.
Not to perform any other work on your PC.
Make sure the phone is fully charged (important)
Do not update from a PC where you have limited rights. Eg. Internet Cafe, Work etc.
Prefer Laptop as if you have electricity dropped you will have some extra battery and wont harm your phone.
Use only one USB port for you Omnia update, the best one it works for you. Do not try multiple.
Steps used for updating under Windows XP (32 bit).
  1. Make the Install Microsoft ActiveSync 4.5 (once)
  2. Make Install the Samsung Modem Driver XP (once)
  3. http://rapidshare.com/files/179674742/MODEM_DRIVER_FOR_XP.zip
  4. Reboot the PC.
  5. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
    Leave the phone connected for about 10-15 minutes. If it disconnects by itself most probably you have to repeat the procedure from 1st step.
    It is advised to reboot your PC also.
  6. Make sure that have backup all your important stuff (contacts, pictures etc).
  7. Switch OFF the phone by holding the Power button for ~5 seconds.
  8. Run the updater. (Works the same way for Original or Cooked ROMs)
  9. Switch ON the phone again by holding the Power button.
  10. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  11. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  12. Disconnect your phone.
  13. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  14. Enjoy the new firmware.
This is for windows 7 and vista
Things you'll need on Vista:
VMware Workstation (latest will work)
Microsoft Windows XP CD or .ISO image and the serial key
2gb of free disk spaceSafety Tips before starting:
Use the ones that mentioned for Windows XP.
Make sure you turn off the USB on the Windows Mobile Device
Center.How-to disable it. Go to Windows Mobile Device Center:
Mobile Settings -> Connection Settings -> Untick "Allow USB Connections".
After flashing tick it back.Let's start:
  • First install VMware's Workstation. You can get a trial version at http://www.vmware.com/
  • If you have an .ISO image of your Windows XP CD on your hard disk like I do, you won't need the CD, otherwise you'll need it. If you don't have the image, put the CD into your CD/DVD-ROM.
  • Run the workstation.
  • Go to FILE -> NEW -> VIRTUAL MACHINE and choose TYPICAL. On the next tab select the source from where you want to install a virtual Windows XP operating system (CD or image).
  • On the next tab, press next. When the dialog appears, choose YES.
  • Now enter a name for your virtual XP machine and choose a location where you want to save the machine - it's good to have at least 2gb of free space!
  • On the nex tab, I've chosen 2.5gb. I think that's enough, if you wish only to flash your ROM. You can choose to install the machine to a single file or splitted. I've chosen single.
  • On the next tab, click Customize Hardware button and select "USB Controller". Make sure High-Speed USB 2.0 and Auto connect USB devices are checked. Press OK, then press FINISH.
  • Maybe you'll get a warning from VMware but don't bother, just skip it.
  • The Windows installation process should follow. The installation took on my PC for about 25min.
  • When the setup has finished, you can normally run and use Windows XP via WMware.
  • Update your XP machine via Windows Update, reboot and start flashing.
Flashing:
  3. Reboot the PC.
  4. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
  5. Make sure that have backup all your important stuff (contacts, pictures etc).
  6. Switch OFF the phone by holding the Power button for ~5 seconds.
  7. Run the updater. (Works the same way for Original or Cooked ROMs)
  8. Switch ON the phone again by holding the Power button.
  9. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  10. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  11. Disconnect your phone.
  12. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  13. Enjoy the new firmware.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Jul 29, 2010
I am using imate jama101 mobile. the mobile was hanged screen mode aligned screen its not changing from the aligned screen mode i had restarted the mobile but still its not working
HARD RESET
1) Start->Settings->System tab->Master Clear->1234->ok
2)Press soft-reset for 15sec.
3)Remove the battery, Simultaneously hold volume(-) button and red hangup button, while still holding those keys, insert the battery and wait for the led to go out, release keys and device will hard reset
3rd option really worked for me
Jun 26, 2010 | i-mate Jama 101 Smartphone
Hi iam is very critical situation my mobile is not working because this has align screen problem how to rectify this problem please give a help
what exactly is the problem..
the align screen message keeps showing up..
try hard reset?
or..
the screen is not in aligned properly?
start/setting/system/screen
Jul 11, 2009 | HTC P3300 Smartphone
Screen alignment could not be done
I accidentally click on something and my screen alignment for my HTC mobile phone has run significantly... When I tried to align the screen from the setting, it only write that tap firmly and accurately on the target. the target will continue to move until the screen is aligned. Till now, i tried many times but the alignment is still out
Mar 25, 2009 | HTC Touch HD Smartphone
When I change the black ink cartridge, the alignment page and instruction page are printing out fine. When I place the alignment page on the glass as instructed and press 'ENTER', the printer gives a...
I just had the same issue (align page not detected).
We had just re-installed the empty color cartridge back into the printer (long story but basically we knew we could only print B/W).
The align page printout had a lot of empty spaces around the black lines. This is apparently where the color lines are supposed to print.
Without those color lines, the printer would not detect the align page as color is part of the alignment being done.
Since we only wanted black printouts, I pressed 'cancel' to stop the alignment process, and now we just hit the Black copy button and ignore the alignment prompt on the printer window.
The HP site (enter psc750 in product window) has some helpful ideas as to what the problem might also be. It could be the shipping tape is still on the new cartridge (and preventing the black or color from printing on the align sheets) etc.
Mar 20, 2009 | HP PSC 750 All-In-One InkJet Printer
Jas jam screen can't align
tap the screen with thumbs very lightly,sounds funny but it worked. then use a stylist after wing recognizes the taps
Jun 10, 2008 | T-Mobile Wing™ Smartphone
Stuck On Align Screen
This happened to me also. Drain the battery completeley and then do it again. You may have to do it a couple times but it will finally take.
Mar 20, 2008 | T-Mobile MDA
Cant git pass the align screen on my hp2215 ipack
Have you tried a Hard Reset?
This should get you through it but you will lose all of your info.
Information is here:
http://www.coldreset.com/modules.php?name=News&file=article&sid=713
Hope That Helps!
Dec 01, 2007 | Compaq MS Pocket PC 2002
IiMate - Start the system
go to a mobile doctor & tell ur problem to him/her . i-mate itself is a sensetive cell. it has lots of RAM in it but dont worry it will be done
Jun 25, 2007 | i-mate JAM Pocket PC
Well, this is just stupide
John, here, at Dell headquarters. A few suggestions that may help: First, make sure the printer is not plugged into the front USB ports on the system. Sounds strange, but that sometimes makes a difference. Second, unplug the printer, restart the system, then plug the printer into a different USB port. That may fix the problem as well. Third, uninstall and reinstall the printer software. That could also do the trick. If none of these suggestions work, I'd recommend calling our tech support.
Apr 16, 2007 | Dell 924 All-in-One InkJet Printer
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
514 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
