Question about Jandy Heating & Cooling
Setpool temp thermostat at 80 and it continues
Setpool temp thermostat at 80 and it continues to heat up to 110.before it cuts off.
What is the most common cause?
    President:
  • 1,515 Answers
Hi, the cause of this is the thermostat is not working as it should. It has a built in safety to shut if off if the thermostat fails as in your case the high limit is more then likely set to shut it down at 110*F. Johnbarb64, I would consider the over all condition of this unit, age, and the price you paid for it, and compare it to another unit. If you were to take it in to a appliance repair place to have it checked out, you will be looking at a 1 hour minimum of at least $75.00 per hour and them leaving it on the bench until they have time to get to it. If this is something you can take on yourself, you could get the thermostat from them, probably need to order it and hope they send the same type replacement. I would make sure it is the OEM ( factory stat ). Anyway, this is your problem. The stat contacts are worn or temperature probe and sensor is faulty. I hope I have been of help to you and given you some direction to follow. Please keep me in mind when rating me, as I am sure you will be kind. Please keep me posted on the out come of the unit. I will be looking forward to hearing back from you.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Posted on Jul 30, 2010
Testimonial: "Just a brief note to thank you for taking the time to reply and for your expertise. I wrote more but the 50 characters shut me down.Thanks again. Joh"
  • Robert Horton
    Robert Horton Jul 31, 2010
    Thank you John for the awesome rating. I will be here if you need me in the future. Thanks so much.
    Sincerely,
    Shastalaker7
Hot tub is over heating
It sounds as though the thermostat is either shorted or not in contact with heater pipe somehow.
May 12, 2018 | Pool & Spa
Dexter stack dryer..top dryer not heating over 110?.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Mar 31, 2015 | Washing Machines
Dryer was not getting hot. Pulled it apart element seems fine but it looks like it may of been overheating at one point. wires look slightly melted
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Mar 28, 2015 | Kenmore Dryers
VHC691B-80 rotates but doesn't heat up
Check venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Mar 27, 2015 | Hoover Dryers
Kenmore elite quietpak 9 he4 cuts off after drying clothes for a while. clothes are still damp
GOD IS STILL GOOD !!!!
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 27, 2014 | Dryers
My gas kenmore 80 series is not heating?
ELECTRIC Dryer no heat or little heat:
May 20, 2014 | Kenmore 80 Series Heating Element -...
Kenmore dryer 80 series does not heat
May 17, 2014 | Kenmore Dryers
What's your problem? I have a Airtron furnace/air cond unit and last night I smelled a odor that of something electrical burning. I also noticed that the heating unit stayed on and continued to blow...
I'm willing to bet a relay burned up. You likely have your tstat set to auto changeover, meaning it automatically goes from heat to cool to maintain desired set points??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 21, 2017 | Heating & Cooling
My dryer heats but takes two cycles to dry clothes.
Check the hose in the back and vent to make sure it is breathing properly first. Most driers have a thermistor moisture sensor. Try replacing it first. It nether of these works your heat strip may be shorted so only heating partially. Most driers have two or three thermostats also. Two on the heater cover. One is the high temp and one is the low temp. Usually the high heat will be the problem (cuts out to early before the heat strip fully heats). Others have a third one on the exhaust blower. Check these at room temprature with an ohm meter. They should have continuity. If not replace. Thermostats that are open with no continuity will usually cause the heater not to heat at all. Thermostats can get old and stop working at their intended temp. Replace one at a time
Jan 17, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore Dryer - No Heat
110 comes from the motor 110 comes from the timer remove the wire that comes from the motor see if you have 110 if you do the timer is bad if not the motor is. even if the motor is turning its bad
Jun 07, 2010 | Dryers
Heating & Cooling Logo
104 people viewed this question
Top Jandy Heating & Cooling Experts
Craig Butler
Craig Butler
Willie Burks
Willie Burks
Level 1 Expert
David Spradling
David Spradling
Are you a Jandy Heating and Cooling Expert? Answer questions, earn points and help others
