Have an Emerson LD195EMX HDMI LCD TV currently connected to DirectTV. I want to connect my Magnavox DVR/VCR ZV427MG9A so I can record programs. 1. How do I connect the DVR. (I first went by the Magnavox instructions, then connected per Emerson instructions.) 2. Using the Emerson connections, the DVR says I should turn the TV on, then turn the DVR on, then hit #2 and continue hitting channel until I see Setup. This doesn't work. 3. How do I get to setup so I can get the DVR remote to work with the TV?
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
  • 54 Answers
SOURCE: New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Posted on Jan 21, 2009
SOURCE: Emerson TV LC320EMXF Remote code for Direc TV
I got the same TV for my stepdaughter and had the same problem. None of the Emerson codes worked. We use Dish Network but I did the autoscan thing on the remote and found that it was 672 which is listed as a Sylvania. I don't know if it will help in your case but maybe try the Sylvania codes. Good luck.
Posted on Dec 25, 2009
  • 3 Answers
SOURCE: Emerson LD195EMX wont turn on. When plugged in has
Got the same problem. Foud:
Zener D648, 5V6BSB, was open: Resulting in very high output non regulated voltage
Zener D668, 20BSB, was short, due to the output voltage being too high.
Posted on Dec 18, 2010
  • 100 Answers
SOURCE: AKAI 27"LCD SN:60683669 Have HDMI connect o
Universal remote controls (like the one for your comcast cable box in which it allows you to control other devices) have "the most popular" IR codes programmed inside of it. When you type in the numbers "10812,10702, etc" you are telling the remote to use that particular IR code within its "database"
The key thing to know is that universal remotes do not have every code, just the most popular. If you have tried all of the codes listed in the manual for you model TV there's not much you can do.
  • Try searching for a code. Some brand names, such as "Akai" may have other manufacturers parts inside of it, Searching usually is done by going through certain key-presses on the remote to try all of the codes available.
  • Buy another Universal remote, not all remotes are created equal as some have mode IR codes built in than others, if you have an odd brand TV, it may be more difficult to come across one that works.
  • Buy a learning universal remote, although usually more expensive these remotes will allow you to "learn" the IR codes from your old remote to the universal remote.
I hope this helps.
Posted on Mar 06, 2011
Connect to direct tv
did you go into the source menu on the tv and go to the hdmi no.you have the hdmi wire plugged into
Feb 07, 2015 | Emerson LD195EMX - 19" LCD TV
How to transfer from dvr to dvd recorder?
A DVD recorder, not connected to a computer, only can record movies.
If you have a DVD reorder connected to your PC, you need software, like NERO, to be able to write all the different codes needed to make a DVD a playable one for movie, audio or just files. (Data)
Jun 11, 2014 | Emerson EWR20V4 DVD Recorder/VCR
We recently connected to Direct TV...I want to transfer some old western TV Shows I recorded on my Direct TV DVR Recorder to VCR Tape. I was told by the people at Direct TV that I would need to contact you...
You can try this: Connect your DirecTv to VCR with Red/White/Yellow cables. Then the VCR to your TV with the same type of cables. Make sure the VCR is set to the video input, not the tuner. Turn your TV to the correct video input. Get the program ready on the DVR as if you were going to watch it. Press record on the VCR and then play on the DVR. At the end of the program, press stop on both. You may have a problem with the video recording properly. Some stations broadcast with copyright protection.
Apr 12, 2011 | Emerson Televison & Video
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Nov 17, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
How do i record from directv hddvr plus to my vcr or dvd
Your going to need a AV connection out of the DVR into the DVD or VCR, whichever you want to record to. Go with the highest quality cable you can because that will define the quality you end up with. If you have an HDMI connection out of the DVR and an HDMI connection into your DVD Recorder, that is definitally the way to go.
Oct 25, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Rabbit ears,vcr,dvr,tv
Connect Rabbit ear antenna to VCR, Take Audio / Video Out and connect to DVR, and Audio / Video out of DVR to AV IN of TV. Start Tuning Channels using the Tuner of the VCR, and store them. Now, whenever you wish to record a particular Channel, select that channel on your VCR, and Record on your Blank DVD in the DVR.
Jan 10, 2008 | Televison & Video
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
Electro Med Services...
