Question about Polaroid TLX-01511C LCD TV
Polaroid TLX-01511C screen goes dark after power on
I have a Polaroid TLX-01511C, it will come on and stay on for a few seconds then the screen goes dark but if you look real close you can see the screen.
I was told that it is the LED inverter board. If so is this the board that is part of the screen??
  • 11,361 Answers
If the screen is still glowing, then you may have either dead T-CON board or the main board. Dead backlight inverter board will not get any glow on the front or the back of the LCD panel.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Jul 30, 2010
    New Friend:
You need to list what pins on the Board need the voltage
3.3 volt 12volt and a 24 volt and 5 volt need the schematic
all caps are good
Posted on Jul 27, 2013
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
Aug 21, 2012 | Polaroid TLX-01511C LCD TV
Screen turns black after about 15 seconds.
possible bad back light inverter board!! refer to service tech
Aug 22, 2011 | Polaroid TLX-01511C LCD TV
After a few seconds, screen goes black, but still has audio and from an angle can see picture.
There is problem with the back light inverter of your unit. Try to check the inverter board I think that their is only a loosed or cold solder but be sure to unplug the unit when removing the back cover feel free to send feed back good day and best regards.
Aug 12, 2011 | Polaroid TLX-01511C LCD TV
My polaroid tla-01511c lcd TV has a problem. When I turn it on, it works fine for about 15 seconds, then the screen goes blank but the audio stays on. When I turn it on again, the screen only stays on...
Buy cymbalta. Customer service worldwide, discount system, round-the-clock support from our staff. Regular online pharmacy at affordable prices. We are fully dedicated to your privacy and security. No delays in delivery. Any drugs without prescription.
*** Click Here To Buy Cymbalta Online ***
buy cymbalta
buy cymbalta cheap
buy cymbalta 60 mg
buy cymbalta medication
buy cymbalta generic
Oct 09, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Have a polaroid tv model # tlx-01511c. need the remote codes for direct tv.
try code 10768. if it doesn't work try the mitsubishi codes. it worked for me.
Jan 09, 2010 | Polaroid TLX-01511C LCD TV
I HAVE POLAROID TLX-04240B TV,HAS PICTURE STAY ON FOR AMOMENT &DI
I'm looking to purchase a broken TLX-04240B, the screen on ours is cracked. If you did not fix yours, I would be interested in purchasing it.
Sep 07, 2009 | Polaroid Televison & Video
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Gray screen
mine too. polaroid tla-01511c
Jun 16, 2008 | Initial Televison & Video
Polaroid TLX-01511C LCD TV Logo
704 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
