Question about Toshiba E-Studio 3511 Color Copier
Misfeed in the in the automatic duplexer - Toshiba E-Studio 3511 Color Copier
Open automatic duplexer door you will see 4 parts to open and green ring for rotating. rotate it the jam paper it will removed. or open all 4 parts you will see the paper if not open drower and remove the paper jam,
Posted on Aug 01, 2010
My konica minolta has a false misfeed showing at fuser area
Check all the sensors, the sensor in the fuser unit might be broken, common thing
Sep 06, 2014 | Konica Minolta Bizhub C550
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Hp p4014 MP tray, enveleope jam
Are you accidentally doing 2 sided printing when printing envelopes ? That could be the reason it misfeeds. Check to see that 2 sided (duplex) printing is not chosen.
Apr 29, 2013 | HP LaserJet P4014n Printer
Dialta i250 misfeed error
replace the fusing unit if you can find one
try this site Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 14, 2010 | Minolta DiALTA Di250 All-In-One Laser...
I have a misfeed in my copier. I have cleared all the channels but it still shows up on the board as a misfeed.
Hello !
when you will open all doors too remove the miss feed usually people forget one door to open let say this way. You will open the front door than you will open the duplex unit (if ti has one), than you will open the cover after the duplex usually here is the miss feed revolve the blue colored wheel in the front of the machine if you need to output the miss feed paper and than before you close all doors do not forget to open the door named [C] which is located under the fusing unit or under the yellow warning sign where writes something like " caution heat area please be careful to not burn your fingers" or something like that the door is opened by putting your fingers under the letter [C] and pull it your fingers towards you. Than you can close all the doors and the miss feed will reset.
Please rate the post if was helpful or write again for i to be able to post some other information
Regards
Dec 31, 2009 | Gestetner DSc224 Copier
Misfeed detected but no paper jam
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
as for the adf replace!!! the rollers all three try the same site above
Nov 03, 2009 | Minolta Di251 All-In-One Printer
Misfeed
Your running double sided copies? Have you open the duplex section? What type pape using
Mar 28, 2009 | Konica Minolta Office Equipment & Supplies
I have a Minolta cf3102 color copier. I pulled out 2 paper jams in fusing unit. Now it displays paper misfeed in duplex unit. I have checked all the paper transport way but I can not see any obstacle....
on the duplex unit is located on wright side .open the first outer door looks like 2 door in one .if you do not see any paper look for black actuator .in the center make sure it's not hanging up.
good lock
Mar 28, 2009 | Konica Minolta DiALTA Di200 Copier
Misfeeds
We lease the copier and have a maintenance contract. We call for a technician to come out and fix the problem. I was trying to find out if there was something preventive that we could do to avoid the misfeeds. For instance, maybe a particular type of paper (brand) is recommended. We use different brands but all are 20lb bond (some recycled, some not). We attempt to keep the paper from absorbing humidity, keeping it in its wrapper until use. Often I think it is that the sensors in the copier get "dusty" and then don't function properly. The user cannot get to these sensors -- that takes a technician.
Mar 03, 2009 | Kyocera Mita Office Equipment & Supplies
Toshiba E-Studio 3511 Color Copier Logo
167 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
