Question about Canon Rebel XT / EOS 350D Digital Camera
3rd party flash trigger on my qtb-7500a
Can i use 3rd party or non-canon flash trigger on my qtb-7500a with canon mount so I can use it off cam?
  • 94 Answers
It should work try out
Posted on Aug 08, 2010
  • 48 Answers
I bought Canon EOS d700. I have a Quantaray QTB-9500A with AF Module NK with my NIKON D90 . is this flash works with Canon EOS d700?
It will work, but not all functions will be availale. You can buy a Canon module for the flash.
Jul 11, 2017 | Canon Cameras
I have a quantaray qtb-7500a for an older n80 nikon but i want to use it with my d90 it has a af module nk
The QTB 7500A will work with the D90. However, you will not be able to use the iTTL mode of the D90. Use it exactly the same way you've been using it with the N80, letting the flash control the exposure.
May 10, 2011 | Quantaray QTB-7500 for Nikon TTL Flash
I have a quantaray qtb-7500a speedlight. It is for a Minolta camera. Is there any way to adapt it to fit Nikon equipment? jim
There are modules available to convert the camera into a Nikon lens. Right below your fill flash on the left hand side of the unit, there is a square button to release your current module and attach the new Nikon module.
May 20, 2010 | Quantaray QTB-7500 for Nikon TTL Flash
Will my qtb-9500a work on hotshoe of canon digital rebel 350
Yes. The trigger voltage is typically less than 5v so it is safe to use.
See here for further info.
Please remember to rate my answer.
Dec 26, 2009 | Quantaray QTB-9500A TTL Flash
How can I get the Quantaray QTB-9500A to work with the Canon rebel XT? It worked fine with my ellanIIE. Can I order a new module? Thank you for the help
You'll need the "AF module CN", but as the flash is no longer made will have trouble finding one.
It helps if you search for the correct flash model as Quantaray is a no-name bit of badge engineering for Ritz/Wolf.
Your flash is really a ProMaster FTD5700.
Please don't forget to rate my answer.
Sep 25, 2009 | Quantaray QTB-9500A TTL Flash
My Quantaray QTB 7500A will not turn on. Placed
Make sure your batteries are inserted properly (+/-) Slide the battery cap on and off several times to make sure you have good contact.
Aug 31, 2009 | Quantaray QTB-7500 for Nikon TTL Flash
Quantaray QTB-9500A with Canon Xsi not working properly
This is probably way too late for the original asker, but the previous answer is incorrect.
The Quantaray QTB-9500A is in reality a ProMaster FTD-5700 and was designed for use with later model electronic 35mm AF models (using the correct dedication module).
As such, the trigger voltage is no higher than 5v making it safe for use on later digital SLR's.
The original answerer is clearly aware that high trigger voltages on flashes designed for earlier, mostly mechanical, 35mm film cameras are often harmful to later models, but you need not worry about your model.
Please take a moment to rate my answer.
Aug 30, 2009 | Quantaray QTB-9500A TTL Flash
Quantaray QDC-NK i TTL Digital Flash Module
The Quantaray Digital NK Module has a small tab on the side of the raised boss that the 8 pins sit on that prevents it from mounting on the QTB-9500A. It's intentional- the NK Digital Module is made for newer Quantaray flashes only. You'll need the older-style AF NK Module to attach to the QTB-9500A.
Apr 06, 2009 | Quantaray QDC-NK i TTL Digital Flash...
Replacement bracket for qtb-7500a
Never seen one in stores the ony replacement I have seen was the one that goes to the tripod and then screws in the botton of the camera...
May 28, 2008 | Cameras
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
