Question about Sony Playstation 3 (PS3) Console
Need help with ps3 anti aliasing
My Tv is HD full connected with HDMI cable to ps3 , I have set the settings to the max.
But still rendering and anti-aliasing seems not to work.
I get this cuted lines
See here
www.gemaga.com/wp-content/uploads/2007/12/anti-aliasing.thumbnail.png
www.tweakguides.com/images/Antialiasing.gif
Does anyone know how to fix this???
Or some games have bad graphic???
ikebert
  • 47 Answers
SOURCE: No signal on my TV
try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
Please remember to rate my response if helpful.
Posted on May 30, 2009
SOURCE: PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Posted on Oct 20, 2007
wattsbw2004
  • 4 Answers
SOURCE: Display not working
how down the power button until it beeps twice. that will restart your settings for the display. once it beeps twice then turn the system on and change the default settings back to your hdmi settings. what happened was when you transferred the ps3 to composite the settings changed to accomodate that but when you switch back to hdmi it doesnt change back. the only solution is to hold down the power button untill it beeps twice. normaly 3 seconds.
Posted on Jan 12, 2008
SOURCE: PS3 picture doesn't work
it is because u had ur ps3 set to and hdty not a standerd one same thing happend to me use hdmi cable and it will work agian
Posted on Jul 17, 2008
SOURCE: Playstation 3 Flickers when set to 1080P
I did some further research. I updated my firmware for TV(samsung) to the latest. This did not resolve the problem. Then I changed the hdmi ports. what I found is that the problem(ofcourse only with 1080p) is seen in the first 3 hdmi ports on tv, BUT NOT at HDMI 4 port. That may be our TEMPORARY SOLUTION. but not a final solution.
In samsung LNxxA650 series, HDMI 4 is at the side, not in the same zone as other 3 in the back. so, it's hardware implement may be little different.
So, does it mean it's been all TV's fault? no, not necessarily. The ports 1,2,3 are working good with blue-ray disk videos with 1080p. How is that possible? So, well, for one, I think PS3 itself could use different ways (integrated chip vs embedded firmware OS ) for launching xmb vs running blue-ray videos. If it is a handshake issue, then PS3 has to resolve; I will also call samsung and launch an investigation. For them, All ports should behave the same. period.
Suggestion: As for other TV brands, try with other ports and check. Otherwise, update firmware/call TV technician. please launch complaints at TV so, that they realize that they need work together to with SONY folks to get this resolved.
Posted on Jan 11, 2009
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I have a ps3 that i tried to hook up to our emmerson tv through an hdmi cable and the tv screen says format not supportedf why?
If you recently moved the PS3 from one tv to another, it's setup to work on that other tv.
Press and hold the power button on the PS3 until you hear a beep. This should default the video output to whatever is plugged in and the PS3 should output normally via the HDMI connection.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
Hey My Jvc tv has 2 HDMI input but when i plug in my ps3 slim into the hdmi input 1 no picture is shown can u please help me
hi,
is ur tv is a full HD one. because the ps3's HDMI out is a full HD 1080p video. did u get the video on HDMI 2. if it is there, then check the connection u made to HDMI 1. if u didn't get video on both then u should down scale the video setting of ur ps3 to 1080i( if ur tv is not a full hd one). also check through component video input.
ok
Dec 22, 2010 | Televison & Video
I am trying to commect to my PS3 to an LG LCD tv which supports 1080P (Full HD). but as the game starts and when i check the TV it says 720P although the game and the TV both supports full HD. Do i need...
Hello there. There's a few possibilities. First, the obvious, do you have it set to 1080P in the Display Settings options? Secondly, are you using an HDMI cable? You need to be using HDMI to play games in full 1080P. I use the component cables (The red, green and blue ones) for my PS3 and when I'm on the XMB (that's the PS's desktop so to speak) it's displayed in 1080P but games will not play in 1080P, only 720P. Any old HDMI cable will do the trick, so don't get suckered by the price if you are going to pick up a cable!
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
Cannot output 1080p with a full hd 1080p hdtv
In the settings menu, go to video settings. You can have the PS3 search for "optimal settings" This will tackle both video & audio.
On a side note, you didn't need to spend all that money a HDMI cable. ( I'll bet it's a 'Monster' cable, right? ) The $16 Phillips at walmart is just as good. Unless your doing "broadcast quality digital" work, the expensive cables are overkill. Sorry, bro.
May 18, 2009 | Sony Playstation 3 (PS3) Console
Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
302 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
