Question about Fein Multimaster Rs - Msxe 636 - 2 Rs
Where can I purchase a switch for the MSxe 636 II Fein Multimaster?
  • Fein Master
  • 1,981 Answers
Http://www.ereplacementparts.com is one of the online shops in you Country or a dealer for FEIN in your immediate environment.
Posted on Jan 01, 2016
3 Suggested Answers
  • 377 Answers
SOURCE: I can't keep the attachments
Are you fully opening the lock lever when you are putting the attachments on? If you are new to the machine, you need to fully open the locking lever on top, insert the attachment and be sure it "seats" in the shaft holder and then close the locking lever and be sure it is tight.
Posted on Sep 14, 2010
SOURCE: Hi. I have an older fein multimaster msxe 636 II.
With respect to the above "answer", this tool has NO locking lever! It uses only a set screw to hold blades in place. It so happens that newer "star" mounting blades will fit into this tool easily, One must center the blade so the fingers of the star are outside of the raised circular surround of the hole. A washer (use a larger tapered one) and the set screw will then press the blade against the back surface of the bit holder. Tighten up this assembly, turn it on a cut away!
Posted on Jul 28, 2012
My 250q surges speed control doesnt work
Fein 30762198013 but first before replace try to clean the variable resistor with a contact cleaner or wd40. and blow it out of dirt little chance sometimes it can help.
Mar 30, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Where could i buy a new switch and capacitor for my multimaster Msxe 636 - 2thanks
A capacitor is in in practice not nessecary but sometimes its only inside for radio interference suppression. remove it the switch is if you not know it also made to disassemble because of all its a realy dirt sensitive, but rarely defect i have never replace this part in all the time this year 20 years switches of this model al very little screwdriver is neccesary open it a little not neccesary to dismount it completely and spray wd40 inside wait a moment and blow the dirt carefully out remount and control always the AC cable for shure after.
Jan 28, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Replace the oscillating fork in a fein msxe 636
beware of the materials that are used are usually very soft witch used by Fein in his budget machine class.
puler
Only a dutch version but the same parts positions.
MSxe 636 II 50Hz 230V
Jan 05, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Multimaster stopped working
First control the brushes for the length or a spontaneous broken cable . or elecric modul has MEASURE is neccesary of the 4 electric field contacts also.
Dec 22, 2011 | Fein Multimaster Rs - Msxe 636 - 2 Rs
My Fein won't turn on without rapping it on the floor ! I turn the switch on and it won't run until I tap or rap it and will shut off during operation. I'm sure there's ...
ELECTRIC FIELD (and all the push contacts are most of the time the problem the cause by this machines , dirt in the switch (the switch is made to disassemble to clean it sometimes .little screwdriver neccesary .
Nov 14, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
I can't keep the attachments from falling off while in use. I suspect I need new hardware, but cannot find instruction for Fein msx 636 II
Sep 14, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Hi. I have an older fein multimaster msxe 636 II. The blades have round bolt holes. The new models have the star type holes. Can I use the star type blades since they are more available?
Dec 30, 2009 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Not oscillating
Hope this helps!
Inside the gearbox there is what should be a 2 pronged fork you may only be able to see 1 of these the other may be broken, the fork goes each side of the armature bearing. If the fork isnt broke it may be the armature bearing that fits inside the fork.
Hope that helps. Sean
Jul 26, 2007 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Fein Multimaster Rs - Msxe 636 - 2 Rs Logo
Top Fein Vacuums Experts
Marvin
Marvin
Bill Boyd
Dan Apthorp
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
