Question about Acer Aspire One PC Notebook
Computer turns on but windows does not load after the page that says acer press f2 for setup screen goes black and lights stop flashing. Tried to start in safe mode still wont go just comes to screen that saids mulit¨(0) disk(0)rddisk(0)partition(2)/windows/system32/ntoskrnl.exe it has 6 lines with stuff like that. just stays there
    Scholar:
  • 50 Answers
Well in the start up process this is really what happen the first couple second of the computer starting up...
the first couple seconds after hitting the power button it does a hardware check..
All hardware passed it proceeds to the software check the drivers and stuff...
if the computer comes to a black screen after start up, or any weird writings, then basically some hardware didn't pass the test and failed causing the start up to fail...
If thats the case i would recommend taking it into a local repair store or calling manufacturer if still under the standard 1 year warranty...
nothing to lose, but a welcome screen to gain, give it a shot...
Posted on Jul 30, 2010
Black screen flashing dash top left corner. ....wont reboot after system restore
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Apr 03, 2012 | Computers & Internet
I have an Acer aspire one netbook. As soon as i turn it on, it shows the first screen that is black with ACER on it, but it just freezes there. I can't access the computer unless i press F2 and exit setup....
Looks like there is something wrong with the registry database of your computer. Best way to fix is to clean Windows registry using some reliable software such as Reginout and start your computer normally. Also do the following.
> Limit your startup programs
> Uninstall unwanted programs
> Disable background running services
Thanks
Dec 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
My sister has an acer aspire 4720z and it will not boot anymore. when i turn it on it will show acer logo for a second and then the screen is black with only a curser flashing in the upper left hand corner...
the windows operating system is corrupt, you need to get a technican to repair the OS or lets chat so that i can give you step by step how to go about it.
Oct 18, 2010 | Acer Aspire 4720 Notebook
MY ACER 5610Z LAPTOP STARTS UP BUT WONT LOAD WINDOWS
WIth the limited fault description its a guess at best. you probably have a corrupted driver or hard disk fault. If you can try a replacement hard drive and reload OS you should get progress.
Sep 29, 2009 | Acer Aspire 5610-4648 Notebook
Black screen and windows won't load
It's possible that Windows got corrupted if you can enter the Setup page. Will you also try to boot up on Safe by pressing F8 during boot up. If Windows loads up on Safe mode, you may try System restore. If not, run a repair using the recovery disc of windows so you can recover all your files. If none of these resolved the issue, you have to do clean installation using the CD.
Jun 19, 2009 | Acer Aspire 5610-4648 Notebook
Blank Black Screen After Windows XP Loading Page
the easiest solution would be to re-install windows and hope it is not a hardware problem
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Blank screen
Have you tried starting in the 'Safe Mode?'
If not, either F5 or F8 (right after anything  appears on the screen) will bring up a short menu to allow you to choose the boot mode; choose the Safe Mode. This loads only the most basic windows files and will let you do some fundamental checking of the hard drive and Win installation.
If you can get that far, Click on 'Start,' then 'Run' and enter 'rstrui' and OK. This should start the Restore routine.
If it does, choose 'Restore to an earlier date.' Hopefully you have had Restore turned on and then you will have a calendar with light and bold dates. Choose a date a few days in the past and let it run.
This may or may not put you back in operation.
Jan 11, 2009 | Acer Aspire 5315 Notebook
My Acer Aspire 3000 has a blank screen
I suggest you check the settings of your bios. Normally this happens if your Hard drive is unreadable. Change the settings of the boot function to first boot on Hard disk and try to disable all other bootable hardwares like CD or network card.
Hope this helps.
Apr 22, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire One  PC Notebook Logo
223 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
