Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
I today saw two black liquid spots which dripped from my Admiral two door refrigerator.... help!!! The drips seemed thick like oil but they were soluble when water was applied
  • 4,793 Answers
The black gunge is moss(it grows in condensation)syringe out the drain hole(s)with clorine bleach,(it will gas off in no time and leave no smell)
Posted on Jul 29, 2010
Testimonial: "where do I locate the drain holes? Would these be located in the freezer section?"
  • geoff hunter Aug 04, 2010
    normally at the back of the fridge,in what looks like a thin drain channel.
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
I have an Admiral refrigerator and i can not see how to clean/empty the drip pan underneath--Isn't there one?
remove the plastic cover underneath the main door, then you can inter you hand inside the slot and find the drip pan underneath the refrigerator
Sep 16, 2014 | Admiral Refrigerators
My Admiral side by side has a leak from the bottom of my freezer.
check your door gasket for air leakage, it sounds like condensation.
Apr 01, 2014 | Admiral 26 cu. ft. Side-By-Side...
I have a leak from the bottom of my freezer. IT seems to be coming from the front left edge corner. Dripping down the adjustment screw leg. I just cleared drain line so its not that again. This is ano
That's where the drip pan is for the underside models, other than that it's likely a leaky door seal on that side or the case heater went out letting it sweat.
How do i replace the cracked drip pan in the french door refigerator
  • Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
  • Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
  • Line up the new drip pan with the two side guides beneath the refrigerator and slide into place. Use the flashlight if to make sure the drip pan is in the groove on each side.
  • Clean and replace the vent cover by clipping or screwing it into place. Plug the refrigerator back into the power outlet
  • Dec 15, 2013 | Freezers
    I have an older admiral refridgerator, when you open freezer it sounds like water dripping on a hot skillet. I unpluged it, later pluged it back in and wont come on
    The sound was water dripping on the defrost coil...
    Check out these tips...they can help you figure out what is going wrong with your refrigerator
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Dec 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
    Hello i am having a foul smell coming from underneath the refrigerator. it doesn't have the drip pan on it..i removed it due to a previous foul smell..are these refrigerators known to have this type of...
    the smell is bacteria caused by condensation from the drain pipe/drip pan,syringe with chlorine bleach, all fridges will smell if not looked after in the proper manner....but how many of us read the book......(if you removed the drip pan then you have the bacteria all over your floor.....will discolour/ruin any surface/carpet...
    Jul 30, 2010 | Admiral Refrigerators
    My refrigerator has same black fluid leak from same spot as ltyndall of 6/22/07. First night when I noticed it, it was semi-hard; and I used a butter knife to scrape it off the floor. Tonight, still liquid...
    This liquid is usually from condensation in the walls or doors of the refer, dripping down through insulation, sealants, sound deadening material on some units, corroding metal, ect., and dripping onto the floor. We have seen where the drain for the defrost system was plugged and the water gets into the insulation from this also. Make sure your condensate pan under the refer is getting water into it periodically. Usually every 6 to 8 hours. If it is always dry then you need to remove the freezer back panel inside the freezer and look for a plugged drain. You can also have a plugged drain in the refer section and in the tube for the drain that is on the back of the refer on some models. If it is from condensation, changing the temperatures can sometimes change the amount or position of the actual condensation. In none of this helps, unplug the refer, open the doors, and let it completely dry out for several days, in the sun if you can, and then restart and see if the problem recurrs. Good Luck, Appliance Specialists
    Jan 28, 2010 | Refrigerators
    Dripping water dispencer
    Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
    Nov 12, 2007 | LG LFD22860 Stainless Steel Bottom Freezer...
    Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
    140 people viewed this question
    Top Admiral Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
