Question about Toshiba Computers & Internet
My toshiba HDDR250E03X harddrive is not being picked up by comput
My toshiba HDDR250E03X harddrive is not being picked up by the computer, it used to work fine, now the blue light does not come on and it is not being picked up on any computer. I have tried changing the usb cord, i have tried puting it on different computer, but it does not get picked up the computer when i put it into the USB port. I can feel the motor or fan running within the hardrive when i plug it into any computer, but it does not get picked up at all, what should i do, please help, all my work is stored on it?
Staunchporra
  • 12 Answers
SOURCE: Simpletech 160 Portable doesn't show up
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Posted on Jan 24, 2008
SOURCE: Computer suddenly not reading external harddrive
I managed to fix it by unplugging the harddrive from the main electrical power source.
Posted on Nov 24, 2008
SOURCE: I have a 160GB signature
Good luck finding an answer on this site
Posted on Jan 03, 2009
SOURCE: wd mybook lights flash and cannot acess drive
Just an FYI for anyone else with a similar problem. I had my buddy look at it and it was discovered that the problem was with the power cord.
If your hard drive is still under warranty, call WD and ask that they send you a new power cord. It worked for me instantly.
Worth trying anyway,
Posted on Apr 07, 2009
renx
  • 71 Answers
SOURCE: Toshiba 160 GB Hard drive is not seen by 'new' computer
I have had a similar problems with external drives that only plug into a USB port (no ext power adapter). It is very common that the power supply fed through the USB port is inadequate to power an external hard drive. Some enclosures have a external A/C input to resolve this. Also, some computers (motherboards) only have a select number of USB ports that are powered. Since this device is detected by your other computer and not on the new one, my next attempt would be to locate a USB hub with external A/C power. There is a good chance that this will resolve the problem. By the way, when you plug in the drive does it spin up?
Posted on May 03, 2009
I have a Toshiba HDDR500EO3X...nothing to connect it to my computer and the external port is so small I have no idea what I need to connect to my HP computer
Toshiba, for HP forum, OK.
ahhhhhh its and exernal hard disk drive and chassis.
mine has USB cable and Esata cable and power.
yours has 1 cable new. usb.
what HP computer is it , which one. is it model numbers on the service tag. 1000s of pCs made by HP from 1982 to now, endless list.
i cant guess ever.
500mb (tiny) external drive.
by TOShiba.
listed as obsolete at Newegg. so is not new, (NOS?)
i guess you got it for free? and now the USB cable is missing
that it?
here is one cable, this fits the tiny HDD end
and then fits all PC made, (no dont fit cell phones)
try to know there are many classes of USB connectors
(lots) my guess you lost the comes with it cable
or you PC has no standard full size USB jacks.
some super tiny thin notebooks can not have full sizes USB jacks
so need a special USB mini cable, unseen by me, no help.
http://www.ebay.com/itm/USB-Cable-Data-Cord-For-Toshiba-HDD640E04X-HDDR250E03X-HDDR500E03X-Hard-Drive-HD-/272192214668?hash=item3f5feb968c:g:~lgAAOxyaqlSToBi
May 23, 2017 | HP Computers & Internet
Toshiba 250gb MK2533GSG my computer cant find my harddrive window 7
Remove and refit your hard drive. If that doesn't work, you may have a faulty drive. First look in the BIOS under Storage and see if the Drive is actually being seen by the computer. To check if it is the computer or the drive you should try a known working one to see if your drive is shot!
Mar 20, 2012 | HP Computers & Internet
I have toshiba 250 gb HDDR250E03X i am unable to write a data of 4 gb or more(single file of 4 gb or more)..?
Hi this is a file system issue. It is probably formatted in fat32, which does not support files above 4 gigs.
To solve this problem you'll need to reformat it (my computer => right click on the drive => format), using ntfs file system (under file system select ntfs).
Note:
THIS WILL ERASE EVERYTHING FROM YOUR DRIVE!
So back up everything before proceeding.
After it is done you will be able to copy files of any size onto it.
Alternative solution: download winrar and split your files into chunks smaller than 4 gigs.
Jun 30, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
PC IS NOT RECOGNIZING MY TOSHIBA EXT-HARD DISK. MODEL:HDDR250E03X. CAPACITY : 250GB
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 18, 2011 | Toshiba MK1637GSX 160 GB IDE Hard Drive
I have just tried, for the first time, using my new 320GB Canvio. The white pilot light comes on, and I feel the disk spinning for a short time, but there is no operating software presented, and no file...
External harddrives do not come with an O/S. They are for external storage, beyond the master harddrive you have installed.
The master harddrive has the O/S.
The Platters are spinning because BIOS had a look to see what is on the Toshiba 320GB external harddrive.
[You press the Power On button. The first chipset to receive power is the BIOS chipset.
