Question about Hoover S5615 Hush Central System Vacuum
CANISTER IS GETTING POWER BUT NO SUCTION FROM HOSE AND DOESNT SEEM LIKE THERE IS POWER GOING TO HOSE..I HAVE CLEANED OUT THE FILTER AND CHECKED ALL BREAKERS...
    Genius:
  • 1,478 Answers
Carnister vacuum cleaners are all built with the same principle in mind. A motor generates power which powers a vacuum which, in turn, creates suction to lift debris. The most common areas of suction loss are within the hose itself, the vacuum bag, clogged rollers, broken vacuum belt or a faulty gasket. All of these problems will lead directly to the vacuum cleaner losing suction. I will advice you check any of the listed problem above to see where the problem lies and fix it.
Take care.
Posted on Jul 29, 2010
Filter queen vacuum head has no power
More information needed. When you turn on the vacuum do you hear the motor running? Is the problem that there is no suction at the head? Is there suction at the canister when the hose is removed? I would first check to make sure that there is no obstruction in the hose. Have you checked the filters to see if they are clean?
Sep 11, 2014 | Filter Queen Majestic Canister Vacuum
NO SUCTION
You haven't given enough details of what machine you are asking about. Take it to your local vac shop for help.
Aug 08, 2017 | Dirt Devil SwivelGlide Bagged Upright...
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
No suction
the hose can clog up insid where you cant see it my husband takes it off and runs water thru it to flush stuff out lets it dry then reconnects it
Sep 18, 2012 | Dirt Devil Featherlite Bagless Vacuum...
Very poor suction.No obstructions in hose.Just cleaned filter and emptied canister.
Are you getting good section at the wall inlet? If so, see below.
Check for a clog inside the power nozzle. Detach wands and drop a small coin into connection. It should fall through. If it doesn't, there's a clog that needs cleared.
A leaky hose could be the problem. Any vacuum hose is often mistreated, though intentionally. But due to the length of the CV hose, it undergoes quite a bit. Being constantly dragged around corners and pulled around, as well as improper storage can all result in holes/leaks in the hose. A few tiny holes throughout the length of the hose will result in an often dramatic loss of suction.
How old is the vacuum? It may be time to replace the hose.
Nov 22, 2010 | Electrolux Central Vacuum
Very little suction when vacumming
Hi There,
I think I know exactly what the problem is with your Dyson. I'd be happy to try and walk you through it, but just want to make sure that you still need help, or if you've already fixed the problem.
Apr 05, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Hose has very little suction
ok dont know but if you havent already where the roller sits underneath it where the dirt sucks threw i had a problem a little like yours i did every thing you did same thing happened.but i had a clog in the vacuum i used a pressure with out the dirt canister on i blew out a real nice hairball.after that i tried it and what do you know it worked. hope that helps
Jan 05, 2008 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
94 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
