Question about JVC HA-W600RF Consumer Headphones
HI THERE, I HAVE A PROBLEM WITH MY JVC CORDLESS HEADPHONES MOD.HA-W600RF; IT HAPPENS THAT I LISTEN A LOT OF STATIC NOISE WHEN I USE THEM, AND AFTER 1 HOUR OR MORE, THIS NOISE INCREASES VERY MUCH, AND THEN IT'S ONLY NOISE WHAT I CAN HEAR!, THEY ARE WELL CONNECTED, AND ALL THOSE THINGS ARE OK, WHAT CAN I DO??, I HAVE ONLY 4 MONTHS WITH THEM AND AT THE BEGINNING THERE WAS NO PROBLEM AT ALL
2 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: I have a big problem
Hello, from my experience , some times its the batteries, when they get weak, that will happen. I have headset like that I use in my band i play in. Here is what happens to me, just like your problem. like i said earlier, batteries, or sometimes, there is something i have just recently installed in my house or moved in my house that is interrupting the frequency. The units are all based on a frequency like a garage door opener. I even one time kept during band rehearsal couldn't figure out why at a certain time i would get this static, come to find out, it was by daughter home at time of my practice, that was using hair dryer. What I did to solve this, was on my unit i can tweak or adjust on head phone and unit a different frequency, and dial it in. Also sometimes if you move your base station and put it on different outlet that is not on same circuit will solve problem. Please try some of these suggestions and see if any of there help you..... Thanks Mike.
Posted on Jun 30, 2011
Ha-nc100 replacement earpads cushion
CHECK YOUR LOCAL CRAIGSLIST, EBAY, OR AMAZON. THEY SELL HEADPHONES THAT EITHER ARE FOR PARTS OR HAVE BOTH CUSHIONS AND BEING IN WORKING ORDER.
I ALSO SUGGEST FOR YOU TO CHECK:
http://www.jvc.com
OR
SEARCH GOOGLE BY INSERTING THE FOLLOWING WITHIN THE SEARCH BAR: " BUY CHEAP HEADPHONE CUSHION FOR AN; HA NC100 SET OF HEADPHONES"
IN YAHOO SEARCH BAR YOU CAN TYPE:
" DOES ANYONE KNOW WHERE I CAN BY AN HEADPHONE CUSHION FOR JVC HA NC 100 HEADPHONES,
OR
DOES ANYONE GOT A SET OF JVC HA NC100 HEADPHONES FOR SALE THAT MAY BE USED FOR PARTS OR EQUIPPED WITH BOTH CUSHIONS THAT ARE IN PROPER WORKING CONDITION?"
I ALSO SUGGEST TO CHECK www.overstock.com
Dec 02, 2013 | JVC HA-NC100 Consumer Headphones
Jvc headphones retractable cord
The JVC HA-NC250s are a new version of their previous model 100, and JVC claims that they will cancel up to 85% of ambient noise, coupled with better sound. In this case, JVC claims up to 16.5 db reduction at 150 kHz. These on-the-ear headphones are very lightweight at 5.3 ounces and are extremely comfortable. The head band has a reasonable amount of sliding expansion for bigger heads, and the oblong ear pieces themselves rotate and fold flat for storage. JVC uses memory foam on the earpieces, as well as double housing, for extra noise isolation. The earpieces have 40 mm neodymium drivers, which are the same size and type that the Creative Aurvanas offer.The JVC HA-NC250 noise canceling headphones. Note the ear-cushion instruction tab that explains how to replace the hidden battery.
The NC250s come in a semi-rigid black case with a dual airline-plug adapter, a mini-to-RCA phono plug adapter and a 4' detachable headphone cord. JVC includes one AAA battery, which should last approximately 50 hours. A simple sliding switch on the right side turns the noise reduction on along with a small red LED. Learning how to add the battery to the headphones required that I study JVC's user manual. The process involves having to remove the earpiece covering to get to the battery compartment, which isn't at all obvious.
Jul 22, 2012 | Audio Players & Recorders
Haw600rf volume
I think there is a wire damage or something of that nature, I would just get a new pair.
Mar 15, 2012 | JVC HA-W600RF Consumer Headphones
Hi, I have JVC CA FSY! and it has static noise on speakers but its ok on headphone. How can I solve this problem?
http://books.jvc.com/booklist.asp?Model=fsy1
Choose your submodel.
So the good news is that the amp isn't implicated but an electrical conductor somewhere in the path may be flaky.
Headphone insertion mechanically disconnects output to the speakers. Hence, headphone removal relies on spring-loaded contacts to restore the output to the speakers. Perhaps there is oxidation on the normally-closed contacs. Repeated headphone insertion/removal MAY help wear it off.
Also try swapping the speakers (wire and all) to see if the static follows or stays with the amp channel.
Jul 12, 2011 | JVC FS-Y1 Theater System
I have a big problem with the JVC HA-W600RF headphone. The sound on my unit will suddenly go off and transmit loud static! The sound don't hear up to a minute or more, and then it will come back on....
Jun 30, 2011 | JVC HA-W600RF Consumer Headphones
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
I have a wireless jvc headphones, the item is 110 volts but was accidentally plugged in to a 220 volts socket. can this still be repaired? thank you.
It no doubt can be repaired, but chances are it's going to be pricey. The power input circuit will be blown for sure, and probably most everything ahead of it, since voltage came in on the ground side also (a 220V line is just 2 120 lines, and it's usually more like 228-240). You would be better off trying to get one off ebay, or on sale, than to repair this one. Sorry to relay the bad news. Of course, the headphones will still be good, that's the good news.
Jun 04, 2010 | JVC HA-W600RF Consumer Headphones
Insignia PC speakers - give a weird static feedback noise
I'm going to vote for the haunted option.
Sound like you have some noise on your power lines. This can be caused from many different things. Normaly it is a motor going bad or a compressor starting up. From the AC unit or refrigerator.
See if you can correspond the noise to anything else happening in the house. Fridge starting up, AC or heat cycling on...etc.
It may be that you just have speakers and a cordless phone going bad at the same time.
It might just be Casper the friendly ghost playing tricks... ha!
Jan 23, 2009 | Insignia 2.0 Speaker System (2-Piece)
Dead earphones !
i bought one headphone of this type ,i believe the length of it can transmit is too limited !,so i it is not very good !
May 20, 2008 | JVC HA-W600RF Consumer Headphones
JVC HA-W600RF Consumer Headphones Logo
99 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
