Question about Lenovo 9165AB6 Monitor
I have 12 Lenovo 9165-AB6 LCD's
I have 12 Lenovo 9165-AB6 15'' LCD monitors all with the same problem.
The leads going to the backlight from inverter (pink and white) are leaking voltage directly to case (ground). Seems to always come from the top backlight.
It is not the main board and the ''leak'' comes from the cable itself.
  • TechUsed Jul 29, 2010
    We are a REPAIR SHOP, please keep in mind we have 12 of these monitors....all with the same problem. The voltage leak is found INSIDE the monitor (with the back off). I am not talking about the VGA cable, it's the pink and white inverter cable coming from the backlight.
    President:
  • 670 Answers
I would try to isolate the source of this leak. It either comes from the backlight itself or from the inverter board. I would start with the inverter board first, by unscrewing it from the case and place it on an insulating matterial and see if that eliminates the source of the leak. If it does not, then see if physically removing the backlights from the LCD fixes it. It has to be light, the wires or the inverter. Since all 12 does this, it probally a manufacturing defect. Hope this helps.
Posted on Jul 29, 2010
    President:
  • 567 Answers
Hi, if the cable is leaking i advise you to replace it, for reasons such as it is dangerous to you while trying to fix it,( 2) it is armful to the computer which the monitor would be connected to,( 3 ) it is harmful to the individual who would be using it, the monitor can be destroy if there is a leak of current, so you should change the cable.
  • 2 more comments
    No, I am talking about the small Pink and White cable inside the monitor that connects the backlight to the inverter. I would guess the problem is in the backlight but am looking for a fix for it. It's new to me.
    Ron
  • Hilton Bristol Jul 29, 2010
    Try this option,
    The computer's monitor is essential to the unit's operation. If the PC is having monitor power supply issues, there are a number of things you can safely try to troubleshoot it before you call a technician. Remember to always turn off the computer and monitor and unplug it whether you think its getting electrical power or not. Never open a monitor, even if it has no power source. A CRT monitor has a capacitor that can store enough electricity to kill a person. There is nothing user serviceable inside a monitor anyway.
  • Unplug the monitor from its normal plug in and try it in a difference receptacle. The monitor's switch should be in the "On" position.
  • Step 2Inspect the back of the monitor. Make sure to push the power cord firmly into the back of a flat screen monitor. A CRT monitor may or may not have a cord that is removable at the back of the monitor. Some power cords have fuses. If yours does, replace the fuse by following manufacturer's directions. If you see signs of wear in the power cord, replace it.
  • Push the monitor's cable to the CPU firmly into the back of the monitor as well as the back of the CPU so the monitor can receive a signal from the PC. Determine if there are any bent pins in the signal cable connector. Replace the cable if it shows signs of wear. A cable longer than five feet can cause power issues, so keep the distance between the CPU and the monitor within that range.
  • Step 4Adjust the brightness and contrast levels on a flat screen monitor if the power light shows green but there's no image on the monitor. No image on the screen may look like there's no power to the monitor when the monitor is actually working properly.
  • Step 5Wake the computer out of standby mode if the power light shows an amber color. Move the mouse or touch any key on the keyboard. If the screen goes blank too quickly, you can reset the length of time that must elapse before the computer goes into standby mode through the control panel. It's also possible to turn standby mode off entirely.
    Connect the monitor to another PC if possible to see if the monitor is the problem or if it's an additional problem with the cables connecting the monitor and the PC.
    No backlight hp l1506
    Have someone to help you , replace the electronic components
    in the Inverter Circuits.
    One may have to use a Desoldering Tool , Soldering Iron
    and a good soldering lead.
    Jul 30, 2012 | HP L1506 15" LCD Monitor
    T42p display lights for a couple of minutes through startup then goes dark
    But fan still runs, and it sounds like the harddrive is spinning?
    Diagnose.
    Do you have a VGA monitor available?
    You can use a CRT type, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
    http://en.wikipedia.org/wiki/VGA_connector
    1) Laptop OFF, monitor OFF, connect the VGA monitor cable to the left side of the ThinkPad T42. (DisplayPort)
    2) Turn the monitor on. If a CRT type allow it to warm up.
    Turn the laptop on.
    By factory default, the display should show on the external VGA monitor.
    If not;
    There are at least three display options available;
    1) Internal monitor of laptop ONLY
    2) Internal monitor of laptop AND external VGA monitor
    3) External VGA monitor ONLY.
    Press, and hold down on the Fn key, and at the same time tap once on the F7 key. The F7 key is the Display Toggle-Over key.
    3) Good display on external monitor?
    Problem is the video cable, or inside the Display Assembly.
    Since the display goes dark after a couple of minutes, I can tell you the problem is the screen Inverter, or Backlight.
    (Inside the Display Assembly)
    90 PERCENT OF THE TIME the fault is a bad screen Inverter.
    Primer:
    An LCD screen cannot produce light. It needs an additional light source.
