Question about HP DeskJet 5550 InkJet Printer
Replace black toner and clean diffuser need instructions for cleaning the diffuser
  • 1126 Answers
SOURCE: Have just placed new toner cartridge., prints have black stripes
Try cleaning the charger wire on top of the toner/drum unit. It should have a green plastic knob/handle to slide the cleaner left to right and back. Do this several times.
Posted on Sep 29, 2009
Testimonial: "Thank you many times over for your help. Before seeking your advice I wasted about 25 sheets and time trying to remove excess toner marks 10/10"
freetek
  • 5568 Answers
SOURCE: black streaks
This is caused by a rotating part that is contaminated, most likely the drum that transfers the toner to paper.
A new drum or drum cartridge is probably needed.
There is a very remote chance that the high voltage that charges the drum is being modulated but I have seen this once in decades of service.
Posted on Aug 15, 2008
leroyal
  • 2120 Answers
SOURCE: I have a faint print image in the blank area of my paper.
Probably a bad toner cartridge cleaning blade.
Posted on Dec 28, 2008
EmmettPinger
  • 63 Answers
SOURCE: Unable to Print error
try resetting the print jobs from your computer printer que and also resetting all jobs from the printer side also good luck
Posted on May 01, 2009
  • 3 Answers
SOURCE: Dell3100cn Replace black toner
I had the same problem. My solution was to replace the black developer unit. It works fine now!
Posted on Jul 09, 2009
Black tinting or scumming on pages
HP has a cleaning page that can be created to help remove toner build up on the fuser roller and I believe one for the drum also. Print "Menu Map" to find the cleaning page quickly. These are the two areas that need to be cleaned to help eliminate the "scumming". I would also look inside the device after removing the print/toner cartridge and if you have the toner wipes, remove any toner spillage inside. please do not use paper towels as they shred too easily and will mess up the transfer roller.
Apr 05, 2016 | HP Laserjet CM 1312NFI Color Printer
New toner loaded but shows load toner mssage Toner execution failed
here are some tips for you to check on:
1/ check your copy counter,if it is already 120,000 copies and you have not yet replace the OPC unit then you should.........
2/ the toner holder bottle unit is not working properly,need to be checked and cleaned...some time the safety cap is not open for toner to be feeded to the OPC unit.........
3/be sure that you follow the instruction of how to install the toner bottle,
4/if the problem is still there??? your toner motor needs to be replaced......
enjoy the experence!!!!!!!!!!
Nov 03, 2010 | Ricoh Aficio MP 1600L Black and White...
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Drum is black afico 450
You need a new drum CLEANING BLADE
Sep 06, 2009 | Ricoh Aficio 450 Copier
Printing black line when coping
You may need to replace the toner cartridge or the fuser assembly.
If you open the toner cartridge door and see a black line on the roller, you will need to replace the cartridge.
Aug 07, 2009 | HP LaserJet 3050 All-In-One Printer
OKI Laser Printer C5300 printing on paper with black flecks
IF you are using after market black toner then we found your problem. Putting a real toner on now wont help cause dodgy toner is now in the drum, you need to replace Black drum and use real toner. If you are using gen OKI toner, then just replace the Black (K) drum.
Clean led head and these printers dont need a teco, they are designed for wearing parts to replaced by operator ie Transfer belt, fuser, drums and toners.
Nov 20, 2008 | OKI C5100n Laser Printer
Oct 26, 2008 | Dell 3100cn Laser Printer
Printed pages look dirty
That black dust that fell out is the toner. When you shake a toner cartridge that shouldn't happen. It looks like you have a faulty toner cartidge and that need to be replaced! Now to make your printer prints cleanly and clearly after you replace the cartridge, you'll need to get someone to service the printer(the faulty toner cartridge more than likely spilled toner on your internal printer parts, cause the smudges). Sevicing would mainly entail, taking down the printer and removing any spilt toner! If you feel you are up to this, be cautious, because toner can be hazardous to your health if you accidentally breathe it in! hope this was helpful! regards babb
May 10, 2007 | Brother MFC-7820N Laser Printer
HP DeskJet 5550 InkJet Printer Logo
111 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