(Basic Input/Output System)
BIOS looks to see what devices are connected to the computer, does a Ram Memory count, turns the Processor on, then hands the computer over to the operating system.
BIOS finds THE harddrive with the O/S on it ]
http://en.wikipedia.org/wiki/BIOS
http://computer.howstuffworks.com/hard-disk.htm
When the Windows O/S (Operating System) is installed on a computer is assigns hash values to certain major hardware components in the computer.
A) Processor
B) Harddrive
C) Motherboard. (Motherboard chipsets and BIOS software on the BIOS chipset)
D) Graphics chip. (Whether it is Integrated Graphics, {OnBoard}, or a graphics card)
Change any two of these hardware components and Windows throws up a 'red flag'.
Microsoft's User License states, "One genuine copy of Windows per One computer"
If a hash value has changed, such as there are different hardware components, Windows 'feels' it is being stolen.
Why do you feel there should be an O/S already installed on the external harddrive?
Awaiting your reply please state in a Comment.
Regards,
joecoolvette
Jun 07, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Hi ... hey how do you run a xp disk i mean make it boot from my dvd drive i just switch the harddrive cause the other broke it a toshiba m2v trece
Put the disk in the cd/dvdrom start the computer and push F11 and pick the cdrom if it goes to windows boot screen start over
Apr 17, 2011 | Toshiba Tecra M2V-S310 Notebook
Why can't I access anything that was copied onto my Toshiba 500G external harddrive. The computer doesn't recognize the program that made any of it, even though it's the same computer.
It is very possible the voltage on your computer's USB port is not handling the load. I would buy a "powered" USB 2.0 hub, plug it into your computer's usb port and plug the harddrive into the powered hub.
Apr 18, 2010 | Toshiba 120GB USB 2.0 Portable External...
Windows failed to load because a required file is missing or corrupt This is what it keeps saying.
This happens with Windows sometimes. One of the little 'Quirks', as it were.
Do you have the Restoration disk? These will be CD's, that Toshiba MAY have supplied with the computer.
(Should be one of the following:
1.Restore CD
2.Recovery CD
3.Reconfiguration CD
4.Configuration Builder CD, {CBCD}
I indicate May, because many computer manufacturer's had/have stopped supplying them. The trend as far as I can tell, is that they are now supplying them with laptop's, and desktop computers, again.
Their reasoning?
Cost, versus whether or not the user/owner of the computer, will actually use the Restoration disk.
Cost:
Let's say it will cost 50 cents. (US), to produce this disk.
Now take that times 50,000 to 100,000 computers.
$25,000 to $50,000 dollars.
If the computer owner isn't going to use them, why supply them?
Sometimes, the computer owner is afraid to use the Restoration disk. Winds up taking it to a computer repair shop. That little disk stays right there, in the computer desk drawer.
Restoration is also put on a separate area of the harddrive. A separate partition on the harddrive.
Problem is when this form of Restoration is used, the computer is brought back to the way it was, when it came from the factory.
Back to Day 1.
This means all the programs, and applications the computer owner has physically installed on the computer, are GONE!
All the one's downloaded also.
All personal files are gone. Pictures, videos, music, and any documents the computer owner has put on, is GONE!
The computer goes back, (Restored), like it was when it came from the factory.
The Restoration disk has a Repair option. The necessary Windows files are repaired, and all personal documents, plus programs, and applications are saved.
Just the necessary Windows 32, files are repaired.
It could be a harddrive that is failing.
The way to get to the bottom of this, is to use the Restoration disk.
Or, completely wipe off all your personal data, and restore the computer back to Day 1
Which way would you like to proceed?
If you have the disk we can proceed from there. Or you may want to order them from Toshiba.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Restoration+disk&x=7&y=7
Dec 20, 2009 | Toshiba Satellite A100-S8111TD Notebook
Dead USB external HDD. Disk spins, light is on, but no one is home.
it does sound like the Hard drive enclosures circuit board may be the problem, there are ways to get the data off that will void your warranty, or there are services you can send it to who will get your data back for you and then replace it.
Let me know what your preference is and I can assist you either way.
Chris
May 20, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Start up
what a pity! if you Windows is really just had a corrupt system file that caused it, try boot with this CD to recover bad sectors: "HDD Regenerator 1.51". This is also available in Hiren's BootCD.
By the way, what Antivirus you are using on the laptop? The cause of this may due to a Virus wrote a startup system file entry into the registry but your Antivirus picked up the file and removed it however not the action. That's why a file is "missing" upon reboot.
What you can do lastly is to take the harddrive out, put it into a external harddrive case, backup all your data from another PC, and reinstall Windows on the laptop.
Apr 12, 2009 | Toshiba Tecra A2 Notebook
Computers & Internet Logo
396 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
