Question about Jensen XCH6RF 6-Disc CD Changer
Can i buy a replacement disc cartridge? - Jensen XCH6RF 6-Disc CD Changer
  • 58 Answers
I belive that changer is manufactured by Audiovox . There six disc magizine should work.
Posted on Jul 30, 2010
My 2002 RX300 constantly ejects the CD cartridge, discs properly loaded and inserted. Any ideas?
It sounds like the CD player is having a case of hiccups. I think the problem lies in the internal power circuitry. I suspect the issue has to do with the CD registration circuitry. No, this has nothing to do with whether the CD is an original or a copy. Instead, it has to do with the CD player's ability to recognize the physical disc.
When you insert a disc, the normal course of events is the servo registers or recognizes the disc as a CD and then moves the read head (the one containing the laser) into the 1:1 position so that it recognizes the first track and the first piece on the disc. Since all designs are, in general, based on the same principles, this step is either controlled by an sensor linked to a microswitch or it is controlled by a sensor that feeds positional information to an ECU (electronic control unit) within the player that compares the disc information to its programming.
If the disc is correctly positioned, the ECU tells the circuitry to start things up and tunes come out of the speakers. If it is not positioned, then the ejection circuitry fires up and the disc pops out. Here's the rub, as an oldtime poet used to say, if there's an issue with this circuitry your player should be replaced. It is possible that the positioner can be readjusted or that the positioning sensors can be realigned -- two steps that I would suggest you take next (you will need the service manual for your player for the instructions) -- otherwise you are looking at replacement of the unit.
Jan 14, 2015 | Lexus RX 300 Cars & Trucks
I am getting an "there is no ink cartridge
Are you removing the seal (looks like tape) from the new cartridge before installing? It needs to be pulled off in order for electrical contacts to touch. Otherwise, may need to replace printer.
Jan 09, 2018 | Primera Technology PRIMERA Inkjet, 4-Color...
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
The standard cartridge for the Pioneer PD-M501 is the Pioneer JD-M300 6-disc magazine, and you can find them at Amazon.com for $25 new. The JD-M300 fits a lot of different brands of CD players, not just this particular brand and model. And here's a link to a copy of the owner's manual: http://www.scribd.com/doc/22613342/Pioneer-PD-M601-M551-M501
Mar 26, 2010 | Pioneer PD-M603 6-Disc CD Changer
My printer's(Samsung CLP300 Color laser)smart panel says 'cyan empty replace the cartridge' even after refilling the cartridge.Not printing.
If you allowed your cartridge to run completely empty before refilling, the chip on the cartridge "knows" it is empty and will not allow it to be used. You can buy replacement chips for about $6.00 or so or buy third party cartridges for about $15. Your cartridge is not going to work until you get the chip replaced.
Jul 05, 2009 | Samsung CLP 300 Laser Printer
Display reads No Disc despite all the discs checking out.
Hi, the optical lens assembly has failed. this is triggering the (no disc) error code. you will need to replace this failed optical assembly.
May 29, 2009 | Pioneer Car Audio & Video
Purchased a 1995 ford explorer with a 6 disc cd changer and it now will not eject the cd cartridge and when the cd player button in pushed a message comes up ''no dj''. have read the owner's manual and it...
If there is a cartridge in the unit, you need to take the player out. pull the housing and do a manual release. do not force it. Possible problem could be 2 discs in the same slot or 2 discs trying to enter tray, either way, if the cartridge is present, it's jammed and needs to be pulled apart. If my memory is correct the factory unit was either Alpine or Clarion. The cartridges are still available at most car audio shops. 20-30 bucks. If you don't feel comfortable pulling the unit, most custom shops can check it on the spot, and let you know if it needs to be sent out for repair. Stay away from Best Buy, etc... go to a custom shop that's been around for a while and you'll get honest service.
May 17, 2009 | Car Audio & Video
JADO BATHROOM SINK FAUCET DRIPS
Jado are ceramic disc cartridges no washers you should replace both sides.You need to remove the handle and unscrew the cartridge
Mar 13, 2009 | Plumbing
Wrong cartridge
I have the multipass mp700 and have just experienced the same message ..... wrong cartridge. After reading the manual, from the disc, it means that there's something wrong with the print head, most likely needs cleaning, but it won't clean because the printer is sending a malfunction message. I will be trying to clean the head and if that doesn't fix it then I'll buy a new print head. Good luck with the problem.
Aug 15, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
I purchased a BJC-85 color bubble jet printer in 2002. I have lost my disc to set up printer; I just received a new labtop for work and I dont want to buy another printer. Is there anyway you can take my...
The drivers that were on the CD probably won't work on your new laptop anyway. You can download the latest drivers here (use the box to select your Operating System -- Windows XP, etc.).
You can purchase ink online here. The BC-10 is a black ink only cartridge, and the BCI-10 is the replacement ink tank. The BC-11 is a cartridge with both black and color ink, and the replacement ink tanks are the BCI-11bk and BCI-11clr.
Jul 26, 2008 | Canon Office Equipment & Supplies
Jensen XCH6RF 6-Disc CD Changer Logo
53 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
