Question about Toshiba 50H13 50" Rear Projection Television
My TV repairman needs a schmatic for my Toshiba Model 57H81 TV, Serial No. 57022893, Chasie #TAC0154. We purchased the TV at Best Buy in Erie,PA, but we now live in Costa Rica. I was fortunate to fine a TV repair person, but he says he needs the schmatic. I assume I write to Toshiba, but I'm not sure of their address of if they have an email address I can write to request the Schmatc. Thanks!
  • Toshiba Master
  • 8,457 Answers
First of all ur tv is out dated.Any experience Tech. DLP,Plasma or LCD big screen tvs,should now how to fix ur tv or an idea,what wrong with it.No tvs schamatics for any tvs model's will be release to any non tv shops or people dosen't have any relation with the tvs Corporations manufactures. Give me the problems,cause to the tv,when the power is on to the tv?Might help u find the cause of the problems and those websites,selling refurbishes PCB boards for the replacement.
Posted on Jul 29, 2010
What's your problem?40-42 inch Theater View Toshiba TV, Date on TV is June 1999. Picture slowly started shrinking from up and down. Model no. TZ50V51 Serial no. 77988872 chasis no. 9951
you're experiencing a vertical deflection issue and will most likely need to replace the deflection board. You can get a deflection board for your model from www.tvrepairworld.com
Oct 18, 2011 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 Blinking power light
Greetings,
Power supply cannot sustain / provide juice to the whole system.
If you are qualified to do electronics, check the power supply section, otherwise contact a repairman.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 29, 2008 | Toshiba 57H81 57" Rear Projection...
57H81 57 in. Rear Projection Television: My Toshiba model 57h81 is 5+ years old. It just s...
I had the same issue with my 57 in. Mitsubishi. I fixed it by buying a new projection bulb. The Mitsubishi manual indicated this was the fix for my Mitsubishi TV. Be advised that new projection bulbs are not inexpensive. My TV works like new once the projection bulb was replaced.
May 03, 2010 | Televison & Video
Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Dec 02, 2009 | Toshiba 57H81 57" Rear Projection...
Needs a new light engine for toshiba 62hm195
A new light engine for any DLP TV ranges from $800 to $1200. I would advise not to repair. Cut your loses. Buy an extended warranty with any new TV. It will pay for itself.
Jul 14, 2009 | Toshiba 57H81 57" Rear Projection...
Blinking power light & black screen on toshiba 57h81
This TV could have one of several problems including but not limited to; convergence IC's,bad capacitors, shorted horizontal output transistor. Call a good TV Tech. Check with the BBB before you decide on one.
Jul 11, 2009 | Toshiba 57H81 57" Rear Projection...
My Toshiba 50in screen TV, screen is broken. Could I get this fixed..
Can't be fixed has to be replaced. Check your local tv repairman & see if he has some spare screens. Can be cut to fit
Apr 08, 2009 | Toshiba 57H81 57" Rear Projection...
Help! Toshiba 51H84..Power light flashing, tv picture won't come on!
You need a new HV transformer. Usually you can just buy the transformer itself. It's a little black tower on the backside of the tv. If it's not that, it's the convergence ic's. There's two of them, given it's a toshiba, the part number is more than likely stk392-110.
Sep 07, 2008 | Toshiba 57H81 57" Rear Projection...
Main board price and part number
You can sent it to a compy called pts to have it rebuilt. much cheaper . whats wrong with the tv that you need a main board?
Apr 10, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81Problems Please Help
On this model I've found the hyper module to cause lines (Left to right) in the picture. Usually at start up and half the screen, then after warm up, the set will clear up some or completely. Of course a picture of the problem would help in diagnostics. The hyper module must be soldered in, so, knowledge of soldering is advised. This PCB can be bought at: Andrews Electroncis or Tritronics. I do this job in the home, pick up for service should not be required.
Jan 06, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 50H13 50" Rear Projection Television Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
