Question about Heartland 3010 Bottom Freezer Refrigerator
Heartland 3010 refrigerator. refrigerator section is warm, freezer is cold
Freezer is working, refrigerator is warm
You probably have a defrost issue with the freezer. Cold air is passed to the refrigerator section from the freezer, when the freezer does not defrost air flow to the refrigerator is eliminated causing the refrigerator to warm up. Check for icing on the back wall of the freezer. If no ice on back of freezer, check the damper assembly going to the refrigerator section.
May 26, 2015 | Refrigerators
Frigidaire Gallery Warm Refrigerator Cold Freezer
Generally the thermostat that turns on and off the compressor is in the freezer and so is the coils. The control knob that is in the refrigerator section is just to adjust the air flow between the two sections. If the air flow is blocked you don't get cooling in the refrigerator section. This could be a bad fan motor not creating circulation, ice blockage because the defrost cycle is not melting away ice accumulation. If it's defrost problems it could be timer, defrost thermostat, or heater element.
Feb 29, 2012 | Frigidaire Gallery GLRT218WD Stainless...
Freezer section gone warm, feels like refer section may be getting warm. Possible cold controls problem
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 19, 2011 | Refrigerators
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Apr 26, 2010 | Hoover HCA391FFK Bottom Freezer...
The freezer is cold but the refrigerator section is not getting cold...it is not warm but not cold according to the dial settings
check the operation of the damper door between the freezer/refrigerator section which lets cold from freezer into refrige compartment for ice build-up which will cause damper door to not open fully and cool the refrige compartment,if this is the problem,unplug the door ans remove and let thaw then replace and try it then
Jan 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have a Kenmore refrigerator (model 253.63732300) with freezer on top. The freezer section is cold but the lower section or the refrigerator section is not cold. It is warm. Any suggestion on why this is...
Hi, Check in the freezer section and see if there is frost building up on the rear panel. Notice if the evaporator fan motor is running. If there is frost, you need to repair the defrost cycle.
Please let me know if this what you find so I can assist you further.
Vic
Jun 14, 2009 | Kenmore 61042 Top Freezer Refrigerator
I have a GE GSS25WGMD BB Fridge. I have already replaced the Defrost Heater and Freezer Thermostat. The lower sections of the fridge and freezer are very cold. The ice maker will not produce ice and the...
First, when the refrigerator is running, open the freezer door and hold in the light switch so the freezer light goes out. You should be able to hear the freezer (evaporator) fan running. If it is running, then you most likely have a problem with the air damper. It is a motorized door in the very upper left side, back corner, of the fresh foods section. The door needs to be open for air to flow into the refrigerator section. If you place your hand near the vent holes at the upper refrigerator section and the freezer fan is running, FF section warm, you should feel cold air entering. If not, the damper door may have broken. It is not real easy to get at to replace, but that is where your problem may be. Be sure to check the freezer fan first, as a non-working icemaker may point in that direction.
Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
Both the freezer & refregirated section are not getting cold enough.
look on the backside of the freezer for frost. You might have a bad defrost heater....read more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer too cold frosty, and refrigerator section too warm
Sounds like a defrost problem if the evaporator is frozen over. If it's just Ice blocking air transfer on a top freezer model, then it's a blocked defrost drain.
Sep 10, 2017 | KitchenAid Superba Architect KSCS25INSS...
Heartland 3010 Bottom Freezer Refrigerator Logo
79 people viewed this question
Top Heartland Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you a Heartland Refrigerator Expert? Answer questions, earn points and help others