    A Backlight is the additional light source.
    A Backlight can be a CCFL, or a series of LED's.
    (Light Emitting Diode)
    The Lenovo ThinkPad T42 series of Notebook PC's, uses a single CCFL for a Backlight,
    http://www.screentekinc.com/IBM__ThinkPad__T42-series-laptops-lcd-screens.shtml
    A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
    Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
    [Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
    Average length is almost as long, as the LCD screen is in height ]
    A screen Inverter converts the power from the laptop, for the LCD screen, and Backlight.
    (Older versions of backlighting that used a series of LED's, used a screen Inverter. Newer versions do not. For these replace the LCD screen)
    A screen Inverter and an LCD screen are a MATCHED unit. Make sure you get the correct screen Inverter, or LCD screen, when buying.
    Primer over.
    One example of a screen Inverter for the T42's,
    http://battery-adapter.com/product_info.php/products_id/3381/vThinkpad+T42
    Pictorial guide for replacing a screen Inverter, in a ThinkPad T42 series of Notebook PC,
    http://www.insidemylaptop.com/replace-screen-inverter-in-ibm-thinkpad-t40-t40p-t41-t41p-t42-t42p-laptops/
    http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
    Lenovo Support link to the Hardware Maintenance Manual, for the ThinkPad T42 series of Notebook PC's,
    (HMM. It is a Service Manual),
    http://support.lenovo.com/en_US/guides-and-manuals/default.page?
    Click on the bold black subheading -
    Hardware maintenance manuals
    Then click on the blue -> [+] Click for files
    It is a PDF file.
    It may take up to 30 seconds before the first page comes up.
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
    Jul 29, 2012 | Lenovo ThinkPad T42 Notebook
    Was running perfect the all of sudden the screen is almost non visible, looks like it is almost totally black, have to look close to see the system running in the dark shadows background. I called Lenovo...
    Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
    The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
    Sep 22, 2010 | Lenovo 3000 G530 Notebook
    My s10e lenovo is on but there is no display please guide me what is the solution of it. all lights are on but display is totally blank
    Sep 16, 2010 | Lenovo IdeaPad S10e Notebook
    I got a ELO 1524L LCD touch monitor. The back
    You should have 2 wires for 12~15 power going in, which you already indentified, 2 more wires should be for ground return, you can check for them by using Ohm meter between the chassis and probe the wire for less then one Ohm resistance. The other two wires, 1 wire will be for Dimming control (usually 0 = dimmed, 5vdc = full brightness), 1 wire will be for BACKLIGHT ON/OFF (0v= OFF, 4~5VDC = ON) control.
    Dose the fuse on the inverter board check out OK? You can use other inveter board as long as the lamp connectors are the same and you just have to match the input signal pin. I have done many.
    http://s807.photobucket.com/home/budm/allalbums
    http://en.wikipedia.org/wiki/Capacitor_plague
    See example of the fuse on the inverter board.
    Jul 11, 2010 | Elo 15" Touch Monitor
    My Inspiron 1200 turns on but I have a black screen - no video. It began fading - now nothing. Is there anything I can replace?
    Hi:
    One thing to try is to connect your Inspiron up to an external monitor. You can plug in any kind of monitor, but you might have to toggle to the external mode:
    Hold down your function key, then hit the LCD/CRT key. If you have a good display on an external monitor, then you are going to need either a LCD inverter or new LCD. They are not too hard to swap out, the inverter costs about $15,it is mounted in the lid, below the LCD, and the replacement LCD about $80.
    Dec 01, 2009 | Dell Inspiron 1200 Notebook
    My lenovo Y510 ideapad turns on but the screen remains black. All of the buttons light up, but the screen stays like it is in sleep mode. I have tried rebooting, removing the battery but nothing seems to...
    The next tim eit is turned on, try shiniing a bright flashlight directly on the screen.
    If you can see anything there then the backlight has burned out on the screen, and will need to be replaced.
    If you cant see anything, try hooking up an external monitor to the laptop, if you have a desktop the monitor for it will work for the test..
    If the external monitor you hook up will work, then you will have to replace the screen..
    ( or at a minimum the inverter board, or check that the cables are tight that go to the screen)
    Oct 31, 2009 | Lenovo IdeaPad Y510 Notebook
    Screen goes black but still can see the desktop??
    Yes this is a back-light problem. The fault could be the inverter board which supplies high voltage to the CCFL lamp or it could be a faulty CCFL lamp, this lamp is a mini fluro tube.
    For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
    www.lcdparts.net
    Oct 12, 2009 | HP w2207 Monitor
    I have power, but no picture
    Hi...there,
    Seems your lucks just run out....you've got a busted backlight inverter. It's time for a upgrade...
    Nov 20, 2008 | Samsung SyncMaster 531 (White) 15 in. Flat...
    Lenovo 9165AB6 Monitor Logo
    220 people viewed this question
    Top Lenovo Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
