Question about Daewoo KOG-867T Microwave Oven
Microwave not heating
During an electrical storm we had a power surge. Our microwave (above stove type) will not heat now. Everything else works, clock, lights, etc., except the high fan setting. Low fan works ok. Can the microwave be saved or is it trashed? We just bought it in October, 2009.
  • 415 Answers
It can be saved but get a quote from the shop first before proceeding and always evaluate it against the cost of a new one,
it could be the power supply has shorted but check it out.
Posted on Jul 29, 2010
No power to the microwave, after storm.
The low voltage brownout let the oven draw too much current, and likely an internal fuse failed. Typically after removing a dozen Philips screws you can take off the cover and locate the fuse, which you can match and replace. [If it still has "power" (like the lights come on) but has stopped heating, then it could be any number of other issues (main capacitor fail, etc)] I've changed a fuse or two in my day, and years ago a failed capacitor, with success.
Jan 13, 2014 | GE Microwave Ovens
How do I set Clock?
Disconnect the microwave from the power source while the power is still out. If the microwave is a built-in, turn off the circuit breaker. Otherwise, unplug the microwave from the wall outlet. This prevents a power surge from damaging the magnetron tube when the power is restored.Turn on the circuit breaker or plug the microwave into the outlet only when you are sure that the power is permanently restored. If there are still storms in the area, the power may be disrupted again. Reset the clock on the microwave. Microwaves vary slightly on how to set the clock, but usually there is a clock button you press. Use the number pad to input the correct time and press the clock button again to set it. Test the microwave by heating some water to ensure that it is still in good operating condition.
Jun 20, 2012 | Emerson Fans MW8995B Microwave Oven
I have a Kenmore over-the-stove microwave oven that is not heating food. Everything else works. I received a message of PF on the keypad. Is there anything I can do before I have to call a repair...
PF - Power Failure - PF error code indicates a power failure during the cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 13, 2010 | Kenmore 62702 Microwave Oven
I have the Kenmoore Microwave Hood 721.80402. During this last wave of storms, I was without power for 2 days. Once the power was restored, the microwave will not work. Everything is plugged in and the...
You might try pulling the plug on the unit and leaving it overnight. The electronics may have locked up due to irregular voltage during the failure. There may also be a GFI (ground fault interrupter) on that circuit that has tripped for the same reason. Check the kitchen outlets for a tripped GFI.
Feb 14, 2010 | Kenmore 62622 Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
Lost heat on microwave ,everything else works fine simple fix?
Inexpensive fix yes, but quite dangerous as you have to either replace the High voltage Diode or the magnetron depending on what has gone. Most often it is the Diode as that is fed a few thousand volts and anomolies such as a surge in current cause it to blow(popping sound) You can also check the fuses and if lucky it is just a fuse, but a fuse very seldomly just blows as it points to an underlying fault such as magnetron , capacitor or Diode. Have a service man attend to it unless you know what you are doing as you are dealing with lethal voltages and current even after the microwave has been switched off.
Aug 01, 2009 | Kenmore Microwave Ovens
Need to know how to remove Advantium 120 convection/microwave oven Model SCA1000DWW03 from mounting above stove so that it can be taken to repair shop - problem is completely dead after power surge during...
Usually there are 3 or 4 mounting bolts located in the floor of the cabinet above. First you will have to disconnect the power and then the duck work if the unit is ventde to the outside. To remove the unit requires two people, one to support the unit and the other to remove the bolts. If you are doing it alone, quite difficult, you'll have to juryrig a deadman support. Ther is a wall plate behind the unit that has a lip that the back bottom of the microwve is locked into. After the bolts are removed slowly lower the front until you are able free the unit from the lip of the support plate.
Jun 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Daewoo KOG-867T Microwave Oven Logo
184 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
