How do i work out the ratio of £9.90 and 10p - Office Equipment & Supplies
  • Office Equip... Master
  • 8,080 Answers
Convert the pound amount into pence (or is it pennies?) then divide the 10p by the larger amount, multiply the result by 100 and append a % symbol.
Posted on Jul 31, 2010
  • k24674 Jul 31, 2010
    If you do not need the ratio in %, omit the multiplication by 100.
Fuel ratio for homelite ut104444
The recommended 50-to-1 fuel mixture includes 2.6 ounces of a high-quality, two-cycle oil with added fuel stabilizers and 1 gallon of unleaded 87-octane gas. Homelite recommends using their brand of oils, specifically designed to work in any model with a 50-to-1 fuel ratio.
Homelite XL Textron Fuel Ratio ' Home Guides ' SF Gate
homeguides.sfgate.com/homelite-xl-textron-fuel-ratio-89880.html
May 13, 2018 | Homelite Garden
Ratio for 2 stroke mi
if you are asking the oil /fuel ratio for a 2 stroke small engine. not being told the size, make or model makes an answer impossible
however Stihl have a special 2 stroke oil that is mixed at the ratio of 50:1 and that will cover all ratios from 20:1 to 50:1
Saves having different cans for all of the engines that can be a workshop
Mixed correctly it works well and if you want just the one fuel can that includes 4 stroke engines
the 50:1 ratio makes for good upper cylinder lubricant in those engines as well and you will not even see it smoke
Apr 21, 2018 | Garden
Aspect ratio problem -- will not display 4:3
You should have an option in your menu for "ratio lock"... many older screens have a ratio lock setting that you can enable or disable. Hope that works!
Jan 15, 2014 | Televison & Video
Audiovox LCDtv aspect ratio problem. Using its built-in media player, when ratio is 16:8, 16:7 or lower, the vertical aspect will be stretched to accommodate the full 16:9 ratio. So the pic is skewed. The...
Nope, there is no work around to get a full screen view with your unit. Unless of course you want to convert your media to the correct aspect ratio with the aid of a PC or Mac with the proper software. The Wondershare media converter software has a free limited edition. It works OK but is slow and lacks many of the "bells and whistles of the paid software.
Oct 20, 2017 | Audiovox Vehicle Parts & Accessories
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Want to interchange rear end on a 1997 5 speed isuzu rodeo. Can i use a rear end from a 1998 3.2 rear end
Hey there Alex,
I am going to say no...
I did check the interchange and Hollander Interchange says no.
Reason being , the carriers are different.
I am assuming you are working on a 2wd , or you would have mentioned the front axle assembly as well.
Here are the options for the '97 ;
96-97 only
disc brakes (6 cyl), (4.30 ratio, 43/10 teeth, S7C), 3 sensor ABS (sensor in pumpkin)
disc brakes (6 cyl), (4.30 ratio, 43/10 teeth, S7C), 4 sensor ABS (sensors in axle tubes)
drum brakes (4 cyl), (4.56 ratio, 41/9 teeth, HC6)
and here are the options for the '98;
1998 and 1999 only
4x2 (drum brakes), 3.73 ratio (41/11 teeth, 6NW)
4x2 (drum brakes), 4.56 ratio (41/9 teeth, HC6)
4x2 (drum brakes), 4.10 ratio (41/10 teeth, GT5)
4x2 (drum brakes), 4.30 ratio (43/10 teeth, S7C)
4x2 (drum brakes), 4.78 ratio (43/9 teeth, S2J)
Sep 30, 2011 | 1997 Isuzu Rodeo
94 caprice classic rear spider gears shot 12 or 16 possi what other rear ends are compatible for this 5.7 liter
. Axle Code >>>>>>>>>>>Standard
2YN Gear Ratio >>>>2.56<<<<< Ring Gear Diameter 8.5 Standard 2GA Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GB Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GH Gear Ratio 2.73 Ring Gear Diameter 8.5 Standard 2LW Gear Ratio 3.08 Ring Gear Diameter 8.5 Standard 2LR Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LY Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LT Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 6YF Gear Ratio 3.23 Ring Gear Diameter 8.5
Axle Code>>>>>>>>> Limited Slip
2LQ Gear Ratio >>>>>>>>2.93<<<<<<<<<<< Ring Gear Diameter 8.5 Limited Slip 2YG Gear Ratio 2.93 Ring Gear Diameter 8.5 Limited Slip 2LX Gear Ratio 3.08 Ring Gear Diameter 8.5 Limited Slip 2ND Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LZ Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LS Gear Ratio 3.23 Ring Gear Diameter 8.5
Nov 28, 2010 | 1994 Chevrolet Caprice Classic
Cannot change aspect ratio of picture when ratio button is pressed on remote. Batteries in remote are good. Everything else on remote works. Sony KP-57HW40
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Sony KP-57HW40 57" Rear Projection...
What do I need to buy or what should I do if my fuel reserve does not work or what is the fuel capacity for a 1991 Yamaha FZR 600?
var gDcsId="dcsmm6y3q0000004zhgx8uuaa_9g7g"; var dom=window.location.hostname.replace(/^www\./,''); window.onload = function() { init(); setThumbnailimages("galleryThumbNails", "galleryImage"); enableMenu("archive"); initLightbox(); }; Technical Specifications 1991-FZR600
Engine Engine type Liquid cooled, 4-stroke, forward inclined parallel 4 cylinder, DOHC 16 valves Displacement 599 cc Bore x stroke 59.0 x 54.8 mm Compression ratio 12.0 : 1 Maximum power 66.8 kW (91 HP) @ 10,500 rpm Maximum torque 65.7 Nm (6.7 kg-m) @ 8,500 rpm Lubrication system Wet sump Fuel System Mikuni BDST32 x4 Clutch type Wet, multiple disc Ignition system Transistor controlled (digital) Starter system Electric Transmission system Constant mesh, 6 speed Primary reduction ratio 1.708 Secundary reduction ratio 3 Final transmission Chain Ratios gearbox 1st 2.846 Ratios gearbox 2nd 1.947 Ratios gearbox 3rd 1.55 Ratios gearbox 4th 1.333 Ratios gearbox 5th 1.192 Ratios gearbox 6th 1.111 Chassis Front suspension system Telescopic fork Front wheel travel 130 mm Rear suspension system Swingarm (Link suspension) Rear wheel travel 115 mm Caster angle 25° Trail 94 mm Front brake Dual discs, ø 298 mm Rear brake Single disc, ø 245 mm Front tyre 110/70V17 V240 Rear tyre 140/60V18 V240 Dimensions Overall length 2,165 mm Overall width 700 mm Overall height 1,155 mm Seat height 785 mm Wheelbase 1,425 mm Minimum ground clearance 135 mm Dry weight 181 kg Fuel tank capacity (reserve) 18 L Engine oil tank capacity 3.1 L
Jun 27, 2009 | 1991 Yamaha FZR 600
I don't have the manual and don't know the gas ratio
If new it's 50:1 and after 100hr Break in you can use 40:1
If not under warranty most saws and 2-stroke engines work great @ 40:1 ratio
Some Old saws use 32:1 and some as little as 16:1
Stick with a 40 to 1 mix ratio for all newer 2 Cycle stuff you own and you'll be just fine!!!
Nov 20, 2008 | Garden
94 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
