Question about Insignia Televison & Video
I have a 15" Insignia TV with a DVD player. It was working fine for a year. Then one day it just stopped. I think my daughter may have pushed something on the remote. I can turn it on. When it comes on the screen is white. I can put in a dvd. It sounds like it makes the whiring sound and then nothing happens. Is there something I can do to fix it myself?
  • 11,896 Answers
You can open the disc tray and blow inside several times to blow of any dust that is on the lens. Or purchase a can of air duster.
If cleaning does not help, then it is likely the laser lens circuit is faulty which is very common and it will need to be replaced
Posted on Jul 29, 2010
  • 3 more comments
  • shelley_jone Jul 29, 2010
    The tv is not working either. The screen is white for both tv and dvd.
  • Nate Stansfield
    Nate Stansfield Jul 29, 2010
    Are you able to access your menu settings? The white level is controlled by the contrast or color settings. One of the settings may have gotten changed.
    You can try uplugging it for 5 minutes, While unplugged, press and hold the power button for 10 full seconds, then wait 1 minute and plug it back in and see if it resets itself.
    Otherwise if you can access your menu settings, try changing the contrast or the color. If none of these work, you may have a faulty LCD tube in the tv.
    Did you get my other posts.
    The whole screen is white for both tv and dvd.
    There is no drawer for the cd player.
    I am wondering if my daughter pushed something on the remote. Any ideas?
    I will try the things you suggested.
    Is it worth getting the LCD tube fixed or am I looking at throwing the tv away?
  • Nate Stansfield
    I say 4 years and newer is worth it. Anything older than that really isn't worth it.
Is Magnavox DVD and playstation 2 compatible to insignia tv
well you need to change the input on the tv for them to work
Mar 02, 2015 | Insignia Televison & Video
Insignia lcd tv shuts off after 2-3 seconds
The TV seems to have a failing Power Supply. This could potentially be repaired but would be an out of warranty expense.
Dec 14, 2017 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia flat screen (tv/dvd) combo. dvd player does not work
Get someone technical to open the unit and clean the laser lens with a swab of eyeglass cleaner and also clean the rails that the laser runs on
Please rate my help if this helps
Thanks
Aug 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Can i change the input settings without the remote
pls check from channel one to zero you can see AV input.
Aug 17, 2009 | Insignia IS 20" TV040919 TV
Insignia car dvd player car adapter doesn't work
Your power adapter for the car is not working. Check if there is any voltage output while plugged in.
Aug 11, 2009 | Insignia Dual 7" 16:9 Widescreen LCD...
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
Insignia dvd player wont play some discs
How to unlock a dvd player Insignia NS-H2002-U for region free
Insignia NS-H2002-U
With disk In the player (must be allowed region on you dvd)
Press stop in the remote dvd control 2 times to have a dvd screen in your tv
Press 16719 in your remote no matter what appears in the screen, at the end the region menu will appear
Using down arrow go to region that you want, “0” is for region free.
Press ok and enjoy it.
If do not work, power of your dvd, turn on again, incert allowed dvd movie in your insignia dvd player, when start reading disk, press stop and the press setup in your remote control, set uo dvd screen appears, then press 16719 in your remote, region menu will appear and use down arrow to select your region code, zero is for all regions.
Enjoy it
Feb 17, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Sep 06, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
My Insignia 8" Portable dvd player does not detect dvd!
Try playing a regular CD first and take it out if it played. Then put the DVD and it will play fine because the player just realign its lense. Hope it will help
Jun 17, 2007 | Insignia PD10135 Portable DVD Player
INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Televison & Video Logo
18 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
