Question about Rheem 81VP6S/430126 Water Heater
81sv-300 Breaker was turned off then back on. 8 hrs later no hot water. breaker was found to have tripped. turned on but still no hot water. thermostats were found to have been at top:140, bottom:110. reset to 150 each. reset button does not push in (is this normal) still no hot water. what should I try next???? thanks gregg
  • 349 Answers
The button could be stuck on the thermostat or needs replacing. You try to reset it by putting the screw driver head against the reset button and bump the handle with your hand to try to free it up. I have tried that and it free up one, reguardless if it didn't you would have to replace it any way if it is bad.
The button should pree in to reset, also check element's out they can short and throw your breaker.
Posted on Aug 01, 2010
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
Apr 29, 2016 | Stiebel Eltron TEMPRA 24 Tankless Water...
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Nov 27, 2014 | State Water Heaters 40 Gallon Select SL...
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 25, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
Water got extremely hot and then tripped a breaker. now if i reset the breaker and turn on the hot water switch on the wall, all is good. but when i turn the switch on the hot water heater itself it trips...
Sounds like you have a short in wiring for 120VAC system of water heater. Shut breaker at panel off, and remove cover on back of water heater to look for any burnt wiring at connections such as switch, or thermostat/eco assembly.
Jun 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
Jan 07, 2011 | Water Heaters
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
4) Bad upper element. Test upper element.
Nov 22, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
Water heater not working after turning up heat
Did you turn the breaker completely off, then back on? When a breaker trips it is in a middle position, and nust be turned off to reset it, then it can be turned back on.
Mar 14, 2010 | Stiebel Eltron TEMPRA 24 Tankless Water...
No hot water.
Please get an expert in - this is either the breaker is faulty or you have an electric fault int he boiler. You can try and replace the breaker - but match the current rating. But this could be dangerous if you keep trying to reset.
Jan 25, 2009 | Rheem Tankless Hot Water Heater...
Rheem 81VP6S/430126 Water Heater Logo
188 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
